Do specjalistów !
zyzio
Logfile of HijackThis v1.97.7
Scan saved at 19:01:36, on 2004-10-18
Platform: Windows XP Dodatek SP. 1 (WinNT 5.01.2600)
MSIE: Internet Explorer v6.00 SP1 (6.00.2800.1106)
Running processes:
C:WINDOWSSystem32smss.exe
C:WINDOWSsystem32winlogon.exe
C:WINDOWSsystem32services.exe
C:WINDOWSsystem32lsass.exe
C:WINDOWSsystem32svchost.exe
C:WINDOWSSystem32svchost.exe
C:Program FilesCommon FilesSymantec SharedccEvtMgr.exe
C:Program FilesNorton Internet SecurityNISUM.EXE
C:WINDOWSExplorer.EXE
C:WINDOWSsystem32spoolsv.exe
C:WINDOWSSystem32RunDll32.exe
C:Program FilesCommon FilesSymantec SharedccApp.exe
C:WINDOWSSystem32RUNDLL32.EXE
C:Program FilesMessengermsmsgs.exe
C:Program FilesGadu-Gadugg.exe
C:Program FilesNorton Internet SecurityccPxySvc.exe
C:Program FilesCommon FilesMicrosoft SharedVS7Debugmdm.exe
C:Program FilesNorton AntiVirusnavapsvc.exe
C:Program FilesNorton SystemWorksNorton UtilitiesNPROTECT.EXE
C:WINDOWSSystem32nvsvc32.exe
C:PROGRA~1NORTON~3SPEEDD~1nopdb.exe
D:ToolsHijackThis.exe
R0 - HKCUSoftwareMicrosoftInternet ExplorerMain,Start Page =
O2 - BHO: NAV Helper - {BDF3E430-B101-42AD-A544-FADC6B084872} - C:Program FilesNorton AntiVirusNavShExt.dll
O3 - Toolbar: &Radio - {8E718888-423F-11D2-876E-00A0C9082467} - C:WINDOWSSystem32msdxm.ocx
O3 - Toolbar: Norton AntiVirus - {42CDD1BF-3FFB-4238-8AD1-7859DF00B1D6} - C:Program FilesNorton AntiVirusNavShExt.dll
O4 - HKLM..Run: [Cmaudio] RunDll32 cmicnfg.cpl,CMICtrlWnd
O4 - HKLM..Run: [NvCplDaemon] RUNDLL32.EXE C:WINDOWSSystem32NvCpl.dll,NvStartup
O4 - HKLM..Run: [ccApp] C:Program FilesCommon FilesSymantec SharedccApp.exe
O4 - HKLM..Run: [ccRegVfy] C:Program FilesCommon FilesSymantec SharedccRegVfy.exe
O4 - HKCU..Run: [NvMediaCenter] RUNDLL32.EXE C:WINDOWSSystem32NVMCTRAY.DLL,NvTaskbarInit
O4 - HKCU..Run: [MSMSGS] "C:Program FilesMessengermsmsgs.exe" /background
O4 - HKCU..Run: [Gadu-Gadu] "C:Program FilesGadu-Gadugg.exe" /tray
O4 - Global Startup: Microsoft Office.lnk = C:Program FilesMicrosoft OfficeOffice10OSA.EXE
O8 - Extra context menu item: E&ksport do programu Microsoft Excel - res://C:PROGRA~1MICROS~2Office10EXCEL.EXE/3000
O9 - Extra button: Related (HKLM)
O9 - Extra 'Tools' menuitem: Show &Related Links (HKLM)
O12 - Plugin for .spop: C:Program FilesInternet ExplorerPluginsNPDocBox.dll
Tak wygląda nowy log.
masz jeszcze tego smiecia?
zastanawiam sie tylko nad ostatnim wpisem, jak nie uzywasz IE to plugin do niego tez nie jest potrzebny
extra button i extra tools jak nie uzywasz to tez mozesz wywalic
ten smiec instalowal sie za kazdym uruchomieniem kompa
O4 - HKLM..Run: [nwiz] nwiz.exe /install
i pobieral pliki instalacyjne z caba
O16 - DPF: {22222222-2222-2222-2222-222222222222} - file://c: x.cab
bycmoze otwieral jakis port i powiadamial ze jest aktywny (wpisy z Nortona)
Dane: Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1)
Dalej jest :-(
Scan saved at 17:14:15, on 2004-10-19
Running processes:
C:Program FilesInternet ExplorerIEXPLORE.EXE
O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} (Shockwave Flash Object) -
Nowy log - czemu nie został usunięty extra tools i extra button nie wiem...
Zainstaluj jeszcze Spybot - Search & Destroy po instalacji zrob update i skanuj
program jest tu ->
jak nic nie znajdzie to trzeba skanowac rejestr moze wyszukaj ciąg zanków z "nr IP z ktorym sie laczy" albo słowo "sexfiles"
na koniec coś ekstremalnie rozpaczliwego mozna szukac w plikach na dysku z opcją słowa zawierające ciąg "sexfiles"
po tych operacjach napisz czy cos znalazles
Do nowego loga
wywal:
jest tez kilka wpisów podobnych do Nortona ale nie jestem przekonany do nich na 100%
odinstaluj Nortona i przyslij loga zobaczymy co zostało
194.237.110.172 to jest to IP, łaczy się też z innym IP 194.237.110 i ostatnie cyfry się zmieniają, złośliwe paskudztwo, różne przeglądarki same się wczytują co jakiś czas....
Spy boot wykrył przekierowanie do Alexy, w raportach nadal jest to gówno, ale tam pisało, że tak może być, a i tak jest wszystko ok, zobaczymy czy będzie się łączył z tymi IP, bo prawdę mówiąc mam już dość ;-(
Ale naprawdę bardzo, bardzo dziękuję za wszelką pomoc, tylu odpowiedzi w tak krótkim czasie nie dostałbym na żadnym innym forum. W szczególności pragnę podziękować guzi
Niech spyware i adeware trzyma się od Was z daleka !
C:Program FilesInternet ExplorerIEXPLORE.EXE - tego nie można wywalić.
To cholerstwo jest chyba nieusuwalne....
zyzio,
jak sie laczysz z Internetem? wdzwaniasz sie? jezeli tak to minuta połaczenia wynosi $1,99 !!!
opis dzialania SexFiles.nu
ten sofcik usuwa SexFiles.nu
Poza tym mi się ładują przeglądarki w ogóle z seksem nie związane - ostatnio chodziło o gry komputerowe - IP kompletnie inny niż poprzednie, to jakiś nowy robal pewnie....
Ruch internetowy:
Data i czas: 2004-10-20 20:02:33
Użytkownik:
URL:
Ruch internetowy:
Data i czas: 2004-10-20 20:02:27
Użytkownik:
URL:
Ruch internetowy:
Użytkownik:
URL:
Ruch internetowy:
Data i czas: 2004-10-20 20:02:26
Użytkownik:
URL:
Ruch internetowy:
Data i czas: 2004-10-20 20:02:14
Użytkownik:
URL:
Ruch internetowy:
Data i czas: 2004-10-20 20:02:09
Użytkownik:
URL:
Ruch internetowy:
Data i czas: 2004-10-20 20:00:45
Użytkownik:
URL:
No jak to kurna jest możliwe ??? Przecież to zostało usunięte, jakieś pomysły ??
Będę wdzięczny za pomoc.
Zaloguj się, aby zobaczyć treść (możliwe logowanie za pomocą ) - a co to jest ?
