biniek
Audio over IP
Recommended Posts
mozna tak powiedziec ale ale nie rozkodowuje paczki danych tylko zmienia strumien audio na zrozumialy dla DAC
mniejsza o proces nie do konca rozumiem na jakiej zasadzie dziala wazne ze gra zajebiscie
wg defnicji
Dante (Digital Audio Network Through Ethernet) is a combination of software, hardware, and network protocols that deliver uncompressed, multi-channel, low-latency digital audio over a standard Ethernet network using Layer 3 IP packets
In a Dante-enabled device, the hardware takes digital audio and ‘packetizes’ it. Basically, it segments the audio and wraps it in IP (Internet Protocol) packets suitable for transmission across an Ethernet network. The packets contain timing information and source and destination network addresses, allowing them to be efficiently routed through the network to the correct destination.
When a device receives Dante audio packets, it reconstructs them back into a continuous digital audio stream, which is then played out, recorded, or digitally processed, depending on that device’s role in the audio system.
Hardware Dante devices support exceptionally low latency (on the order of microseconds, rather than milliseconds), and common low-latency applications (for example, real-time monitoring during recording) are easily supported.
Clock synchronization is critical to the success of any audio network. For packetized audio to synchronize perfectly across the network, all devices need to share identical timing information. This is achieved by the presence of a single master clock, which provides synchronization information for all devices. Dante ensures that the most stable and accurate clock automatically becomes the master clock. All other devices automatically lock to that device, eliminating any network timing issues.
Edited by biniek
Share this post
Link to post
Share on other sites
Z tego wynika że endpointami są konwertery do których przesyłane są indywidualnie adresowane pakiety danych.
Przy sieci składającej się z wielu endpointów i źródeł protokół sterowania ruchu Dante ma sens.
Ale w prostym domowym audio robi się z tego klasyka : żródło , sieć, sterownik,sieć, endpoint.- DAC / przynajmniej tak u mnie to wygląda/.
Nie wiem dlaczego konwertery obsługujące Dante miałyby być lepsze od innych konwerterów sieciowych.
Ostatecznie sygnały AES czy SPDiF przy dobrym zegarowaniu muszą być tożsame i tej samej jakości co daje tą samą jakość dzwięku na DAC.
Zasilanie PoE też niczego dobrego nie wróży :(
Podłączałeś ten konwerter do normalnego DAC, czy tylko do LAB Guppen ?
Edited by marekzawa
Share this post
Link to post
Troche manipulujesz slowem konwerter
Urzadzenia dante enabled to nie konwertery
Nie zachodzi tu tradycyjna konwersja do i2s z ktorego dopiero formowany jest strumien audio
Taka "paczke audio" tworzy karta dzwiekowa i wysyla ethernetem do urzadzenia dante ktore ja rozpoznaje
Proponuje poczytac watek na head fi ktory ma 230 stron i zachodni audiofile juz od dluzszego czasu graja tym protokolem bo jest lepszy niz dotychczasowe rozwiazania
Teorie i zyczenia tego raczej nie zmienia
Edited by biniek
Share this post
Link to post
xavian
Biniek...rozumiem Twój zachwyt...fajnie, że spełnienie dźwiękowe dokonane...
"ostatnio pochlonelo mnie szukanie wlasnego brzmienia w sprzętach muzycznych bo to duzo ciekawsze niz odtwarzanie czyjegos ;) "
I to jest to...
Udostępnij proszę jakieś demo swojej twórczości...
Edited by ziko369
Share this post
Link to post
W lipcu wchodzimy do studia i nagrywamy plyte. Teraz trwaja ostatnie szlify i szukanie wlasnego brzmienia. Mam tez duzo na glowie bo odpowiadam za cala warstse muzyczna :) moze tez dlatego sluchanie audio zeszlo na drugi plan i zostaje z tym co mam
  • Like 1
Share this post
Link to post
Pc wyjsciem rj45 router adapter dac i gotowe
Podobne rozwiazanie protokolem aes67 tj. nadac kosztuje prawie 50 tys zl
Share this post
Link to post
to banalnie proste wchodzisz na strone www.audinate.com
podajesz adres mailowy i podstawowe dane i dostajesz na 21 dni wersje trial którą później przedłużasz bezterminowo za 29$
to wszystko - nie trzeba niczego wiecej instalować ani płacić żadnych abonamentów
Share this post
Link to post
sluze pomoca jakby co
Ty lepiej ładną płytę nagraj. BTW gdzie nagrywacie?
