Question about Fuse
I bought a DC Audio 175.4 that didn't come with an integrated fuse. A
Zaloguj się, aby zobaczyć treść (możliwe logowanie za pomocą ) is recommended, though they can be difficult to come by. Because that was the only place I could locate it, I ordered an Absolute brand from Amazon. Is this a reputable brand? Also, would a 125-amp fuse be enough? Both that and 150 amp are readily available, but I'm leery about using the latter. I'll use 0 gauge wire if I add another amp. Are there any brands of fuses that you should avoid?
https://www.audiostereo.pl/topic/158534-question-about-fuse/
While I don't have any experience with car audio fuses, I do have some with electricity. Always use a fuse with correct rating! It's fundamental for your safety. While +-10% difference in rating is probably fine I strongly recommend you to stick with 140A as recommended by manufacturer.
Co to za zaśmiecanie forum? Po pierwsze post w język angielskim. Po drugie kendall zadaje pytanie odnośnie bezpiecznika do tranzystorowego wzmacniacza do samochodu?! No faktycznie  LAMPA, ....ale pod sufitem.
Odezwal sie deputy sheriff i zaraz „pozamiata“
Dla mnie smieci to uwagi jak powyzej
