Gdzie w okolicach Łodzi kupić kasete DAT
manioslawa
>manioslawa, 21 Kwi 2009, 07:43
>Ale czy kasety do streamerów dss będe pasowały i grały?
Któreś tak. Niestety nie pamiętam które, ale z tych starszych, to jest DDS-1 lub DDS-2.
Trzeba by wyguglać :-).
Na stronie HP jest coś takiego:
HP DAT - DAT and the Use of Audio
ISSUE:
Using an HP Surestore DAT or HP DAT mechanism to play audio DAT tapes.
SOLUTION:
The Digital Audio Tape (DAT) standard was created in 1987 as a digital recording format offering three hours of digital sound on a single tape. The technology is based on rotating helical-scan heads similar to those used in a video cassette recorder (VCR). The sampling frequencies are 48 kHz and 44.1 kHz. The sound quality can be better than a CD. No data compression is used in recording.
The Digital Data Standard (DDS) is based on DAT and uses similar technology. The cassette design is identical but different tape formulations have been developed. DAT uses two levels of error correction called C1 and C2. DDS adds a third level, called C3, which recovers errors too severe for DAT. The C1 and C2 error corrections operate at a track level, whereas C3 error correction operates over a group of tracks.
Hewlett-Packard DDS drives cannot decode digital audio as they always assume that the data has a group structure with C3 error correction data. There is also no electronics to convert the digital data into an audio signal, and vice versa, for recording.
The use of DAT tapes designed for audio use is not supported in HP Surestore DAT or HP DDS mechanisms. This is because the tape identification holes in the base of the cassette are incorrect.
Co nie znaczy, że w drugą stronę nie pójdzie.
Jestem Europejczykiem.
Tak na oko będzie działała taśma DDS-1, może DDS-2 i DDS-3. Długości taśmy odpowiednio 60/90m, 120 i 125m więc te dwie ostatnie mogą być bardziej podatne na uszkodzenia (są cieńsze).
Będą grały. Używam z powodzeniem takich taśm w przenośnym Sony TCD-D8. Tylko lepiej nie przesadzać z długością, bo może to zaszkodzić silnikowi. Ja pozostaję głównie na taśmie DDS-1 o długości 90 metrów co daje z małym zapasem 180 minut nagrania w trybie SP.
Sprawdzone modele to TDK DC4-90 (ale już nie produkowany) i Imation DDS-90. Pewnie z powodu problemów z dostępnością będę musiał przesiąść się na DDS-2.
