Jakie głośniki do Outlaw Audio RR2150?
NEWT
Witam wszystkich. Właśnie kupiłem Outlaw Audio RR2150. Opis zamieszczam poniżej. Jakie głośniki kupić do tego sprzętu?? Ze względu na mój brak doświadczenia w temacie (to mój pierwszy poważny zakup) będę wdzięczny za każdą poradę. Pozdrawiam
Audio Section
• Continuous Average Power:
100 watts per channel, 20 Hz - 20kHz,<0.03% THD, both channels driven into 8 ohms
160 watts per channel, 20 Hz - 20kHz,<0.03% THD, both channels driven into 4 ohms
• Input Sensitivity/Impedance:
High Level: 200mV/47kohms
MM Phono: 3.3mV/47kohms
MC Phono: 0.6mV/47kohms
•S/N Ratio: 96dB
•Bass Management:
Adjustable 60/80/100/Bypass
High-Pass Slope 12 dB/octave (2nd order)
Low-Pass Slope 12 dB/octave (2nd order)
•Tone Control:
Bass Center Frequency/Range 50Hz ± 6.5dB
Treble Center Frequency/Range 1KHz ± 6.5db
FM Tuner Section
•Frequency Range: 87.5-108MHz
•Usable Sensitivity IHF: 12dBf
•Signal-to-Noise Ratio:
Mono/Stereo 75/70dB
•Stereo Distortion: 0.24%
•Stereo Separation: 37dB @ 19kHz
•Selectivity: +/-10kHz, 70dB
AM Tuner Section
•Frequency Range: 530-1710kHz
•Usable Sensitivity: 500uV/M
•Signal-to-Noise Ratio: >54dB
•Selectivity: +/-10kHz >25dB
General
•Supply Voltage 120V, 60Hz only
•Power Consumption:
5W Idle
400W maximum, both channels driven
•Dimensions:
(HxWxD) 5.75 x 17.1 x 15 in.
Weight 27 lbs
