jolida - co z nia?
mateuszek
kiedys byla sobie jedna firma "jolida"'
teraz sprawa sie pokomplikowala
jest jolida "net" i "com"
"net" nie dziala obecnie ale sa glosy ze to byla ta jedyna i oryginalna
produkty "com" maja coraz czesciej napis "made in usa" - czy to oznacza ze producja wrocila do domu?
o co chodzi?
a tak dodtakowo czy ktos mial kontakt z jolida fusion?
https://www.audiostereo.pl/topic/99619-jolida-co-z-nia/
Jolida.com jest oryginalna.
Cytuję z jednego z zachodnich forów (Steve Hoffman Music Forums):
"Who is the real Jolida?
I have been a Jolida dealer for 14 years. I have never bought nor sold any gray market products. All of my equipment comes straight from the manufacturers or their assigned and authorized distributors. In the case of Jolida, Mike Allen is the president and the father of the Jolida brand and concept. He is based in Maryland, USA. Jolida has sold their amps to dealers in the US for perhaps 20 years now. I know that I was in with them from the early days when the first products were out and only a few changes had been made. Jolida has a history of continual improvement and for instance, despite the fact that the model 202A amplifier has not really changed its name or its look, it has been improved significantly internally. It has new transformers, new capacitors, new circuit boards, new volume control, all of this a bit at a time over the years in "running changes" at the factory to keep the product competitive and the best that it can be at its price point. It was originally released as the SJ202A and then became the JD202A as all products took on the JD prefix. The very first product was the SJ302, now the JD302A. When I first started selling the Jolida amps in 1997, there were only integrated amplifiers available and only 4 models (202, 302, 502, 801). Now Jolida produces hybrid integrated amps, CD players, phono stages, power amps, preamps, and DACs. The official USA website is www.Jolida.com .
It was only a year ago, less even I believe that the jolida.net website appeared. This is a chinese website operated by the old factory where Jolida used to have the products made. The products were much more crude there and they had more problems with reliability and ultimately with outright deception and trademark infringement. Gray market items began showing up at puppet websites of unathorized "importers" in NY and other places. These offered the chinese direct versions for a tiny bit less money. There was no warranty of course unless you were to send the product back and forth in the flimsy export boxes to china and trust the guys that even Jolida could not trust to return the product to you. Since those problems, the .net site has started some sort of negative campaign that has given the Jolida brand a duality and a tough go frankly. They seem to feel that they have a right to continue to produce the products even though Jolida Inc had found it necessary to use another manufacturer whom they could trust. Sad but true.
If you want real Jolida products that have been final assembled and tested in Maryland, then you need to go through an authorised USA dealer to do so. Only then will you get USA inspected and tested product, and a USA warranty. The USA warranty allows you to return the product to your dealer or to Jolida in MD for repairs.
-Bill".
https://www.audiostereo.pl/topic/99619-jolida-co-z-nia/#findComment-2674498
Też mi się nie chce wierzyć. Wbrew rozmaitym opiniom, szczególnie tych, którzy z jolkami nie mieli nigdy do czynienia, to są znakomite sprzęty, choć może - były; te stare jolki trzymały jakość. Sam używam CD jolki już b. długo i próbuję zmienić go na droższy, lepszy itp. Robię odsłuchy klocków za 10 tys. i lepiej i jakoś do tej pory żaden nie zdyskwalifikował JD100A. To świetna maszyna, a z dobrymi lampami 12ax7 jeszcze lepsza niż świetna. W każdym razie nie zamienię jej na inną dopóki ta inna nie zagra słyszalnie lepiej.
https://www.audiostereo.pl/topic/99619-jolida-co-z-nia/#findComment-2674708
Ja również darzę Jolidę ogromną sympatią. Sprzęt, który sam używam, czy słuchałem u innych nigdy niczym nie zawiódł, ani jakością dźwięku, ani awaryjnością.
Ostatnio słuchałem JD100A po dziurce od słuchawek i porównywałem ze wzmakiem MF HPA. Ten drugi oczywiście był dużo wydajniejszy, ale na rozsądnych poziomach głośności Jolka go po prostu zdmuchnęła harmonią, nasyceniem, sceną, gładkością.
Ehh, marzy mi się nowy CD na 12ax7, z wejściami na DAC, jeszcze lepszym wzmacniaczem słuchawkowym i kultowym pilotem. Chyba się nie doczekam...
https://www.audiostereo.pl/topic/99619-jolida-co-z-nia/#findComment-2674764
ciekawy zakret historii jolida - lua - shenda...
https://www.audiostereo.pl/topic/99619-jolida-co-z-nia/#findComment-2695799
  • 3 lata później...
Pozwolę sobie odświeżyć ten wątek, gdyż nie widzę dedykowanego, dla klubu Jolida.
Mam pewien problem z moim 302CRC, mianowicie wzmacniacz potrafi się wyłączyć niespodziewanie, wcześniej wydając szum z jednego z kanałow i po chwili słychać z jego okolic delikatnie serię "cyknięć" tak, jakby lampy chłodząc się wydawały odgłos z siebie.
Czy ktokolwiek z właścicieli tego, lub podobnego piecyka spotkał się z czymś podobnym? Pierwsza moja myśl to powolne padanie lamp mocy EL34 od EH, ale nie widać jeszcze widzialnych oznak puszczania pary.
Dzięki za pomoc!
https://www.audiostereo.pl/topic/99619-jolida-co-z-nia/#findComment-3763829
