Squeezebox - wymiana doświadczeń itp.
Gość romeksz
myslalem tylko ze moge otworzyc sam program serwera squezebxa
login as: root
[email protected]'s password:
Linux nas-D5-B0-AC 2.6.17.14ReadyNAS #1 Thu Sep 1 17:44:33 PDT 2011 padre unknown
nas-D5-B0-AC:~# cd /
nas-D5-B0-AC:/# ls
backup  c    etc        home    lib         media  opt   ramfs  sbin  tmp  usr
bin     dev  frontview  initrd  lost+found  mnt    proc  root   sys   USB  var
nas-D5-B0-AC:/# cd usr
nas-D5-B0-AC:/usr# ls
bin  doc  include  info  lib  local  sbin  share  src
nas-D5-B0-AC:/usr# cd share
nas-D5-B0-AC:/usr/share# ls
base-files       dekoh    lld2d   mt-daapd  perl5             tabset
base-passwd      dict     locale  mysql     pixmaps           terminfo
common-licenses  doc      mailx   netatalk  samba             zoneinfo
cups             info     man     nut       snmp
debconf          lintian  misc    perl      squeezeboxserver
nas-D5-B0-AC:/usr/share# cd squeezeboxserver/
nas-D5-B0-AC:/usr/share/squeezeboxserver# ls
Bin   Firmware  HTML  lib    Plugins       SQL
CPAN  Graphics  IR    MySQL  revision.txt  strings.txt
nas-D5-B0-AC:/usr/share/squeezeboxserver# cd ..
nas-D5-B0-AC:/usr/share# cd /
nas-D5-B0-AC:/# ls
nas-D5-B0-AC:/# cd etc
nas-D5-B0-AC:/etc# ls
adduser.conf       host.conf       minidlna.conf      rc4.d
adjtime            hostname        mke2fs.conf        rc5.d
aliases            hosts           modprobe.d         rc6.d
alternatives       hosts.allow     modules            rc.boot
at.deny            hosts.deny      modules.conf       rcS.d
avahi              hotplug         motd               readyNASVault.config
bash.bashrc        ietd.conf       msmtprc            resolv.conf
bash_completion    ifplugd         mtab               rmt
bash_completion.d  inetd.conf      mt-daapd.conf      rpc
btsettings.txt     init.d          mysql              samba
calendar           inittab         Net                securetty
cron.d             inputrc         netatalk           security
cron.daily         ioctl.save      netgroup           services
cron.monthly       issue           network            shells
crontab            ldap            nsswitch.conf      skel
cron.weekly        ld.so.cache     nut                snmp
cups               lld2d.conf      opt                squeezeboxserver
debconf.conf       localtime       pam.conf           ssh
debian_version     login.defs      pam.d              ssl
default            logrotate.conf  passwd             sudoers
defaultdomain      logrotate.d     passwd-            sysctl.conf
dekoh              logsrv          profile            sysinfo
deluser.conf       lvm             proftpd.conf       syslog.conf
e2fsck.conf        lvmconf         protocols          terminfo
email-addresses    lvmtab          quotatab           timezone
exim               lvmtab.d        raid               udhcpc
exports            magic           raidiator_serial   udhcpd.conf
frontview          mailcap         raidiator_version  updatedb.conf
fstab              mailcap.order   raidtab            warnquota.conf
ftpusers           mailname        rc0.d              wizd.conf
gateways           mail.rc         rc1.d              yp.conf
group              mime.types      rc2.d
gssapi_mech.conf   mini-boot       rc3.d
nas-D5-B0-AC:/etc# cd squeezeboxserver/
nas-D5-B0-AC:/etc/squeezeboxserver# ls
convert.conf         modules.conf              types.conf
custom-convert.conf  slimservice-convert.conf
nas-D5-B0-AC:/etc/squeezeboxserver# exit
logout
jak widzisz, tam nie ma nic ciekawego ;-)
A ja powrócę do poniższego pytania:
ozglądam się za jakimś tabletem w roli sterownika do SB.
Macie jakieś typy?
Ma ktoś jakieś doświadczenia z tego typu ustrojstwami (tablety np. na androidzie) czy tylko od biedy "jajpody, jajfony i ipengi"? ;)
Szukam niedrogiego tabletu na adroidzie, powiedzmy od 8" w górę (od biedy 7" jakby było coś ciekawego). Ma to działać jako pilot do SB, czasem może będzie gdzieś zabrany do czytania ebooków. Oczywiście bezproblemowy dostęp do Android Market, niestety różnie z tym bywa, a szkoda mi czasu na jakieś buble i kombinowanie z softwarem...
