Klub otwarty  ·  270 członków
Paradigm Klub
Klub zwolenników PARADIGM
zyzio
http://www.hometheatershack.com/forums/home-audio-speakers/2301-paradigm-its-all-about-speakers-you-love-listen.html
http://www.avsforum.com/avs-vb/showthread.php?t=724050
http://www.soundstage2.com/lasvegas2007/feature_jeff.html
oraz
Signature v.2 and Statement
March 19, 2007
Editor,
Apropos: “I can tell you that it is refreshing to see a company pushing technology to new heights while remaining grounded in the realm of affordability. I will be listening to, and writing about, the next-to-the-top-of-line Signature S6 v.2 ($4000/pair) soon on Ultra Audio.” Would it be possible to review the S8 v.2 instead? Pretty, pretty please with a cherry on top.
Marc Mickelson reviewed the S8 several years back and was very enthusiastic. It would be great to read how the S8 v.2 compares to the S8 with all the improvements not only to the tweeter. It is impressive too that there is virtually no price increase.
For what it is worth, the frequency response of the S8 is the most linear I have ever seen measured (as shown on SoundStage!). It is more linear than that of the Thiel CS2.4 and the Revel Ultima Studio and the Wilson Sophia (old version).
There was also a review complete with measurements of the Anthem P2 on SoundStage! and it too has amazing measurements with vanishingly low output noise unbalanced (3dB less than the Classé CA-2200) and 4dB less in balanced, less distortion than the Classé and it retails for $2500!
Problem is there is not one (believe it or not) dealer in Southern California who is both a Paradigm Signature dealer and an Anthem Statement dealer (confirmed for me by the rep after contacting all the listed dealers for Paradigm Signature).
So my suggestion is to pair the Anthem Statement P2 stereo amplifier with the Paradigm Signature S8 v.2 and see the results. That would really hit the nail on the head per your comments.
Anyway, thank you so much for having the temerity to write this: “All of this raises the question of whether an affordable product like the new Paradigm Signature v.2 speakers would be considered in the upper echelon of the loudspeaker world by certain folk. I’m sure that to a specific segment of the audiophile market, the answer is ‘no way.’ But this attitude is wrong-headed to me. In the end, you just have to use performance as the final arbiter, not price. As obvious as that seems, it’s just not a universal belief.” I wish that phrase were reprinted in all of the audiophile journals!
Christopher Frank
Thank you for the kind comments and reading our sites so thoroughly. I did not get to hear the original S8, so a comparison to the v.2 is for me is impossible. However, we do have a reviewer on our sister site, www.hometheatersound.com, who not only reviewed the S8 as part of a home-theater system, but bought the review samples. He is scheduled to write about the newest models as soon as they are available, so a direct comparison is only natural. Keep an eye out on that site, or e-mail me in a few months for an update. Personally I can’t wait to get my hands on the S6 v.2!...Jeff Fritz
PARADIGM® REFERENCE SIGNATURE™ SERIES v.2
FAST FACTS about Signature v.2:
NEW! P-Be™ Pure-Beryllium Tweeter Domes.
Although far more expensive, the new
dome material was chosen for its exceptional
mechanical properties: lighter than aluminum,
with unmatched rigidity.
NEW! Co-PAL™ Cobalt-Infused Anodized Pure-
Aluminum Midrange and Bass/Midrange Cones.
The infusion of cobalt brings increased stiffness
and improved damping properties to the lightweight
character of the pure-aluminum cone.
High-Frequency Drivers:
– Internal ARB™ Aperiodic Resonance Breakup fins
– Unique exterior heat dissipation fins
– High-temperature copper-clad aluminum-wire voice
coils wound on Apical™ formers
– Dual super neodymium magnets
– Highly sophisticated motor assemblies
– Die-cast aluminum heatsink chassis
Midrange and Bass/Midrange Drivers:
– ATC™ Asymmetrical Tapered Dual Channel Chamber
ensures optimal internal volume
– Computer-optimized super neodymium magnets
– Advanced Nomex® suspensions; butyl-rubber surrounds
– Anodized solid-aluminum phase plugs
– High-temperature, lightweight aluminum or copper voice
coils wound on ventilated Kapton® or Apical™ formers
– Rigid high-pressure die-cast aluminum heatsink chassis
with proprietary AVS™ cooling
Precision Crossover Networks designed with ideal
frequency- and phase-response characteristics allowing
for minimal crossover networks.
