KEF XQ 20- obiektywnie
Kamil Pawłowski
bardziej mi się podobały tańsze r300 , dzwięk bardziej wypełniony, a przy tym swobodny. z wyglądu xq20 bardziej mi przypadły do gustu ale brzmieniowo nie.
Podzielam te opinie:
"I purchased a pair of XQ20 to a friend of mine without previous auditioning (I trusted on KEF's tradition) and eventually got shoked with their bad quality. I really regreat having purchased those loudspeakers."
"The three-way R300 uses a dedicated bass driver which works from 500Hz downwards - this relieves the UniQ of the stresses involved in reproducing bass frequencies that involve large cone movements, allowing the UniQ to do a far more accurate job, as it is dealing with a smaller frequency bandwidth. The UniQ can now do away with a larger roll surround, in fact, it pretty much does away with the roll surround altogether - something you've probably seen popping up on a lot of speakers in the past 5 years or so. Because the midrange section of the UniQ now hardly moves, it no longer affects the dispersion of the treble frequencies, allowing more accurate and precise imaging, as the HF unit uses the curve of the midrange cone for dispersion. You'll notice the UniQ on the R300 and upwards is very similar to that of KEF's Blade loudspeaker.
Because of the dedicated bass driver of the R300's, the whole frequency range sounds cleaner, and along with a larger cabinet volume, you'll get a far lower bass reach - with music, I swear I've heard my R300's at home reaching frequencies that my subwoofer has in the past, only cleaner! That's some achievement."
