Foobar2000 ciekawostki, pliki itd.
majmaj
Witam serdecznie tak sie zastanawiam co wiecie ciekawego o opcjach foobara? możee jakiś odkrycia ciekawe ustawienia?
macie jakieś ciekawe skorki? ja za chwilkę będę sie bawił tym:
tylko nie wiem jak się za to zabrac bo z ang. słabo u mnie.
https://www.audiostereo.pl/topic/46308-foobar2000-ciekawostki-pliki-itd/
HOW TO USE
- Install the fonts.
- Extract the rar contents to: /foobar2000/PanelsUI/
Go to preferences > PanelsUI and select the foobear.pui file in the Layout dropdown box.
- I recommend that you turn on ClearType if you use Windows XP.
- Add and scan your Media Library in Preferences > Media Library.
- If the album title in the playlist is called "Single Tracks" you must tag your album's Total Tracks tag. The easiest way to do this is to select all your songs in the playlist > rightclick > rightclick again on the Total Tracks field and choose "Auto track number".
- To display the album art:
The front cover must be named folder.jpg and be located in the album's folder where the music files are.
Same with artists. Name those images artist.jpg.
- Tag your music!
Rightclick on your songs and choose properties. Fill in the correct artist, title, year, total tracks, album name etc.
See
Zaloguj się, aby zobaczyć treść (możliwe logowanie za pomocą ) for the correct tags you need for your music.
- To change the background between the bear and a blank one - click on the 1 & 2 buttons next to the search area.
- The 3 top left buttons switches between, playlist, playlist switcher and library filter.
That wallpaper is from:
KNOWN ISSUES
- If you use the latest PanelsUI beta 0.14.x the rating buttons won't work correctly. I recommend that you use the latest 0.13.x instead.
- Minor issue with the big play/pause button on the big cover image.
niech mi to ktos przetłumaczy bo mnei juz kur** bierze :P)
Gość cadam
A oto wynik tłumaczenia przez google
Sposobu korzystania z
- Instalacja czcionek.
- Wyodrębnij zawartość do rar: / foobar2000/PanelsUI /
Przejdź do preferencji> PanelsUI i wybierz plik w foobear.pui Układ pola wyboru.
- I zaleca, aby włączyć funkcję ClearType, jeśli używasz systemu Windows XP.
- Dodawanie i skanowanie biblioteki multimediów w Preferencje> Media Library.
- Jeżeli w tytule albumu listy nazywa się "Single Tracks" należy otagować albumu Razem Utwory znacznikiem. Najprostszym sposobem, aby to zrobić jest wybór wszystkich utworów na liście odtwarzania> prawym> prawym ponownie Razem Utwory na pole i wybrać "Auto numer ścieżki".
- Aby wyświetlić album sztuki:
Przednią pokrywę należy nazwie folder.jpg i być umieszczone w albumie na folder, w którym są pliki muzyczne.
Z tych samych artystów. Nazwa tych obrazów artist.jpg.
- Tag your music!
Prawym przyciskiem na swoje piosenki i wybierz polecenie Właściwości. Wypełnij prawidłowego artysty, tytuł, rok, łącznie utworów, nazwy albumu itp.
Zobacz http://musicbrainz.org/ dla prawidłowego tagów musisz dla swojej muzyki.
- Aby zmienić tło w poniesie między pusty i jeden - kliknij na 1 i 2 przyciski obok obszaru wyszukiwania.
- 3 przyciski, przełączniki lewym górnym rogu pomiędzy listy odtwarzania playlist switcher i biblioteki filtr.
Tapetę, że jest z: Vplants 9
Znane problemy
- Jeśli korzystasz z najnowszej PanelsUI beta 0.14.x ratingu przyciski nie będą działać poprawnie. Zalecamy korzystanie z najnowszych zamiast 0.13.x.
- Drobne duży problem z przycisku odtwarzania / pauzy na pokrycie duży obraz.
skonczone, miałem chyba wszystkie możliwe błędy... poczynajac od problemow z jadrem az po panele i wtyczki. Teraz wszystko gra, po 2 kliknieciach wchodzi mi w dane o albumie + okładka. jestem w miare zadowolony.
pr1nce, 22 Paź 2008, 23:16
>sciaga Ci okladke z internetu ?
>dzialaja Ci lyrics ?
