Sprzedam Kolumny Klipsch Quartet
cyranka
Czarne drewniane Kolumny estradowe (2 sztuki) Klipsch Quartet Przywiezione z USA.
Wystawione na sprzedaż z powodu przeprowadzki.
Widać ślady użytkowania (jak na zdjęciu).
Można obejrzeć i odsłuchać w Łomiankach pod Warszawą. Sprawdzone w serwisie, nigdy nie naprawiane (oryginalne części).
Więcej informacji ze strony Klipscha:
Detailed Description
The three-way Quartet floorstanding loudspeaker was first introduced in 1989 and manufactured by Klipsch until 1996. While no longer in production, Quartet model loudspeakers are still owned and listened to by Klipsch fans around the world as part of two-channel audio and home theater surround sound systems. To connect with other people who are passionate about audio and interested in Klipsch Classic products, visit one the several Klipsch Classic areas on our open forum bulletin board.
Quartet Specifications
frequency response 38Hz-20kHz±3dB
power handling 100 watts maximum continuous (500 watts peak)
sensitivity 97.5dB @ 1watt/1meter
maximum acoustic output 117.5dB SPL
max acoustic output 117.5dB SPL
nominal impedance 8 ohms
crossover frequency HF 7,000 Hz
LF 650 Hz
tweeter K-76-K 1" (2.54cm) Polymer diaphragm compression driver
high frequency horn 90°x40° Exponential Horn
midrange K-61-K 1.5" (3.81cm) Phenolic diaphragm compression driver
mid frequency horn 90°x40° Tractrix® Horn
woofer K-10-K 10" (25.4cm) Fiber-composite cone active / KD-13 12" (30.48cm) Fiber-composite cone passive
enclosure material Medium density fiberboard construction (MDF)
enclosure type Bass reflex via passive radiator
dimensions 31.2" (79.25cm) x 15.9" (40.39cm) x 12.25" (31.12cm)
weight 52 lbs. (23.6kg)
finishes Walnut Oil, Oak Oil, Oak Clear, Finished Black
built from 1989
built until 1996
Related Products
Academy Academy
Center Channel
©2007 Klipsch Audio Technologies. All rights reserved.
Osoby zainteresowane proszę o email [email protected]
Mamy także subwoofer Klipscha do kompletu, który też chcemy sprzedać.
https://www.audiostereo.pl/topic/36208-sprzedam-kolumny-klipsch-quartet/
