ortofon VMC Exklusive
lian
Czy ktoś słyszał o tej wkładce? Na stronie ortofona nic o niej nie ma. W tym wątku też tego nie rozstrzygnięto:
Bedę ją miał, więc wypada wiedzieć
VMS oczywiscie, przepraszam
https://www.audiostereo.pl/topic/95247-ortofon-vmc-exklusive/
Ortofon brochure and reprint rp October 1981
VMS exclusive special
This pickup has the advantages of the VMS principle: Low moving mass, high channel isolation, low distortion and excellent spatial sound combined with robust and versatile Elnsatzmöglichkeiten.
The low needle flexibility makes it particularly suitable for heavy and medium weight tonearms.
Magnetic pickups VMS exclusive special
Weight of 5 g
Cut of the diamond Elliptical
Effective mass of 0.65 mg Diamontspitze
Hz frequency range .20-20.000
Sensitivity at 1OOO Hz 5 cm / sec) 5 mV
Crosstalk 25 dB at 1000 Hz
Difference in transmission measure bei1000 Hz 2dB
Stylus compliance static, vertical 20 um / mN
Needle flexibility, horizontal, dynamic (1O Hz) 15 um / mN
Recommended Auflegekraft mN/2.0 20 g
Auflagekroft from-g to 17-23 mN/1.7-2.3
Abtastfählgkeit at 315 Hz laterally 65 uM
Vertical tracking angle 20 degrees
DC resistance. 800 ohms
FIM distortion of 1% (20Mn)
Inductance 600 mH
Recommended load resistance 47 kOhm
Recommended load capacitance 400 pF
Replacement Diamond D Exclusive Special
źródło
audiokarma.org
