Najpiękniejsze tranzystorowce świata :)
zyzio
Marantz ma-9s1
Chociaz rownie dobrze moglem to wkleic tu:
Czy Plinius jest ładny?
Model 9200
Ponoć świetny preamp, PS Audio - GCP 200
Najnowsze Pioneer i Sony.
Luxman B-1000f podobno nowość z 2006 roku
wklejam mojego ulubionego STAX'a którego niestety znam tylko od strony technicznej, chyba najbardziej rozbudowany schemat, na ten wzmacniacz skladaja sie praktycznie 3 wzmacniacze (na kanał)
Gość discomaniac71
Komplet Luxmana z 1999 roku: preamp C 10mkII i monobloki B10mkII. Koszt calosci 2,8mln jenow. Bagatelka... Za to mozna kupic bardzo dobre auto... Jest to okolo 46.000 DM (wg moich obliczen).
Gość discomaniac71
Troche parametrow:
Type Monaural power amplifier
Continual effective output 8Ω: 500W
4Ω: 1000W
Input sensitivity 1V/500W (8Ω)
Input impedance Coaxial: 50kΩ
Balance: 100kΩ
Profit (gain) 36dB
All the harmonic distortion factors 0.04% (20Hz~20kHz)
Frequency characteristic 20Hz~20000Hz, +0 -0.1dB
10Hz~100000Hz, +0 -1.0dB
SN ratio (IHF-A) 115dB
Attachment Coaxial-Balance input [atsuteneta]
Line phase sensor
Power supply voltage AC100V and 50Hz/60Hz
Electric power consumption 750W (the stipulation due to electric supplies control method)
External size Width 467× height 233× depth 482mm
Weight 43.5kg
Type Control amplifier
Input sensitivity/input impedance Tuner: 150mV/50kΩ
CD: 150mV/50kΩ
Line1~4: 150mV/50kΩ
Output/output impedance [koakishiyaru]: Rating 1V/300Ω, maximum 7.5V
Balance: Rating 1V/600Ω, maximum 7.5V
All the harmonic distortion factors 0.005% or less (rating)
SIGNAL-TO-NOISE RATIO ratio Above 120dB
Tone control Treble: Turn over 3kHz maximum ±8dB (10kHz ±6dB)
Bass: Turn over 300Hz maximum ±8dB (100kHz ±6dB)
Attachment function Tape dubbing: 2 systems (1→2 and 2→1)
REC OFF
Straight switch
Output mode Change-over Switch
Remote (POWER) output
Line phase sensor
Output phase Change-over Switch
Electric power consumption 38W (the stipulation due to electric supplies control method)
External size Width 467× height 187× depth 475mm
Weight 23.0kg
może nie jest to najskromniej ale inni tez wklejali maja aktualna konstrukcja w budowie 2X250 wat
=>adamhiend, 20 Sty 2007, 21:45
na 12 stronie
Zaloguj się, aby zobaczyć treść (możliwe logowanie za pomocą ) jest schemat niech się fachowcy wypowiedzą co to warte
Wagowo jest podobnie luxman 64 kg cenowo Stax dużo dużo tańszy 17800DM mocowo dużo mocniejszy luxman przy 8 omach "tylko" 250Wat no i pasmo "nieco zawężone" bo tylko do150kHz jedyne co mi się udało poszukać że Staxa nikt się nie pozbywa-może się mylę ?
Poniżej dane Staxa
Circuit Construction
- Monaural Class-A
Non-NFB Final Stage
Dynamic Power Supply
Balanced Amplification with DC Servo
Frequency Response
- 0.8 Hz - 220kHz
10W output with DC input
Input Impedance
- RCA: 32k Ohm
Balanced: 64k Ohm
Signal to Noise 116dB (IHF-A weighted)
Input Sensitivity
- Low: 2 V RMS for full output
High: 1 V RMS for full output
Gain
- Low: 30dB
High: 36dB
Maximum Output Power 600 Watts at 8 Ohms
Total Harmonic Distortion
- < .1%, .03 watt to 600 watt
at 8 Ohms, 20Hz to 20kHz
Power Consumption 390 Watts Without Signal
Input Power
- 100, 117 or 220 VAC
User Adjustable
Dimensions
- Height 227 mm
Width 430 mm
Depth 546 mm
Weight 47 kg
Rafaell
ta cena to jest od 1szt czyli trzeba wymnozyc przez 2 czyli okolo 35.000DM, jak to Stax wypuscil bardzo krótką serię i po tym modelu wycofał sie z produkcji wzmacniaczy, wczesniej wypuscił taka "spawarke" z wyglądu na kółkach, też monobloki czysta klasa A na mosfetach cena coś koło 70.000DM poszukam może znajdę i wkleję, tutaj to wypuścili dosłownie pare sztuk, nawet w katalogu nie było
A mi podoba się to co mam - zwłaszcza w porównaniu do wcześniej posiadanego amplitunera:)
Oczywiście jest wiele innych pięknych wzmaków w tym temacie i chciałbym je mieć, tylko wiecie co...
A ta zieleń napisów Creeka na tle czarnej blachy jest dla mnie jakimś uosobieniem złotych lat stereo (czytaj '90).
Bluesound Node / Synthesis Roma 96DC+ / B&W 706 S3
Dorzucam jeszcze foto pary A52SE - ciekawe ile osób ma w Polsce ten piecyk, pewnie da się policzyć na palcach jednej ręki.
najdroższa spawarka na świecie, ciekawe ilu szczęsliwych posiadaczy ma to cudo:
Audio Research VT 130
>adamhiend
Pomijając brzmienie i parametry - wstawił byś coś takiego do swojego salonu?
Przecież te kółka są pokraczne.
Air Tight ATC 3
tomek11
jeżeli gra tak jak piszą, to oczywiście wstawił bym, ale wcześniej pomalował w barwy maskujące, cikawe kto im ten dezajn wymyślił? chyba chcieli zaoszczędzić na projekcie i wykonanie obudowy zlecili swojemu spawaczowi, własciwie w konkursie na najpaskudniejszy wzmacniacz ma 1 miejsce (a może była to wersja robocza i nie weszła do produkcji, no bo niebyło jej w katalogu)
