Nagrody EISA AWARDS 2006/2007 rozdane..
Pixeel
Nagrody EISA AWARDS 2006/2007 przyznane..
» VIDEO PANEL
KATEGORIA // MARKA - MODEL
LCD TV // Sony - KDL-32V2000
HIGH-END LCD TV // Philips - 37PF9731D
PLASMA TV // LG - 42PC1RR
HIGH-END PLASMA TV // Panasonic - VIERA TH-50PV600/PX600E
PROJECTION TV // JVC - HD-70ZR7U
HDV CAMCORDER // Sony - HDR-HC3E
DVD CAMCORDER // Panasonic - VDR-D300
MEDIA CAMCORDER // Sanyo - VPC-HD1
DIGITAL VIDEO RECORDER // LG - RH200MHS
EDITING SOFTWARE // Pinnacle - Studio Plus v. 10 Titanium Edition
HD-COMPONENT // Pioneer - PDP-5000EX
VIDEO INNOVATION // Samsung - LED-‘backlight’
HT DESIGN // Loewe - Individual
VIDEO PROJECTOR // InFocus - IN76
HIGH-END VIDEO PROJECTOR // SONY - VPL-VW100
źródło:
Pixeel
https://www.audiostereo.pl/topic/27634-nagrody-eisa-awards-20062007-rozdane/
Nagród ciąg dlaszy.. :-)
EUROPEAN HT RECEIVER
Yamaha RX-V659
In terms of sound quality and features, the Yamaha RX-V659 offers everything you would demand from a one-box AV receiver in this price range – plus a lot more. It boasts a full 7.1-channel architecture, with decoders for both DTS 96/24 and DTS-ES Discrete 6.1, as well as Dolby Digital EX and Pro Logic IIx. Internal video conversion allows the flexibility the modern home theatre enthusiast needs, while YPAO Automatic System Calibration makes accurate speaker set-up a straightforward operation. Yamaha’s Compressed Music Enhancer gives the user even more opportunities, and useful iPod compatibility is provided via the optional YDS-10 docking station.
EUROPEAN HT SYSTEM
Samsung HT-XQ100
Good design does not always come together with necessary features and impressive sound quality, but the Samsung HT-XQ100 truly encompasses a wide variety of qualities: beautiful design in pearl white or piano black, 500W power output, plus HDMI upscaling of video outputs, up to the 1080i specification. Practically all kinds of audio and video discs can be played and the USB Host feature allows the direct connection of a wide variety of external devices, facilitating its playback of DivX, MPEG4. MP3, WMA and JPEG. The amplification is fully digital and there is also the possibility of complementing the HT-XQ100 with a wireless module, which easily allows a wire-free connection to the additional loudspeakers.
EUROPEAN VIDEO PROJECTOR
InFocus IN76
The InFocus IN76 is not the usual square box that you would want to hide from view, but a very fine design with a futuristic aesthetic, all finished with great precision. But more than that, it is a very high picture quality DLP projector that can bring into your room bright and vivid images up to 720p resolution, and bigger than that possible from any current flat screen technology. Thanks to its very precise factory setup, high-definition video has never been so accessible.
EUROPEAN HT LOUDSPEAKER
KEF KHT3005
With design considerations now a priority for loudspeaker manufacturers, KEF continues to offer striking modern sub/sat loudspeaker systems with its all-new KHT3005 speaker system. This package provides easy living room integration, along with an immersive sound experience. The revised 114mm UniQ drivers in the satellites, using KEF’s patented sealed-suspension technology, provide a clean and powerful sound, while the dedicated HTC3001 center speaker is augmented with two additional mid/bass drivers to support the coaxial main driver, promoting better dialogue reproduction. Supporting these, the versatile HTB2 subwoofer with its 10-inch driver and passive radiator, delivers more controlled bass than you might expect from such a compact and attractive enclosure.
EUROPEAN HD-COMPONENT
Pioneer PDP-5000EX
Pioneer, the plasma display specialist, has made the market’s first 50-inch plasma display with full 1920 x 1080 progressive resolution, with pixels so small that they are almost invisible. A conservatively rated contrast ratio of 3000:1 gives unsurpassed picture quality, even when viewing the screen from extreme angles. With DVI, component and standard video inputs, as well as two HDMI inputs, you get all the connections you need. And you only need to hook a TV tuner and a set of loudspeakers to transform the Pioneer PDP-5000EX into a stunning TV set with impressing screen size of 50 inches.
EUROPEAN HT HIGH-END SYSTEM
NAD Masters Series (M55/M15/M25)
For “high-end” home theater, the combination of the NAD M55 universal disc player, M15 processor and M25 multichannel amplifier is the perfect choice. The M55 player can play CD, DVD-Audio, DVD-Video, SACD and MP3 – and thanks to a Faroudja DCDi chip, it’s able to upscale any video source to 720p or 1080i via HDMI. Its 12-bit/216MHz video converters allow you to experience stunning pictures from component video. The brain in the system, the NAD M15 surround processor with HDMI video switching, able to decode practically every home theater sound formats, and is upgradeable for future compatibility. Completing the set, the M25 is a 7 x 160W power amplifier, delivering rock-solid home cinema experiences with enough power to lift your roof, yet with all the fine detail to satisfy even most demanding audiophile.
