d'Agostino Helius
Elberoth
Recommended Posts
800kg, 6 części, 20.000W przy 1 Ohm.
What’s next?
The next thing I’m going to build is a new product line called the Progression, set to be priced somewhere between $10,000-$20,000. The first product in the line will be a big mono power amplifier, similar to a Momentum but costing somewhere around $16,000-$18,000. And it will be very powerful. I’m hoping that will appear before the end of the year – I’ve told the factory ‘August’, which means I’ll probably finish it in late November!
Once the Progression line is done, I’ll turn my attention back to the Helius amplifier I’m building. Helius is truly a monster amplifier. It’s made of three chassis – it’s got a ‘plus’ amplifier and a ‘minus’ amplifier because it’s a purely balanced design. People say they’ve made a balanced design, but I don’t think anyone’s made a truly balanced design like this. It’s got two completely mirror imaged amplifiers that are virtually identical, only one is inverted from the other.
And then, I took the insides of the amplifier – all the bit stuff, the transformers and electrolytics and power devices and heat sinks – and put them all in one case. But no input board: the input board is inside the base, fully isolated chamber with its own power supplies, and sits below the amplifier on some suspension equipment made by Mike Lapis of HRS fame. So there’s no vibration, then it’s totally sealed with µ-metal and copper shielding around it so no influence from the amplifier.
The amplifier is built out of a solid block material, and the toroid is 10” in diameter and it’s seven inches tall. So the toroid itself probably weighs about 130lb, and that is actually milled into a block, the outside block of the amplifier; the toroid fits into a hole and is then covered.
The electrolytics capacitors, of which there are a total of 12 in the two sides, comes out to 1.2F. Each transformer is 6kW, 12kW in total. It’s got a giant copper heatsink; 10” tall, 28” long, and 1.5” thick. That’s bolted to a piece of specially designed aluminium designed for heat reduction in aircraft known as 5051, and each fin of that heatsink is milled out whilethen the base is bolted to the outside of the copper. And that’s three inches deep and of course 10” tall and 28” long – it’s a single piece. And that’s the heatsink for the output stage.
The capacitors, and power supplies are all in this great big block. If you imagine the block is 11” deep, 10” tall, 28” long – that’s where the block starts – and then it’s hollowed out to fit the transformer and the six electrolytics. Then in the back – where it’s ‘empty’ – is where the protection circuits and the hook ups and all that go, then that part is slid onto that heatsink, there’s bolts that go through the inside web of the heatsink to hold that block on, so it’s one rectangle.
If you add up all the parts, the amplifier is going to weigh 780-800lbs. Per channel. Each plus amplifier and minus amplifier has its own cord; it’s designed to run on 220V or 240V… it doesn’t run on 110V. And you need two of them for each channel.
It’s got an extraordinarily gorgeous meter on the front. It’s about 10-12” in width, and six inches high that sits on the front. It’s really strange – it’s almost Bauhaus in design, but looks like a Momentum from another dimension. This is not that big for the kind of power it will produce, though, because it will produce up to 20,000W into one ohm!
Once I get the Progression amplifiers done, this is next in line. I would love to have it ready for CES, but maybe I’ll just show the case. I have the metalwork ready. But it will definitely happen by March next year. Or maybe CES 2017!
Powiedzenie go big or go home nabiera nowego znaczenia :)
Hidden Content
Link to comment
Share on other sites
Cena 250 tyś USD czyli w naszych realiach ponad MILION PLN...są kolumny za milion to pora i na końcówkę za milion...
30 sztuk już podobno sprzedano...
W obecnych czasach gdy wielu CEO zarabia rocznie 300 razy więcej pieniędzy niż ich szeregowi pracownicy w biurze to wcale nie dziwi...
Ja tam czekam na chwilę gdy kable głośnikowe będą za milion PLN...
Hidden Content
Link to comment
Zamów wpłać zaliczkę a sprzedam Ci nawet za dwa :)
Hidden Content
Link to comment
No tak tylko po co? Wiadomo, że najważniejsze są pierwsze waty mocy. Z reguły słuchamy na 2-5W mocy. Przy impulsowych, mocnych uderzeniach basu czasem skoczy to do 20W. Bywa, że chcemy przłożyć mocniej ale to nie często i wtedy Max w impulsie pójdzie 50W.
Wzmacniacz musi mieć trochę zapasu, więc te 70-100W w klasie A to jest Max.czego możemy potrzebować. Po co komu 20000W? Tym bardziej, że wzmacniacz optymalnie pracuje w swoim środkowym zakresie mocy czyli gdzieś między 1/3 a 2/3 mocy. To nawet gdyby takie potwory grać na 1/3 to będą oddawały straszną moc. Podają 20000W dla 1ohm, czyli 10000W dla 2ohm, 5000W dla 4ohm. Większość kolumn jest 4ohm, więc 1/3 z 5000W to mamy ok 1500W i kto będzie grał z taką mocą? Gdzie? Na stadionie? Pomijam już inne aspekty jak zapotrzebowanie na prąd czy wagę tych sprzętów. Produkt nikomu niepotrzebny. Nie tędy droga w audio.
