(Ogłoszenie archiwalne)
Audio Analogue Maestro CD / DAC
sprzet
Autor:  Ra1stlin
Typ ogłoszenia:  sprzedam
Cena:  4100 zł
Województwo łódzkie
Miejscowość Łódź
Opis
Srebrno - czarny stan bardzo dobry. . Wyjścia – zbalansowane elektryczne AES/EBU (XLR), niezbalansowane elektryczne RCA. Dodatkowo wyjście i wejście cyfrowe SPDIF (podłączysz dodatkowe źródło cyfrowe - komputer, streamer).DZiala rowniez jako DAC po podlaczeniu zewnetrznego cyfrowego  zrodla.  Mozliwosc wypuszczenia syglalu do zewnatrznego przetwornika DSP 44/96khz ( i powrot w petli) Pilot w komplecie - nosi juz mocniejsze slady uzytkowania .
A CD player that can also be used as a digital audio processor.
The pickup mechanism adopts the latest version mechanism made by Philips.
This mechanism is isolated by a solid 3 mm thick steel sub-chassis to shut off vibration and other disturbance factors, and is combined with a servo decoding circuit unique to audio analog to reduce data errors and noise.
The digital processor contains 24 bit precision resampling and re-locking circuits and a 96kHz/24bit D/A converter.
In addition to the normal 44.1 kHz, you can listen to the sound upconverted to 96 kHz by selecting the mode. This function is also effective for external digital input. The signal of DVD, MD, PC, etc. can be converted to 96 kHz and output as digital.
Equipped with loop mode function, the signal sent to an external digital processor can be converted back to Mestro CDP for analog conversion.
The re-locking circuit reduces jitter by up to 30 dB.
All stages of the analog circuit are differential amplifier circuits.
The output jacks are equipped with balanced and unbalanced outputs.
Wireless remote control is included.
Type CD Player
Total harmonic distortion factor 0.001% or Less (1 kHz, -10dB)
Frequency characteristic 0 Hz to 48 kHz ± 0.1 dB
Jitter reduction 0.00005%
Noise floor -140dB
Digital input impedance 75 Ω
Output impedance 40 Ω, 110 Ω
Channel separation 100 dB or more
Analog output level 2Vrms
Analog output stage Semiconductor with a matching differential FET input
Digital output level 0.5Vp-p/75 Ω (S/Pdif standard)
Digital input sensitivity 0.5Vp-p/75 Ω (S/Pdif standard)
Digital processing 24-bit real-time resampling
Data buffering, low-noise jitter, and relocking
Analog filter Secondary Butterworth filter
Nominal voltage 100 VAC, 50Hz/60Hz
Maximum Power Consumption 100VA
External dimensions Width 445x Height 135x Depth 360 mm
Weight 20.0kg
Attachment Wireless Remote Control
Dodano:
Regulamin Ogłoszeń