Edytowane przez m0d
Jeszcze w kwestii prawdziwego zasilacza liniowego:
Specyfikacje:
Output Voltage 5 Volt DC
Input Voltage 230 Volt AC 50Hz
Transformer 30VA
Rectifier bridge ON Semiconductor Schottky barrier rectifiers
Bulk capacitors 6 x Rubycon ZLH Low Impedance High Ripple Current (28.200µF total)
Linear Regulator National LM1086IT-ADJRegulator input and Kemet Solid Tantalum
Output capacitors LDO
Resistors High-precision metaal film SMD resistors 0.1% 25ppm /oC
Bypass capacitors AVX Ceramic X7R
DC power cord 80cm 16 AWG spiral shielded, with integrated SBooster and interchangeble DC plug
Mains cable Standard supplied
Size and Weight Dimension: 124*88*64 mm, 1050 g
I wszystko jasne
(Standardowo dołączony do zasilacza jest SBooster, inny produkt tej firmy
Recenzja klienta (tłum. bubble z j. niderlandzkiego):
Well, what can I say now? Honestly I was skeptical, but decided anyway to buy the SB BOTW Touch but the benefit of the doubt, despite its steep price. Well, I knew (or rather heard). Definitely a noticeable improvement, the entire sound spectrum is rock solid, beautiful transparent with a good foundation. I'll still buy the Style Audio DAC and there is certainly a BOTW to hang. All in all not regret this purchase ...
Zaloguj się, aby zobaczyć treść (możliwe logowanie za pomocą ) Edytowane przez Zombywoof
Pytanie związane z działaniem oprogramowania squeezeserver, squeezeplay (lub squeezeslave).
Zainstalowałem na kompie squeezesrver i squeezeslave by zdalnie odtwarzać muzyke za pomocą programu squeezecommander na telefonie z androidem.
Problem:
Przy przełączaniu na następny utwór zrywa muzyke. Sprawdziłem, że do takich zerwań dochodzi gdy procek jest w znacznym stopniu obciążony. W trakcie odtwarzania muzyki obciążęnie jest na niskim poziomie, jednak jakakolwiek komenda, która w obsługuje squeezeserver (przeglądanie biblioteki muzyki, przełączanie utworów, dodawanie do playlisty) powoduje przycinanie obecnie odtwarzanego utworu.
W komputerze płyta z platformą AMD fusion E350, więc coś energooszczędnego co do tego typu serwera świetnie się powinno nadać.
Czy używająć squeezboxów podpiętych do sieci obserwujecie jakieś problemy zrywania muzyki? Próbuję rozpoznać czy to problem softu w postaci squeezslave (lub squeezeplay) czy to występuje też przy używaniu squeezeboxa.
Ogólnie sterowanie przy pomocy squeezecommander z androida muzyką na kompie jest świetną sprawą. To chyba najlepiej rozbudowana aplikacja ale to wymaga własnie by na kompie był squeezeserver i odtwarzacz programowy typu squeezeplay lub squeezeslave.
Przysiadłem wieczorem i już wszystko jasne.
Uruchomiłem squeezeslave w trybie z asio. Wszystko śmiga... ąż chce się słuchać.
Zadowolony użytkownik softu squeezeeeeee bez squeezeboxa...
Witam, proszę o pomoc w temacie LSTouch. Mam zamiar zamówić poprzez amazon z usa (224 $)
Pytanie czy ktoś wie jak wygląda temat zasilania lub przestawienia 110/220V ?
Czy menu posiada język polski?
Co lepsze do obsługi ipod touch czy tel na androidzie?
Poz.M
Czy ktoś coś wie w tym temacie?
Witam.
fugazi, tomter ... 224$ to ok. 740 zł. Jeśli to cena końcowa to dobrze, jeśli doliczyć przesyłkę ew. cło + podatek to cena już dobra nie będzie.
Kilka dni temu kupiłem na amazon.co.uk za 185 funtów co dało 940zł łącznie.
Egzemplarz z UK ma polskie menu i "przejściówke" do naszych gniazdek prądowych.
Z USA menu pl powinno być (u mnie przy rozruchu i podpięciu do netu pobrał nowy soft/firmware).
Prąd ... nie wiem.
Mój nowy nabytek zastąpi ma płytotekę CDA (flac) i czasami posłuży jako radio.
Pytanie do użytkowników.