Hidden Content
Link to comment
50 wat to forte dużej orkiestry symfonicznej tak ze po co nam więcej przy tej mocy nawet na 80m2 idzie ocipieć :)
W domu normalnie słuchamy na 1-1,5 wata mocy tak że może autor wzmacniacza chce nagłaśniać Kraków Arenę ;)
Hidden Content
Link to comment
dlatego nie dziwcie sie ze ja mam taki tor odsluchowy(Goodmansy+Cary 300B) bo juz dawno pisalem ze najwazniejsze jak zagra z pierwsz
ych watow i to wszystko
Hidden Content
Link to comment
Masz rację, tylko zapominasz, że za mało watów nie wysteruje dobrze kolumn i nie ma wtedy kontroli nad kolumnami. Twój wzmacniacz nie nadaje się do kolumn. Owszem na wysokoskutecznych zagra to głośno ale kontroli nie ma. Dlatego za duża moc potrzebna nie jest, ale za mała też być nie może.
Hidden Content
Link to comment
A po co komu Bugatti Veyron o mocy 1300 koni? Kto jeździ z prędkością 420 km/h? Ten pan w audio osiągnął już tyle, że ma prawo poszaleć. Klienci się też znajdą.
Hidden Content
Link to comment
Sly, nie poznaję cię! Nie uwierzysz, ale zgadzam się z tobą :)
Po co? Ano po to, by elberoth mógł po raz kolejny wkleić sobie angielski tekst. A wydawało mi się, że forum jest polskojęzyczne. Lenistwo gorą.
Tyle, że 1W mocy wzmacniacza nie daje 1W mocy akustycznej. Więc różnica jest znacznie większa.
Hidden Content
Link to comment
Cary 300B posiada super kotrole nad Goodmansami,jest mocny i szyki,moc ma az nadto do tych kolumnami,tak ze najpierw musialbys poslu
chac mojego toru zeby tak twierdzic
Hidden Content
Link to comment
Pełna zgoda. Nikomu nie jest potrzebne 1300KM, ale też 100KM to nie ta sama jazda co 300KM. Dlatego mocny V6 czy jeszcze lepiej V8 jak najbardziej, ale bez chorej przesady.
Hidden Content
Link to comment
"800 kg, 6 części, 20.000W przy 1 Ohm."
Wygląda jak napinki ministrów, który ma dłuższego.
Hidden Content
"Naukowe teorie mnie nie interesują. Zresztą kogo tu interesują? To jest forum dla audiofilów."
Link to comment
Ten zestaw nie jest dedykowany do symfoniki Mirku! Kwartety,jazz, małe składy, wokale to OK.
Hidden Content
Link to comment
kazdy z nas buduje tor pod swoje upodobania i tak powinno byc, prawda!
Hidden Content
Link to comment
Prawda.
Hidden Content
Link to comment
Prawda ale nie pod symfonikę, prawda ?
Hidden Content
Link to comment
Oczywiście, że nie. Do mocnego rocka, pop i muzy elektronicznej też się to nie nadaje, ale mirek słucha głównie vocali, więc może dla niego jest ok.
Hidden Content
Link to comment
Powiedzcie mu jeszcze dlaczego nie do symfoniki, albo .., moze nie, bo znów dekadę będzie szukał kolumn i pieca, prawda?:)
Hidden Content
Link to comment
Dan już zrobił wzmacniacz o mocy 5W (z założenia był do słuchawek, ale jak się okazało - był zaprojektowany z takim zapasem, że można było także pod niego podłączyć kolumny), robił wzmacniacze o mocach 50, 100 i 900W, więc teraz najwyraźniej zapragnął czegoś o mocy 2500W ... i kto mu zabroni ? :)
Hidden Content
Link to comment
Nikt, niech robi.
Hidden Content
Link to comment
Dan weź zaliczkę i do roboty zawsze chciałeś tyrać :)
Przypomina mi to koniec wyścigów starych technologii i lokomotyw w Anglii kiedy ilość węgla potrzebna do spalania i uzyskania wysokich prędkości zaczęła przekraczać masę którą te lokomotywy dały ciągnać. Jakiś czas sobie z tym radzono stosując specjalne wysięgniki ściągające podczas jazdy węgiel z pobocza torów. Znacznie wygodniejszy i bardziej elegancki okazał się kawałek drutu doprowadzający energię do lokomotywy elektrycznej.
Dan powinien takie eleganckie rozwiązanie zastosować a nie tylko wungiel i więcej wungla z Węgorzewskiej.
Hidden Content
Link to comment
Hidden Content
Link to comment
to już kiedyś było: Krell Master Reference
pokaz możliwości w stosunku do obecnego Krella
Hidden Content
Link to comment
Wrzuć jeszcze np Dynaudio a kiedyś kiedyś lata temu dawno STAX też pokazał swój topowy wzmacniacz a obecnie kupili go i jego niektóre produkty robią Chińczyki.
Hidden Content
Link to comment
firma Krell za czasów mr d`Agostino
a
obecny Krell to zupełnie inny świat i możliwości.
Hidden Content
Link to comment
Te Krelle MRA i monosy Dynaudio Arbiter miał taki jeden Norweg z WBF.
Hidden Content
Link to comment
A Pivette pamiętacie:))
Jest do wzięcia za jedyne pół bańki $. na
Hidden Content
Hidden Content
Hidden Content
Hidden Content
Hidden Content
Link to comment
Nie tędy droga
Dawno pisałem, że osoby, które nie mają wiedzy dotyczącej rozwoju, kreują gigantyzm.
To rozdymane ego zbudowało te produkty, natomiast klient zawsze się znajdzie, jeśli są odpowiednio legendowane.
Hidden Content
Link to comment
To jest wlasnie Hi End niedostepny dla przecietnego czlowieka. A nazywanie sprzetu za 20 30 tys HiEndem jest smieszne dla tych ktorzy wydają miliony zlotych na swoje klocki.
Hidden Content
Link to comment
trolle nie śpią.....czuwają :)
Hidden Content
Link to comment
Archived
