Moc wzmacniacza a amplitunera?
audimaniac
A co można powiedzieć o czymś takim? Warto brać?
• Minimum RMS Output Power
(8 Ω , 20 Hz to 20 kHz, 0.019% THD) ............... 100 W + 100 W
(6 Ω , 20 Hz to 20 kHz, 0.03% THD) ................. 120 W + 120 W
• Dynamic Power (IHF)
(8/6/4/2 Ω) ..................................................... 140/170/220/290 W
• Maximum Output Power [Europe model only]
(1 kHz, 0.7% THD, 4 Ω) .................................................... 160 W
• IEC Output Power [Europe model only]
(1 kHz, 0.019% THD, 8 Ω) ................................................. 115 W
• Power Band Width
(0.03% THD, 50 W, 8 Ω) .....................................10 Hz to 50 kHz
• Damping Factor (SPEAKERS A)
20 Hz to 20 kHz, 8 Ω ..................................................240 or more
• Maximum Output Power (EIAJ)
[Asia and General models only]
(1 kHz, 10% THD, 8/6 Ω) ........................................... 145/170 W
• Maximum Input Signal
PHONO (1 kHz, 0.019% THD) ............................ 70 mV or more
CD, etc. (1 kHz, 0.019% THD) ............................... 2.2 V or more
• Frequency Response
CD, etc. (20 Hz to 20 kHz) .......................................... 0 ± 0.5 dB
CD DIRECT AMP ON (10 Hz to 100 kHz) ................ 0 ± 1.0 dB
• RIAA Equalization Deviation
PHONO ........................................................................... ± 0.5 dB
• Total Harmonic Distortion
PHONO to OUT (REC)
(20 Hz to 20 kHz, 3 V) .......................................... 0.008% or less
CD, etc. to SP OUT
(20 Hz to 20 kHz, 50 W, 8 Ω) ............................... 0.012% or less
• Signal to Noise Ratio (IHF-A Network)
PHONO (5 mV input shorted) ................................ 87 dB or more
CD DIRECT AMP (200 mV input shorted) ......... 110 dB or more
• Residual Noise (IHF-A Network)
CD DIRECT AMP ON ....................................................... 30 μV
PURE DIRECT ON .......................................................... 110 μV
• Gain Tracking Error (0 to –60 dB) ................................ 2 dB or less
• Input Sensitivity/Input Impedance
PHONO .................................................................. 3.0 mV/47 kΩ
CD, etc. ................................................................. 200 mV/47 kΩ
MAIN IN........................................................................ 1 V/30 kΩ
• Output Level/Output Impedance
OUT (REC) ................................................ 200 mV/1.2 kΩ or less
PRE OUT ...................................................................... 1 V/1.2 kΩ
• Headphone Output/Impedance
(Input 1 kHz, 200 mV, 8 Ω , 0.015% THD)
CD, etc. ................................................................... 0.47 V/470 Ω
• Channel Separation
CD, etc. (5.1 kΩ input shorted, 1/10 kHz) ........ 65/50 dB or more
• Tone Control Characteristics
BASS
Boost/Cut (20 Hz) .......................................................... ±10 dB
Turnover Frequency ........................................................ 350 Hz
TREBLE
Boost/Cut (20 kHz) ........................................................ ±10 dB
Turnover Frequency ....................................................... 3.5 kHz
• Continuous Loudness Control
Attenuation (1 kHz) ........................................................... –30 dB
• Power Consumption
[u.S.A. and Canada models] ................................ 260 W, 360 VA
[Other models] .................................................................... 260 W
• Standby Power Consumption ................................................. 0.1 W
• Maximum Power Consumption [General model only]
(6 Ω , 1 kHz, 10% THD) .................................................... 650 W
• Weight .................................................................... 10.9 kg (24 lbs.)
Czesc wszystkim, to moj pierwszy wpis
AVR-4306 Measurements and Analysis
As is typical, we measured CONTINUOUS unclipped power in these tests. Estimated THD at these measurements was between 0.5 - 1% (max) and tests were done with an 8-ohm test load for one and two-channels as well as a 1 channel test with a 4-ohm load. The results were above average to say the least. This 130wpc amplifier scored well above that value (around an average of 150W) when driving 2 channels into an 8-ohm test load. When pushing a 4-ohm load the power jumped to around 240watts. One thing that became abundantly clear (and showed through in our listening tests) was that the AVR-4306 has a healthy power reserve to be used wherever it was needed during multi-channel playback.
The damping factor of the receiver hovered for the most part around 220 and went as high as 550 around 20Hz and above 5kHz. Anything above 50 throughout the audio band is excellent. This is simply a strength of this product and is consistent with what we have come to expect from mid-fi and up Denon receivers.