Czy zakup QNAP TS-112 (obudowa ok. 620 zł) i "postawienie" na nim Squeezebox Server (
Zaloguj się, aby zobaczyć treść (możliwe logowanie za pomocą ) ) będzie dobrym rozwiązaniem ?
Myślałem o dedykowanym przez Logitecha NetGaer ReadyNAS Duo (obudowa ok 500zł). Ten drugi dedykowany i tańszy, ale z wentylatorem, który jak czytałem potrafi czasami zaszumieć (nie chcę dodatkowego źródła hałasu).
Proszę ew. użytkowników obydwu o jakieś opinie.
Może Ktoś zaproponuje mi inny NAS bezproblemowo współpracujący z LSTouch.
Cena max do 600 zł (bez HDD) i w miarę prosta instalacja Squeezebox Servera (na linuxach nie znam się).
Próbowałem odtwarzać z HDD po USB, 2,5" bez zasilania zewnętrznego nie ruszył (rozumiem), 3,5" z zasilaniem po uruchomieniu Squeezebox Server na LSTouch ruszył, ale
po odtworzeniu kilku kawałków zawiesza się (nie rozumiem). Jeśli Ktoś z Was korzysta z takiego rozwiązania to proszę o konkretne modele HDD, które nie sprawiają problemów (jeśli istnieją :-) ).
Uruchomiłem Squeezebox Server na PC i wszystko ładnie działa. Z racji potrzeby ciągłej pracy PC to rozwiązanie mnie nie interesuje.
Zmieniłem na PC lokalizację plików muzycznym, ustawiłem to w Squeezebox Server i zaktualizowałem bazę na nim i LSTouch "zgłupiał" (rozumiem).
Kazałem mu wywalić starą bazę i zaktualizować na nowo i trwa to już z godzinę (nie rozumiem).
Szybsze jest przywrócenie ustawień fabrycznych i zainicjowanie wszystkiego od początku.
Zaloguj się, aby zobaczyć treść (możliwe logowanie za pomocą ) Edytowane przez gatar
Gość Roxi
Witam Kolegów!
Mam prośbę o info co do wyboru Qnapa. Będzie oczywiście współpracowała z SBT + DAC. Pytanie jest takie, czy te Qnapy z prockiem 1,2 i 256 RAMu dają rady. Są z dyskami 4TB za około 1300. Czy dać sobie spokój o brać pod uwagę raczej mocniejsze. Qnap raczej wyłącznie do muzyki ale mam trochę plików gęstych formatów i nie wiem czy da rady.
Wiem, ze temat Qnapów był 100 razy wałkowany, ale będę wdzięczny za konkretną odpowiedź:)
Gość rochu
Pozwalam sobie zwrócić uwagę dystrybucję Linuxa pod nazwą Vortexbox.
Posiada ona na znakomitą implementację SB-servera.
Ma niewielkie wymagania sprzętowe i jest generalnie szybsza w działaniu od SlimNAS postawionego na FreeNAS.
Ma także funkcję ripowania płyt oraz serwer DLNA.
http://vortexbox.org/
Edytowane przez rochu
Mogę się wypowiedzieć o tym co sam posiadam: Netgear ReadyNAS Ultra 2. Działa dobrze, jest oparty na procesorze Atom (a nie Sparc). Wspierany przez Logitech.
Recenzja:
mam problem squezebox widzi mi tylko niektore okladki albumow? muzyke mam na nasie
co moze byc tego przyczyna?
Chyba czas poczekać na pensję i kupić SBT, Ipad2 mam, Dac też jest, całość wygląda genialnie, szkoda że ten ipeng kosztuje 10$, no ale wygląda tak fajnie jak remote do Itunsa.
Zapytam bo nie mam czasu szukać za bardzo odpowiedzi ( długi wątek, praca itd ). Da sie do SBT podłączyć po usb dysk tak bezpośrednio i sterować całością za pomocą pilota/ipada
pzdr. Łukasz
Witam.
łukasz --> da sie podłączyc HDD po USB i sterować pilotem (ja również używam smartphona na Androidzie),
jednak SBT ciągle mi się "wieszał" (może za słaba jego wydajność to tej funkcji ?).
Z PC bez problemu (ale PC musi pracować, dla mnie bez sensu). Kupiłem NASa QNAP TS-112 i wszystko
ładnie działa.
kurcze to jak mam używać PCta to kupno SBT mija się z celem kompletnie. Kurcze a możę to problem aplikacji na androida ??