Proprietary IMS/SHOCK-MOUNT™ ‘baffle-less’ driver
fastening system introduced in the original series.
Bass Drivers:
– Massive ceramic/ferrite magnet structures
– Rigid lightweight, long-travel aluminum or copper
voice coils wound on Kapton® or Apical™ formers
– Mineral-filled polypropylene bass cones are designed
to deliver deep, articulate, super-clean bass performance
and play a leading role in Signature’s superb lowfrequency
performance
Hand-Finished Real Wood Cabinets available in
Cherry, Natural Birdseye Maple, and Piano Black.
A tu parametry techniczne Signature S-6 v2
4-driver, 3-way, MagneShield™,
floorstanding
3rd-order electro-acoustic at 1.9 kHz
2nd-order electro-acoustic at 350 Hz
(lower bass driver)
25-mm (1 in) P-Be™ pure-beryllium dome; rear
damping chamber with ARB™ aperiodic resonance
breakup fins and integrated heatsink; dual super
neodymium magnets; ferro-fluid damped / cooled;
die-cast heatsink chassis; IMS / SHOCK-MOUNT™
178-mm (7 in) Co-Pal™ cobalt-infused pure-aluminum
cone; ferro-fluid damped / cooled; ATC™ asymmetric
tapered dual-channel die-cast aluminum chamber;
solid aluminum phase plug; super neodymium
magnets; dual-layer 38-mm (1-1/2 in) rigid, low-mass
voice coil; AVS™ die-cast heatsink chassis;
IMS / SHOCK-MOUNT™
Two 178-mm (7 in) mineral-filled polypropylene cones;
dual-layer 38-mm (1-1/2 in) rigid, low-mass voice coils;
massive ceramic / ferrite magnets; AVS™ die-cast
heatsink chassis; IMS / SHOCKMOUNT™
28 Hz (DIN)
±2 dB from 50 Hz – 45 kHz
±2 dB from 50 Hz – 20 kHz
91 dB / 88 dB
15 – 400 watts
200 watts
Compatible with 8 ohms
47.1 L / 1.66 cu ft
111.0 cm x 21.0 cm x 34.5 cm
43-3/4 in x 8-1/4 in x 13-1/2 in
63.6 kg / 140 lb per pair
Cherry • Natural Birdseye Maple • Piano Black
Bardzo ciekawy watek.
Kiedyś (5-6 lat temu) mialem okazje posłuchac Paradigma,bodajże Monitor 3 v.2 , w zestawieniu ze wzmacniaczem i odtwarzaczem Micromega Minium.
Mimo słabowitego wzmacniacza i kolumn podstawkowych uzyskałem niczym nie skrepowany przekaz w pokoju ok.20m.
Tu moge sie zgodzic z przedmówcami:
Slucha sie tego z przyjemnoscia, bez całego zadecia audiofilskiego,po prostu zmienia sie płyty i gra muzyka!
Moze sie ktos czepiac szczegółów ale myśle ze Paradigm daje poczucie uczestnictwa w muzyce"na zywo".
I po latach musze stwierdzic- własnie o to chodzi....
Przy nastepnych zmianach sprzetu napewno Paradigma wezme pod uwage.
Pozdrawiam członków Klubu:)
chodzi mi po glowie wymiana kolumn. dzieki temu watkowi a zwlaszcza wpisom Snajpera w dziale opinie (paradigm i xindak) mam zamiar powaznie przyjrzec sie paradigmom a konkretnie Studio 40. to co mam teraz gra slicznie, ale czasem brakuje tzw. drive'u. mam tylko obawy czy aluminiowa kopulka i midwoofer nie powoduja odchudzenia i metalicznosci dzwieku? czy nie jest sucho i ostro? bo oprocz powera i dynamiki musi byc muzykalnie no i nie znosze jak cos w uszy kluje...