  • Like 1
nagrywamy.com
Share this post
Link to post
gitary to pojda pewnie cyfrowo na popularnych ostatnio amp modellerach a reszte w studiu kolegi w milanówku pod Warszawą - Sound Grenade Studio
btw widzę że sie nawet znacie bo na fb zachwalają takie oto cudo ;)
11226551_694994240631457_5607846931783736115_n.jpg?_nc_cat=0&_nc_eui2=v1%3AAeEETImrQ9sbWxCaSleZT2Rl_V5KbRDyjoVH-Lk2F12JOWhPm8b5eBsnA7f_VuzYxvVg-KWUuQojNoMAH3PvBHL2UL5yW0vOPeUS9b-kJ1gmbw&oh=432ef90192cb7512853e08ecb429672c&oe=5B930B87
Edited by biniek
Share this post
Link to post
O jak ładnie, darmowa reklama ;)
No to powodzenia!
  • Like 1
nagrywamy.com
Share this post
Link to post
Prices of DC line, small enclosure, 12V DC
- Micromedia – Digimedia DIO XLR: €180.--
- Optional external PoE-Splitter €10.-- for one pcs
Zamówione
  • Like 1
Share this post
Link to post
Dla porządku. :)
Nadac, jak i ogólnie Merging korzysta ze standardu (!) aes67, ale z protokołu ravenna, a nie dante.
"Trochę" sie to różni....
W sieci można znaleźć sporo informacji...
P.s.
By trzymac się prawdy.
Najtańsze, profesjonalne rozwiązanie merginga z ravenna kosztuje ok 12 tys. Ale pełni tez sporo innych funkcji....:)
Edited by globtroter1
  • Like 1
Share this post
Link to post
Dla porządku. :)
P.s.
faktycznie przyda sie male sprzatanie bo pomylilem standard z protokołem
na pytanie czy oba protokoly poza probkowaniem roznia sie sonicznie pewnie sobie nie odpowiemy a i jednemu z nich zapewne byloby nie w smak biorąc pod uwagę ile kosztuje
Edited by biniek
Share this post
Link to post
.... Ravenna w przeciwieństwie di Dante jest darmowa.: )))
Ma inne przeznaczenie i zastosowanie.
Ma inne progi jakosciowe i algorytmy.
Między nagłośnieniem dworca wschodniego, czy centrum handlowego, a np. Docelowo 512 kanałowa transmisją hd z igrzysk olimpijskich istnieje spora roznica... ;)))
Wysłane z mojego LG-K420 przy użyciu Tapatalka
Share this post
Link to post
dante nie kosztuje wiele drozej bo 29$
a ile kosztuje najtansze urzadzenie dekodujace ravenne?
umowmy sie w audio nie potrzebujemy zwykle wiecej niz 2 kanałów a wyjątkowo skrzywieni kilku więcej ;)
zreszta ravenna ma swoj watek w zakladce hi end - dante jest dla mas i nie potrzebny mu marketing
Edited by biniek
Share this post
Link to post
Trzymajmy sie prawdy. To Dante ma bardzo agresywny marketing w porownaniu do darmowej ravenny i innych konkurencyknych protokołów ( tak są też inne) bo jest płatne. :)
Reszta jak wyżej.
Poza tym warto podejrzec kto i do czego używa ww protokołów.
Uważam że Dante ze swoimi ograniczeniami, do domowej sieci może być spoko.
I tak większość nie zobaczy/ nir usłyszy różnicy. ;)))
Share this post
Link to post
Reszta jak wyżej.
mimio wszystko namawiam do sprobowania dante tym bardziej że masz doświadczenia z ravenną i grasz (jeśli się nie zmieniło nic od mojej ostaniej wizyty u Ciebie) po usb
Share this post
Link to post
warto naprawde bo jakosc dzwieku powala
Od strony technicznej co to ma takiego, e jakość dźwięku "powala"? Edited by Kyle
Share this post
Link to post
trzeba sprawdzic kluczem jest izolacja galwaniczna wyjcia rj45, zerowa latencja i brak konwersji do i2s
Share this post
Link to post
Zalezy od wejscia w dac ktorys z tych micromedia ma toslink
Jest tez klika innych producentow z kompletem zlaczy ale kosztuja ciut wiecej bo ok 400eur
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