Mam tego denona i radzi sobie niezle, na moje ucho lepiej niz 200 watowa integra Lyngsdorf Audio. Gdzies necie znalazlem opis ze radzi sobie takze z kolumnami ktorych impedancja spada do 1 ohma. W testach przy pieciu kanalach i 8 ohmach daje prawie 90 W na kanal.
Amplituner Onkyo 805 ma takze zmierzonych 100 W ciaglej mocy na kanal przy 5 granych.
Niektore ampli daja rade :-).
Nie mam polskich znakow - sorry.
Andrzej
Witam!
Sprawa wygląda tak. Nie każdy wzmacniacz gra mocą jaką podaje
producent.
Przykładowa sytuacja:
Jest taki sobie wzmacniacz XXX. Producent podał że ma 2x 150W.
Natomiast pobór mocy z sieci to jest zaledwie 180W.????
Konsternacja o co chodzi!!
Jak to na prawdę wygląda. Z reguły pobór mocy z sieci 180W jest teraz
dzielone- tylko jak?
od 30 do 40W jest to spalanie urządzenia podczas pracy (włącznie ze
wszystkimi stratami), czyli do podziału na rzeczywistą moc napędzającą
kolumny jest powiedzmy tylko 140W??!
Teraz te 140W dzielimy na 2 i wychodzi nam że wzmacniacz zapodaje
rzeczywistej mocy na kolumnę w sinusie tylko 75W.
Dalej wnikając w szczegóły ustalamy z jakimi kolumnami może
współpracować
dany wzmacniacz. Jeżeli z 4 OHM - to ten wspomniany wzmacniacz zagra sinus
75W ale z kolumnami o impedancji 4 ohm. Jeżeli podłączymy kolumny o
impedancji 8 ohm to mamy połowę mocy dysponowanej ze wzmacniacza czyli
około
40W mocy sinusoidalnej na jedną kolumnę.
"Lampa nie umiera nigdy"
Posiadalem amplituner Yamaha RX-V550 tam tez podane bylo ze ma na kazdy z 6 kanalow po 90 Watt w rms, a po zastosowaniu tego wzoru tak naprawde na kanal wychodzilo 26,6 Watt przy glosnikach 8 Ohmowych :( przykre ale prawdziwe.
Gdyz pozniej porownywalem i obliczalem takze swoj wzmak Marantz PM 7001 to rzeczywiscie wychodzilo ze jest w tych obliczeniach duzo prawdy, co potwierdzilo sie w odsluchu pozniejszym.
Nie Ja ten wzor stworzylem (Sam tez kiedys o tym sie dowiedzialem od czlowieka co studiowal w tych kierunkach i zna realia) zdziwilem sie ze producenci glownie amplitunerow robia z Nas frajerow) :///////
Tak po krotce obliczenia te napewno niemaja potwierdzenia w najnowszych produkcjach czyli wzmacniaczach cyfrowych gdyz tam calkowicie inaczej konstrukcyjnie to dziala i inaczej sie moc mierzy ale to juz inna historia ktorej niebede Wam zblizal gdyz tez niejestem ekspertem tylko powoluje sie na to co sam dostrzeglem (matematyka + odlsuch) i wypowiedzi osob w temacie obeznanych.
Ps. Chodzi o wzmaki i amplitunery na tranzystorach co do lamp to niewiem czy tez tak mozna mierzyc i jak to sie ma do rzeczywistosci! Pozdrawiam :)
Arek__45, 18 Gru 2007, 16:22
>.....tak,powyzej, to mozna wytlumaczyc budowe cepa .....we wzmacniaczach + kolumny wyglada to
>zupelnie inaczej....
Kolega Arek_45 ma rację. Wzmacniacze są nieco bardziej skomplikowane. To ile pobierają prądu z sieci a ile oddają zależy często od różnych elementów. Różne wzmacniacze mają różne straty energii - najwięcej jest chyba tracone w postaci ciepła. Poza tym moc wzmacniacza zależy od obciążenia (impedancji kolumn). Straty pobieranej energii są też związane z tym w jakiej klasie dany wzmacniacz pracuje. Niemal wszystko zatem zależy od budowy wzmacniacza.
Dla kolegi Patryka - w wielkim skrócie o klasach wzmacniaczy:
A ja mam inne laickie pytanie:
Jak to jest ze skalą ujemną decybeli we wzmacniaczach / amplitunerach ? Jak ją prawidłowo odczytywać, jak odnieść do watów, do głośności ?
Dzięki z góry.
