7 Pin Connector with a Loose Fit
I tried two different
Zaloguj się, aby zobaczyć treść (możliwe logowanie za pomocą ) , and when plugged in, they both move about 1/8" side to side. This movement is timed to correspond with the intermittent blinking of my running lights. Is it possible that I have a faulty receptacle, or is there a solution?
Thanks.
https://www.audiostereo.pl/topic/157619-7-pin-connector-with-a-loose-fit/