>jezeli tak, to bylbym wdzieczny za upload calego kat z foobarem
sciagniecie okladki to kwestia klikniecia w 2 miejsca ;) i automatycznie zapisuje na dysku. Jest mozliwosc aby bez klikniecia zapisalo okladke ale to kwestia ingerenci w kod.
co do tapety sam robilem :) link:
a mi foobar2000 nie otwiera wav. :(( zdeinstalowalem i zainstalowalem na nowo ale nie pomoglo. mam viste na laptopie hp, na winampie wav chodza ale osobiscie wole foobara. mial ktos ten sam problem
chodzi o okładki? jak tak to plik foo_discogs-1.dll wklejasz do C:programyfoobar2000components, aby poprawnie działał musisz podmienić zlib1.dll
te 2 pliczki:
ustawienia:
w razie w pytaj.
Pokarzcie swojego…. Foobara, zacznę:
Pierwsze koty za płoty.
u mnie skromnie
czesc,
foobara zainstalowalem wczoraj... jak z jakoscia konwersji z flac do mp3.
- czy po drodze cos chrzani czy jest ok jesli zrodlo (flac) zapodam i zrobie convert do *.mp3 ustawiajac LAME i V0?
- czy moze sugerujecie zebym robil recznie flac -d a potem wavy do mp3 przy pomocy LAME. Szczerze - nie chcialbym w to sie bawic, chyba ze jest jakis automat...
Druga sprawa... foobar2000 po instalacji nie przyjmuje *.ape... musze dograc jakis plugin? jaki/skad? dajcie pls znac, musze troche flacow i apow zrzucic do mp3 bo stacjonarny odtwarzacz nie lyka bezstratnych...
bonart1, 12 Lis 2008, 13:05
>czesc,
Po co te kombinacje?
prawym na playlist -> convert to -> wskazujesz enkoder lame, ustawiasz -> lokalizacja -> czekasz
a potem jeszcze lepiej
convert to -> last used
no wlasnie tak robie... tylko nie mam kontroli nad:
- procesem decompresji flac do... (nie wiem do czego foobar to dekompresuje - zakladam ze do wav a na koniec to kasuje)
- procesem kompresji do mp3 (bo niby fakt, moge wybrac lame, ale potem jest ten "zajebisty" suwak sluzacy do kontroli high speed vs best quality co daje tylko vbr v0 = a co jakbym chcial cbr 320kbps = insane?=nie ustawie prawda?
>j dajcie pls znac, musze troche flacow i apow zrzucic do mp3 bo stacjonarny odtwarzacz nie
nie wiem czy dobrze zrozumiałem? z bezstratnych robić mp3? to chyba za przeproszeniem ocipiales :D
bonart1, 12 Lis 2008, 18:38
Foobar to program do sluchania, zainstaluj sobie kolego EAC.
majmaj...
1. flac i ape do mp3 - tak dobrze zrozumiales. przeczytaj jeszcze raz by sie dowiedziec dlaczego...
- chyba ze sa jakies stacjonarne odtwarzacze ktore akceptuja flac/ape- ja o takich nie slyszalem, moje zrodlo lyka tylko mp3 i wma, a chetnie bym cos fajnego kupil...
2. eac - z tego co wiem nie wykona zadania (ma byc szybko/automatycznie)
- chyba ze ja nie wiem jak uzyskac w eac taki scenariusz:
- zassac wszystkie flac/ape
- wykonac konwersje do mp3 (lame -preset insane lub extreme)
- a wszystko to w 2 klikach/z zachowaniem tagow itd... bo na piechote (flac-wave, wave-mp3) to nie mam zamiaru...
foobar jest prawie idealny - boli tylko brak kontroli pelnej nad lame, i nie wiem czy foobar nic nie psuje po drodze.....
pozdrawiam...
Twój odtwarzacz lyka na 100% wav i tak nagrywaj te pliki! A nie z formatu The Best robisz gownanie mp3. jak chcesz mieć zautomatyzowane nagrywanie lossless to ściągnij burrrn.
powodzenia
Nowy resampler, lepszy niż Secret Rabbit Code
tak, testowałem go i nie przekonał mnie pod żadnym względem
jest to z pewnością dobre rozwiązanie dla kogoś kto chce mieć gotowy, prosty w obsłudze odtwarzacz o niskich wymaganiach. Nic więcej