EUROPEAN HIGH-END VIDEO PROJECTOR
Sony VPL-VW100
Directly derived from the gorgeous Qualia 004, and even improving on that high-end statement in some aspects, the VPL-VW100 pushes the limits for a true, uncompromised high-definition image, at an incredibly reasonable price. Based on a trio of latest-generation SXRD panels (each with Full HD 1920 x 1080 pixel resolution), the VPL-VW100 combines top-specification all-glass optics from legendary German manufacturer Carl Zeiss with an exclusive variable-iris Xenon lamp, the preferred option for professional applications. Combined with Sony’s advanced proprietary video processing circuits and a sophisticated set-up software system, the VPL-VW100 establishes a new reference in domestic video projection, to create the best home cinema experience available on earth.
Sony VPL-VW100
EUROPEAN HT INNOVATION
LG Flat Wall-Mountable Projector
Sometimes a simple idea can provide the solution to a familiar problem, even if it may need a lot of work to put the idea into a real product. And LG has done it – this innovative projector series is designed to be discreetly and easily hung on the rear wall, behind the seating position. A small and flat box does not disturb the arrangements of the living room, but to reach that goal, the optical system had to be completely redesigned – and all of that is LG’s original concept and engineering. Good picture quality is maintained in this special way of installation, opening the door to video display solutions for a whole new category of customer who would not normally be able to accomodate a projector in the living room.
EUROPEAN HT DESIGN
Loewe Individual
German television specialist Loewe always strives for the perfect combination of design and quality in its products. With the Loewe Individual LCD televisions, using ‘HD-ready’ panels, the customer has a choice of customizable side panels in different colors and materials, including one glitzy limited edition option that includes genuine Swarovski crystal trim. A choice of stands and mounts is also available to match. The accompanying Individual Sound System can be ordered with corresponding color combinations and uses the TV’s integrated speakers for center channel sound reproduction, thus reducing the installation effort for the customer and completing one of the most aesthetically pleasing home theater solutions for the living room available today.
EUROPEAN HIGH-END PLASMA TV
Panasonic VIERA TH-50PV600/PX600E
Compared with its predecessor, the Panasonic TH-50PV600/PX600E is cheaper, weighs less and uses less energy, despite its vast 127cm screen. But it still offers high-contrast pictures with natural colours, intense blacks and brilliant whites, with fine detailing thanks to its V-Real video processing. Two HDMI interfaces are offered, and HDAVI Control allows you to switch on all home cinema components together and play a movie at the touch of a single button. With VIERA you can view still pictures and movies via SD memory card reader, with the possibility to even record TV programmes directly to a card. And its audio performance is impressive too, with deep bass available from its built-in speaker system.
EUROPEAN PROJECTION TV
JVC HD-70ZR7U
With the HD-70ZR7U the engineers of JVC have created a huge but slim projection TV with high contrast ratio, wide viewing angle and uniform brightness over the whole picture area, a combination of features not seen before in this product category. JVC’s unique HD-ILA technology incorporates three 1.4 megapixel reflection chips with an impressive switching time of just 2.5 milliseconds. Advanced technologies like Motion Adaptive Dynamic Picture Management for fine reproduction of dark colours is combined with Smart Picture for the dynamic adjustment of brightness, contrast and sharpness. When added to Digital Image Scaling Technology for the smooth upscaling of conventional video signals, the result is an outstanding viewing experience and the perfect stage for exciting TV events and movies.
EUROPEAN PLASMA TV
LG 42PC1RR
With the fantastic looking 42PC1RR, LG Electronics has introduced a real highlight in the field of plasma TV. Thanks to its use of a thin filter-foil instead of a glass filter screen, the 42PC1RR reproduces astonishingly deep black levels, giving high contrast with a wide viewing angle, and it is almost immune to the distracting effects of reflected light. Besides its outstanding picture quality and connectivity, including two HDMI inputs, the 42PC1RR includes useful one-touch recording on an internal 80GB hard-disk drive. This offers not only timeshifting capability, but also instant review of scenes, up to a couple of hours. And the best news? This versatile, high-performance plasma TV is available at a reasonable price.
EUROPEAN HIGH-END LCD TV
Philips 37PF9731D
To reproduce any high-definition signal without losing quality, the Philips 37PF9731D uses a true 1920 x 1080 pixel LCD panel. Inside lies the most advanced video enhancement circuits, optimised especially for the clearest picture and smoothest motion. In total you will find a Full HD LCD TV that offers impressive picture quality with both Standard and HD signals. The visual experience is enhanced further by Philips’ next-generation of Surround Ambilight illumination. And thanks to the user-friendly guided set-up procedure, everybody can take advantage of the best performance that this sophisticated television can offer.
EUROPEAN LCD TV
Sony KDL-32V2000
Sony’s Bravia concept paved the way for the company’s successful comeback in the LCD market worldwide. And the beautifully designed KDL-32V2000, based on this concept, proves that it’s more than simple marketing, but advanced technology and quality build as well. The Bravia Engine effectively gets rid of unwanted noise, and is able to highlight details in darker parts of the picture. By enlarging the number of colour graduations and multiplying the number of pixels by four times, digital artifacts are also greatly reduced. The visual result is a stunning picture performance at a clearly affordable price level.