BAwił się ktoś ipadem/iphonem/ipodem ?? , z dyskiem na usb/sieciowym z pominięciem kompa ?
ps. ale jak dałeś dysk sieciowy ten NAS to działa wsio bez kompa ??
pzdr. Łukasz
Edytowane przez łukasz
pzdr. Łukasz
no wlasnie sbc+komp mija sie z celem i dlatego wymyaslono cos takiego jak nas zeby to jako tako dzialalo bo odtarzacze sieciowe wciaz kuleja i po usb sobie nie radza z pelna obsluga dyskow z powodu tzw wczytywania biblioteki, no i sam odczyt przez usb powoduje ze to gra przecietnie, dopiero przez nas jest przyzwoicie
tak na nasie dziala bez kompa wszystko tylko trzeba zainstalowac mu squeze serwer a reszte robimy z poziou SBT
Edytowane przez antymalkontent
Gość rochu
no wlasnie sbc+komp mija sie z celem i dlatego wymyaslono cos takiego jak nas zeby to jako tako dzialalo bo odtarzacze sieciowe wciaz kuleja (...)
Mam serwer na Atomie 2 GB RAM i śmiga, że hej.
Nic nie kuleje.
A odtwarzacz sieciowy ma jedną piękną zaletę - nie mam w salonie żadnych dysków ani żadnych zasilaczy impulsowych.
Nic nie szumi, nic nie bzyczy a serwer sobie chodzi w pralni.
Witaj.
QNAP TS-112 ma co prawda mały wiatraczek, ale nie słychać go.
Osobiście do pralni nic wstawić nie mogę, niestety.
Soundcheck już szykuje nowy mod TT 3.0
Hi folks.
Just to let you know.
I will release TT3.0 on the 22nd of October.
You'll find a beta release on the Beta-Blog on the 20th.
TT30 comes with tons of new features and modifications.
It's much easier to install.
And it'll <<squeeze>> that tiny box out even further.
You'll love it.
I'm sure that the price/performance ratio
of that Transport is the best out there.
I didn't manage to get USB-DACs going. I tried hard.
Logitech won't support us at all on the subject.
The modifcations as proposed by John Swenson won't work.
We still experience XRUNS on all kind of DACs. That's why I
leave it out for the time being.
Advise:
A good idea would be to get SBS 7.7.x installed beforehand.
Tranzystor to ciemna strona mocy... strzeżcie się jej... I nie dajcie się zwieść, jakoby mocniejsza była... bo jest tylko szybsza... łatwiejsza... a przez to pociągająca tak bardzo... Podczas gdy jasna, lampowa strona trudna jest... cięższa... wyrzeczeń licznych wymaga... ale bać się jej nie musicie... by Twonk
Podobno SBT "widzi" tylko 10 000 plików (jeśli dysk podłączymy przez USB). Jest to prawda? Jeśli tak, to wg jakiego klucza układa te pliki? Alfabetycznie?
Gość romeksz
Dzięki. To może taki przypadek. Czy ktoś sprawdzał jak zachowuje się SBT z HDD 3,5" z kilkudziesięcioma tysiącami plików? Ile trwa aktualizowanie biblioteki np przy 20,30, czy 50 tysiącach plików? Oczywiście w sytuacji HDD->USB
Hej proszę o pomoc w temacie twardego resetu. Niestety na tą chwilę nie mam stałego łącza i korzystam z toucha poprzez usb. Dysk jest mały 320G i zawiera około 300 cd. Dziś wprowadziłem kilka zmian na dysku. Touch ściąga biblioteki od jakiś 2 godzin. Pytanie czy twardy reset spowoduje ponowną konieczność połączenia toucha do internetu by sciągnąć program z mysqueezebox.com ?
Poz.M
Polecam Logitech media server 7.7. Muli jeszcze bardziej niż poprzednie, ale działają wszystkie formaty i cue. Wcześniejsze wydawnictwa oprogramowania muliły i nie działały jak należy.
Skąd go wziąłeś? Na stronce logitecha jest wersja 7.6.1.
Dzięki, ale już sam znalazłem i właśnie przekopuję się przez ustawienia. Widzę tam jakieś opcje związane z video i obrazami. Czy to może oznaczać, że będziemy niedługo mieli jakieś odtwarzacze mediów innych niż tylko muzyka pracujące w tym systemie? Przepraszam jeśli te pytania są dla kogoś śmieszne, ale ja dopiero raczkuję w tym temacie. I tak jest mi już trudno bo wychowałem się na winylu i radiu :) a tu jakieś pliki, formaty, gapelessy itp.
