Najpiękniejsze zespoły głośnikowe świata
parantulla
Szanowny Dudivanie !
Ja niestety ino słuchacz, nie szpecyjalista...
Ale ochoczo lineczkiem służę:
Pozdrowienia. ( śle Gienia z Lichenia )
Re: Dudivan
ad Goldmund (ia także YG Acoustics) - co ciekawe obudowy tych kolumn są w całości z metalu (niejednolite, różne stopy); relatywnie rzadko spotykane (TAG McLaren, Krell LAT i Arcitec stosują jednolite obudowy aluminiowe), ale bardzo ciekawe rozwiązanie
najlepiej zacytować samego Goldmunda:
"To insure perfect enclosure rigidity under extreme internal pressures, all the Epilogue enclosures are totally built in metal. A construction of brass and aluminum, with internal steel bracing is used to capture the vibrations and evacuate them to the center Mechanical Grounding evacuation bar.
In addition to its internal perfect rigidity, this full-metal construction allows any of the internal parts to be replaced without degradation of the speaker's integrity, each of these parts being attached by mechanical screws without any gluing or painting.
A neoprene joint system guarantees the enclosure's perfect sealing even after several dismounting"
Goldmund ma całą teorię "Mechanical Grounding", absolutnie nie ma mowy o drganiach czy dzwonieniach
stosowny cytat:
"Constructed around a vertical steel bar, which connects each of the four enclosures to the ground, each Epilogue enclosure concentrates the vibration evacuation towards this steel bar. The choice of metals in the assembly is optimized to fully benefit of the mechanical diode effect, avoiding external vibrations to be communicated to the sensitive parts. Driver's mounting in the Epilogue 1 are made of a sandwich of brass and aluminum with a total thickness of 20mm in order to avoid the baffle of the driver to be excited by the heavy vibration of the driver itself.
The external frame holding the enclosures together and insuring the speaker's stability receives 24 Teflon insulators to avoid vibration transmission, leaving the central steel bar play its full role of Mechanical Grounding transmission"
pozdrawiam,
graaf
a teraz coś z RPA - vivid K1 wykonane z włókna szklanego i polimerów. Do ciekawostek konstrukcyjnych należą dwa twetery w tubkach i sastosowanie czterech wooferów (2 na przodzie i dwa z tyłu) - szczegóły
"I am an audiophile"
amphion Xenon
Dla mnie najładniejsze są ...
zbierałem na nie kasę ale zanim uzbierałem to zdążyli zakończyć ich produkcję ;-)
>Pitdog i Yanoosh
Faktycznie dużo dziwadeł, ale żeby były piękne?
W prostocie siła - VA Mozart i Esa Continuum.
Bluesound Powernode N330 - Elac Vela BS403 - B&W ASW610
to jest piękność
Tannoy Kingdom naprawde zacne.
Mnie też się podobają te z fotek:2, 3 i 4. powyżej. Chyba nie lubię dziwadeł i rzeczy na siłę. To nudne, jak jednosozenowa moda ! Albo inaczej: dla koneserów formy ;)
>andrea29
Prosta forma, dobre lub bardzo dobre materiały i głośniki, nienaganny montaż, jak jeszcze grają dobrze to nie ma co się zachwycać kolumnami a'la szafa gdańska lub zlewozmywak - czyż nie?
Re: tomek11 i in.
Zamiast oceniać gust innych wklejajcie Panowie to co Wy uznajecie za "najpiękniejsze zespoły głośnikowe świata" - taki jest temat tego wątku - nikt nikogo nie zmusza aby go oglądać czy się wpisywać
pozdrawiam,
graaf
Nie werze, że jeszcze nikt ich nie wkleił!!!:)))))))))
>graaf
Co to ja uważam to jest kilka wpisów wyżej - ze zdjęciem :)
Nie bierz do głowy tego zlewozmywaka i zakończmy dyskusję o gustach.
Taaa... Teraz jęczą nad losem Tonsilu a jak to miało przetrwać jak nawet głupiej naklejki komus sie nie chciało prosto przykleić. Pewnie tak samo starannie są wykonane wewnątrz i może stąd to legendarne brzmienie się bierze. Brak słów normalnie...
Vienna Acoustics... Oj tak tak. Widziałem kiedyś Beethoveny z bliska... Piękności.
A mnie - moje też się podobają - B&W CDM 9NT
Janusz z Torunia
Wiem, że na fotce wyglądają dość nieciekawie, może i trochę smutno, bo czarne. Za to w realu - spodobały mi się od razu. Do desigerskich wnętrz jak znalazł. Forma nie przybrała tu skali patologii i udziwnienia,a pozostała szlachetna. /To moje zdanie./ Mieli je w AS i nie były wcale tak drogie jak myślicie. Wykonanie mogłoby być lepsze. Pod lakierem widoczne były niestety punkty połączeń obudowy :(
Czy ktoś z Was widział wcześniej taką formę ? /Ja - pierwszy raz,a trochę na wystawkach bywałem./ Wklejam specjalnie dla Was, nie bijcie ;)
I jeszcze coś z domowego podwórka. Gra - do d... za to nieźle się prezentuje, bo nie sztampowo. Z uwagi na niebanalną jednostkę napędzającą (moc do 20W) prezentuję kolumienki-trumienki razem z nią. Oceniajcie:
Ja tam wolę kiełbasę z sumatry albo na odwrót :)
andrea -a co to za twin towery? i czy "klocek" obok to sub?
