Oppo BDP-83
Kaka
Jest nowe firmware do BDP-83 - BDP83-54-0130B.
1. Certain SACD discs with many short tracks or with a long track following several short tracks can cause the player to freeze during playback. This version fixes the issue. The crackles and pops that happened occasionally between tracks on some discs are also eliminated.
2. Fix for the issue of incorrect video size when playing some Blu-ray discs, such as "Patton", "Time Bandits" and "Date Night".
3. A small number of Blu-ray discs with Dolby TrueHD audio exhibit a momentary audio drop-out issue if the player is connected to an A/V receiver via HDMI and bitstream is selected as the HDMI Audio format. This version fixes the issue.
4. Support for LPCM audio streaming over home network is restored. The previous firmware did not carry this feature over from older versions. Please note that home network streaming is an experimental feature. You will need a computer running UPnP or DLNA streaming server software that can support transcoding to LPCM in order to use this feature.
5. The previous firmware version displays the time counter slightly too fast when playing SACD. This version fixes the issue.
6. Other general disc and media file compatibility improvement based on recent and upcoming Blu-ray releases as well as user-submitted samples.
... żeby był jakiś porządek i sens tego wszystkiego nieznanego i tajemniczego, stworzył człowiek bogów, osadził ich w miejscach niedostępnych i ich mocom oddał swój los ...
https://www.audiostereo.pl/topic/61839-oppo-bdp-83/page/2/#findComment-2121191
A no jest i nic po za tym. Niemal żadnych różnic w porównaniu do tego z sierpnia a problemy jakie były takie są nadal.
A no wiem, bo mi się po DLNA np dalej syf robi i nie czyta niektórych formatów.
Na razie tego mi najbardziej brakuje ...
https://www.audiostereo.pl/topic/61839-oppo-bdp-83/page/2/#findComment-2123615
Mam problem z plikami MKV muxingowanych przez program "mkvmerge_GUI" gdy chcę dodać polskie napisy do filmu MKV to w Oppo nie mam obrazu ani dźwięku ale licznik idzie. Czy wiecie może jak z tym problemem sobie poradzić albo jakiego programu użyć do wstawienia napisów do filmu by Oppo go odtwarzał?
Czy poradziliście sobie z polską czcionką w divx?
https://www.audiostereo.pl/topic/61839-oppo-bdp-83/page/2/#findComment-2129132
Zrób to za pomocą mmg.exe
Dodajesz pliki *.srt?
Po za tym zastosuj mkvtoolnix w wersji 3.20 (code "Beginnings"), nowsze wersje przy odtwarzaniu w Oppo wyczyniają cuda z mkv (przynajmniej u mnie)
Wrzuć avi'ka do mkv wraz z plikiem napisów
https://www.audiostereo.pl/topic/61839-oppo-bdp-83/page/2/#findComment-2129229
