Elektor-Elektuur The Audio Collection
ChUmI
Panie i Panowie :) wreszcie wpadl mi w rece CD-ROM "The Audio Collection" wydany przez Elektora :) wiec teraz, jezeli sa jacys zainteresowani kopia, wypada sie podzielic :) Niestety nie mam nagrywarki w domu :( jedynie w pracy :) wiec moge zaproponowac cos takiego ... zeskanuje okladke i nagram razem z zawartoscia na plyte CD a potem wysle do kogos kto bedzie w stanie zrobic kopie dla innych ... co wy na to? Dla zainteresowanych podaje zawartosc plyty, wszystkie artykuly sa w pdf'ach po angielsku, niemiecku, francuzku i holendersku ;) dla kazdego cos milego:
Amplifiers:
battery-operated AF pre-amplifier - 1
battery-operated AF pre-amplifier - 2
compact power amplifier
headphone amplifier
HEXFET amplifier upgrade
miniature power amplifier
PA300 power amplifier
single-chip AF power amplifier
single-chip 50 W AF amplifier
supply board for output amplifiers
Titan 2000 - 1
Titan 2000 - 2
Titan 2000 - 3
Titan 2000 - 4
Titan 2000 - bridging
1-watt BTL audio amplifier
30 W AF amplifier for cars
50 W a.f. amplifier
100-watt single-IC amplifier
Digital audio:
AES/EBU-to-S/PDIF converter
clipping indicator
copybit eliminator revisited
copybit inverter
digital-audio-input selector
opto-to-coaxial audio converter
sampling rate converter
simple copybit killer
S/PDIF test generator
S/PDIF-to-AES/EBU converter
splitter for S/PDIF coax/optical output
Loudspeakers:
a.f. power limiter
loudspeaker protector
simple two-way loudspeaker
surround speakers
surround-sound subwoofer - 1
surround-sound subwoofer - 2
surround-sound subwoofer - 3
the wall box
Test and measurement:
digital VU meter - 1
digital VU meter - 2
passive VU meter
portable sound-pressure meter
sound pressure meter
Miscellaneous:
accurate bass tone control
active potentiometer
active power buffer
AF input selection
AF level matching
auto volume control
AVC for PCs
balanced microphone preamplifier
balanced/unbalanced converters for audio signals
bass extension for surround sound
car booster adaptor
d.c. detector
delay line
digital potentiometer
DIY: from vinyl to compact disk
fan control
front/rear car radio fader
infra-red-controlled noiseless volume control
Insulated Gate Bipolar Transistors (IGBTs)
mains on delay circuit
parametric equalizer
pick-up input becomes line input
playback amplifier for cassette deck
silent volume control
stereo microphone amplifier
stereo microphone input adaptor for PC
surround sound indicator
surround sound processor
symmetrical supply in cars
ten-band equalizer
treble tone control
ultra low-noise MC preamplifier
mP-controlled mixer board - 1
mP-controlled mixer board - 2
up/down drive for tone control
20-bit A-D converter
... sporo tego :) a tak wyglada plytka:
https://www.audiostereo.pl/topic/22929-elektor-elektuur-the-audio-collection/
napisz moze ile to zajmuje miejsca... moze by to poprostu umiescic na jakims serwerze do sciagniecia.
z tego co napisales domyslam sie ze sa tam rozne wersje jezykowe.... zapewne wystarczylaby angielska
Po pierwsze wszystkich witam!
Forum czytam od kilku miesięcy, jednak zarejestrowałem się dopiero teraz.
Dla wszystkich chętnych cała kolekcja Elektora po angielsku dostępna tutaj:
Spis znajduje się w pliku content.pdf:
Zaloguj się, aby zobaczyć treść (możliwe logowanie za pomocą ) &file=content.pdf
Zapraszam
Ja mam płytkę z tymi artykułami w kilku wersjach językowych ( bez polskiej) zassałem z E-mulka cały obraz płyty.
W angielskim wszystko chodzi.
poza tym to jestem rozczarowany
pojedyńczy artykuły mogę wyślać na e-mail
Witam !
Panowie, a ma któryś z was w pedeefach rocznik '94 Elektora ?
Tam była ta hi-endowa końcówka mocy, mógłbym zrobić pcb, ale do tego potrzebny jest mi rysunek wektorowy ścieżek - właśnie tak zrobiłem płytki do "Kompaktowego wzmacniacza audio na IGBT ".
Przy okazji mam też roczniki EE do '03 bodajże w pdf-ach.
Ale nie mam '94 :)
Pozdr.
ex-stożek
O tą końcówke Ci chodzi, na płycie elektora EE'94 niema obrazków samch płytek tego wzmacniacza.
Ps. jeśli ktoś potrzebuje coś z płytek z EE'94 -2003, proszę na maila może się znajdzie.
A czy w tych roczkikach, które posiadacie są jakieś koncówki mocy?
Interesuje mnie końcówka która będzie tylko wzmacniać sygnał, wzmocni wszystko bez mrugnięcia i nie będzie jej przeszkadzała niska impedancja kolumn.
Wiem - brzmi to zbyt idealnie, ale taki "przezroczysty" i niewymagający piecyk, minimum 50W - to jest to czego mi trzeba.
Zbudować (najlepiej monobloki, albo power-amp symetryczny) i spokojnie wziąć się za resztę toru.
Znajdzie się coś?
ex-stożek>
Wspomniana przez Ciebie końcówka to rzeczywiście taki hi-end>
Może samodzielnie zaprojektować płytkę? Albo poprosić jakiegoś speca z forum. Veteran, DeTom..
  • 2 lata później...
Czy można jeszcze skądś zassać zawartość tej płyty ?, ew. i następne roczniki ?
Poszukuję (na razie z ciekawości) wzór PCB do Giesbertsowskiego kompakta na IGBT.
Ale i inne konstrukcje fajnie było by przejrzeć.
