LittleDot MK VI+ już w Audiomagic!
Witajcie,
do Audiomagic dotarł arcymocny wzmacniacz ze stajni LittleDot, model MK VI+.
O co szum? Między innymi o 5W przy 120ohm na słuchawkach. Tak, 5W.
Technical Specifications:
Available in either Black (default) or Silver
Fully Balanced Architecture
SEPP (Single-ended Push Pull) OCL (Output CapacitorLess) in Class-A
Active 2 fan cooling
Driver Tubes: 2x 6H9C
Power Tubes: 4x RCA 6080
Inputs:
Balanced: 2x 3-pin XLR
Single-ended: 2x RCA
Outputs:
Balanced: 4-Pin XLR
Balanced Pre-Amp: 2x 3-pin XLR
Single-ended: 1/4" (6.35mm) TRS Stereo jack
Frequency Response:
5Hz - 80KHz (-3dB)
10Hz - 30KHz (-1dB)
Input Impedance: 50K ohms
Pre-Amplifier Output Impedance: 600 ohms
THD+N:
0.02% (2Vrms @ 1000Hz)
0.06% (10Vrms @ 1000Hz)
0.3% (20Vrms @ 1000Hz)
Signal-to-Noise: 92 dB
User Selectable Gain Settings: Low (10 dB) and High (15 dB)
Power Output:
1W per channel into 50 ohms, 5W per channel in 120 ohms
Power Consumption: 25 VA
Measurements:
Metric: 350mm (length) by 290mm (width) by 140mm (height)
Imperial: 13.8 inches (length) by 11.4 inches (width) by 5.5 inches (height)
Weight: 9.6 kg or 21 lbs
Available in either 110-120VAC or 220-240VAC
One Year Official Little Dot Warranty
Zapraszamy na Sienną 61 w Warszawie, można pooglądać, posłuchać oraz zakupić tę małą bestię.