Mik, 15 Maj 2007, 07:09
Trochę się powtórzę, ale trudno.
To zależy od wzmaka. 40v4 z PMA 1500 AE grały właśnie w sposób, którego nie znosisz - metalicznie, kłująco. Chudo może nie, ale wrażenie grania z metalowej beczki było mocne. Z XA-6950 nic a nic z takiej maniery nie pozostało. Musisz więc dobrze dobrać wzmak i nie będzie żadnych problemów z odchudzeniem i/lub metalicznością.
A mi np. przy studio 20 .v3 zajeżdżało kevlarem :)
Nic nie kłuło, ale dźwięk w porównaniu do klasycznych kolumn na dobrych przetwornikach (np. ss+vifa) nie nazwałbym naturalnym.
Zupełnie inaczej grają np. paradigm titan .v2 - tam dźwięk jak dla mnie jest bardziej ludzki mimo że gorszy :)
Obie kolumny grały z ciepłym i dynamicznym wzmakiem jakim jest Rotel Ra-980BX.
Na pewno przekonałem się, że nie toleruje takiego posmaku kevlaru i niechciałbym więcej takiego dźwięku. Po prostu mnie to drażni i potem zostaje w uszach :)
Być może skala zjawiska jest minimalna, ale w moim przypadku nawet to minimum wyczuwam i mnie to drażni.
Studio .v3 odebrałem jako kolumny łagodne dla słabszych nagrań, głównie dzięki stonowanej górze, która jednocześnie była zdecydowana, twarda i dobitna. Wszelkie sybilanty były zaokrąglone i łatwo wchodziły w ucho.
Titan .v2 z kolei uważam za wybitne w tej cenie do muzyki metalowej. Oddają charaktej tej muzyki, a że nie jestem basolubny to po zatkaniu BR środek jest dobitniejszy i w zupełności wystarczający (główną bolączka jest właśnie wycofany środek)
Jak dla mnie titan .v2 to numer jeden ze wszystkich moich sprzętów w kategorii jakość/cena :)
Panowie wiem że to sprawa gustu, ale patrze na centralny z powyższego zdjęcia, jak na siłę emanuje to ilością śrubek, głośników i kolców zaczepu maskownicy i czuje się przytłoczony (coś moim zdaniem w typie mega porcji pepsi i full bic mac-a ) .
Tylko proszę bez złośliwości napisałem rzecz gustu.
Raczej nie pomysł na wygląd ,tylko konsekwencja w założeniach ,i przestrzeganie zaleceń producenta co do tego jak ma głośnik pracować .Kiedyś taki mądry Pan z Paradigm powiedział że gdyby nie musieli to by maskownice na stałe przymocowali do głośnika ,ale natura ludzka jest taka że każdy lubi wiedzieć co tam tak ładnie połyskuje pod spodem .
O takie coś jest na stronie Polpaka
Zapraszamy do sklepu HI-END CORNER w Poznaniu przy ulicy Szewskiej 18a
na prezentację doskonałego systemu HI-END firm: ANTHEM oraz PARADIGM
Prezentowany sprzęt to:Anthem AVM50, MCA 50,Paradigm STUDIO 20 v.4, STUDIO 60 v.4,
CC-590 v.4 ORAZ SERVO 15 v.2
I dla tego tego Servo 15 v2 warto......przejechać pół kraju .....
kerikawon
>Stare podobno juz są teraz do wyrwania w niezłych cenach .
Sam czekam na S8 v.2, ale mam poważne obawy, bo Paradigm wkracza tu na poziom 30kzł, gdzie jest markowa konkurencja. Np. Focal 1037be może być baaardzo groźny.
Co do "niezłych cen" wersji v.1, to oczywiście nie w PL, jeszcze trochę... Cena, ceną, ale warto wiedzieć, że v.2 ma też nowy przetwornik średniotonowy. Jeśli "środek" Sig v.2 gra lepiej, to trzeba dobrze ważyć niższą cenę v.1
Pozdr.
