compliance wkładki Nagaoka MP500
2A3_fan
Przejrzyj dyskusję:
Napisane jest, że compliance dla Nagaoki mp500 liczona jest dla 100Hz.
Przejrzyj dyskusję:
Ponieważ znakomitą większość japończyków trzeba tak liczyć.
ciekawa rzecz z t Nagaoką - sam się nią interesowałem, aczkolwiek cena w Polsce jakaś zaporowa - otóż w tej dyskusji na vinylengine jest mowa, że w realnych pomiarach jej compliance sięga ponad 20cu?
"dlaloum wrote:
The MP500 uses the Japanese measurement system at 100Hz - to convert multiply by 1.75... which makes it 8.5 x 1.75 = 14.875cu or roughly 15cu
No no no. In this case, rule of thumb x1.75 doesn't work. Using loafer, compliance of MP-500 is near 23cu, which is confirmed by Miller audio measurement in their published results. So the MP500 is also a 'mid compliance' cartridge, quite similar in fact to the 2M Black, and both are well suited to mid mass arms.
dlaloum wrote:
LD, 22cu does not seem mid compliance! - and yes it is widely used in mid mass arms (which are the most common arm type).
Well, evidence such as Ortofon spec, and 3rd party test house measurements say it is 22cu and mid compliance, DL. And, by your own admission you have no first hand experience.
dlaloum wrote:
The Paul Miller measurements (
do not appear to include anything below 20Hz - which makes it hard to work out what is going on in the lower range where the cartridge/arm resonance happens!
No no no, Paul Miller always reports measurements of the lf resonances. At the very bottom of the test report. In the case of the 2M black, in a 12g arm, resonances were 11Hz and 9Hz. It's published, and there to see. This confirms Ortofon's 22cu spec for 2M black compliance. And Paul Miller elected to test it in a 12g arm, for obvious reasons."
lub mp50
nie znam tego modelu ;)
Miałem MP150 i mp200 - dla mojego ramienia , niestety , grały zbyt "miękko"
Ja sfrajerowalem sie kilka dni temu. MP500 nowe second hand wrzucil na ebay jakis Wloch. Za dlugo sie zastanawialem. Sprzedala sie nastepnego dnia bodajze. Wystawil za ok 1800zl.. Komplet jak sklepowy... Szkoda...
