ONKYO CS-525
ALTON
Digs deep for the detail
Listening to the hotly anticipated and predictably underwhelming Chinese Democracy album from Guns N’ Roses, the Onkyo reveals plenty of detail as it delivers an open, spacious sound.
Kanye West’s Robocop shows this system is capable of hitting high frequencies as well as it can reach impressively low bass notes.A very promising start, but prolonged listening turns up a few small issues that start to bug us.
Listening to A Tribe Called Quest’s Buggin’ Out, the track doesn’t quite have the flow we’re used to, with the lazy rolling bassline lacking pace and punch, sounding a little soft.
More pertinently there’s a lack of balance to higher frequencies, with vocals at times sounding a touch muffled while other treble sounds display some brightness.
Switch to the tuners and the Onkyo is strong and reliable, picking up the necessary stations and demonstrating clarity and stability with DAB and FM.
While undoubtedly an enticing product, sonically this Onkyo doesn’t quite match either its admittedly brilliant predecessor or the new kid on the block from Denon – which can only mean four stars.
https://www.audiostereo.pl/topic/48555-onkyo-cs-525/#findComment-1254074
Niektóre informacje możesz znaleźć tutaj:
Zaloguj się, aby zobaczyć treść (możliwe logowanie za pomocą ) (szukaj moich postów)
Mogę jeszcze dodać, że to dobre mini w swojej cenie.
https://www.audiostereo.pl/topic/48555-onkyo-cs-525/#findComment-1254076
Mam cs-325 w sypialni. To w sumie to samo tylko ze 525 ma lepszy przetwornik w cd i posiada usb.
Te mini Onkyo graja podobnie jakosciowo do Pianocraftow, mini Denonow itd. Kwestia gustu co wybrac. Mi Onkyo bardziej podeszlo od Pianocrafta. Za ta cene bardzo dobre mini.
https://www.audiostereo.pl/topic/48555-onkyo-cs-525/#findComment-1254353
  • 7 miesięcy później...
  • 4 miesiące później...
Dobry_chlopak,
zdjęcia dla Ciebie. ;)
https://www.audiostereo.pl/topic/48555-onkyo-cs-525/#findComment-1568836
Jedyne różnice między CS-325, a CS-525 to tak jak napisał Ender^Wiggin - różnica w przetworniku w CD (mocno wpływa to na dźwięk?) oraz USB?
SMSL Q5 Pro ♪ Magnat Quantum 673 ♪ Google Chromecast Audio ♪ Technics SL-Q3 ♪ Koss Porta Pro ♪ Philips TAPH805BK
https://www.audiostereo.pl/topic/48555-onkyo-cs-525/#findComment-1569062
Są drobne zmiany aplikacyjne. Największe zmiany to dodatkowy DAC WM8726 w CD (model 525) zamiast wyjścia audio prosto z chipsetu CD CXD3014 (325) oraz kontroler USB BU9437(525). Nic poza tym (z widocznych zmian). Koniec mocy, tuner oraz preamp są identyczne w obu modelach.
https://www.audiostereo.pl/topic/48555-onkyo-cs-525/#findComment-1569108
Notabene firma chwali się tym dodatkowym dacem w modelu 525 i podaje dumnie 192khz/24bit tylko nie wspomnieli że to jeden z pierwszych daców jakie pojawiły się na rynku w 2000r o dość słabych parametrach (ale i tak lepszy niż goły chipset cdx) :)
https://www.audiostereo.pl/topic/48555-onkyo-cs-525/#findComment-1569111
samael
Dziękuje za foty mam jeszcze 1 pytanko czy pod wejscie DOCK moge podłaczyć np.DVD to jest to samo co AUX?
Jest jeszcze jedna różnica pokrętło w cs 325 jest z tworzywa a w cs 525 jest metalowe :)
https://www.audiostereo.pl/topic/48555-onkyo-cs-525/#findComment-1569134
Pisze na raty sorki.Skopiowałem moje pytanko z innego tematu.
Jestem prawie na 99,999% zdecydowany kupić ONKYO CS-525 słucham muzyki dance,techno(armin van buuren,atb,westbam...)tu parę kawałków dla nieznających ocb.
Uwielbiam niskie tony więc bez suba się nie obejdzie co polecacie pokój 18m2 na velodyne mie nie stać(podobno najlepsze suby) kwota którą moge przeznaczyć ok 500zł
https://www.audiostereo.pl/topic/48555-onkyo-cs-525/#findComment-1569144
Polecam Ci subwoofer firmy Voice Kraft (tak, to nie jest żart) model 7800 do 7830 - to ten sam sprzęt tylko z innym wykonaniem skrzyni. Poczytaj moją recenzje na elektrodzie. Subwoofer jest wykonany jak markowe produktu za 1000zł. Za 300zł nie znajdziesz nic lepszego nawet z używanych.
https://www.audiostereo.pl/topic/48555-onkyo-cs-525/#findComment-1569162
ALTON
Widzę że to twoja recenzja elektodzie gratki :) myślałem nad jamo sub 200 nie wiem jak porównać te dwie konstrukcje?Szukałem na allegro i nie mogę znaleźć vk7830 jest tylko 7820 bebechy mają te same jak pisałeś ale mają inne obudowy i to już może robić różnice nie wiem czy go brać co myślisz?
https://www.audiostereo.pl/topic/48555-onkyo-cs-525/#findComment-1569245
Sorki zapomiałem o linku
https://www.audiostereo.pl/topic/48555-onkyo-cs-525/#findComment-1569257
ALTON napisał:
"Są drobne zmiany aplikacyjne. Największe zmiany to dodatkowy DAC WM8726 w CD (model 525) zamiast wyjścia audio prosto z chipsetu CD CXD3014 (325) oraz kontroler USB BU9437(525). Nic poza tym (z widocznych zmian)."
Na CS-525 widnieje jeszcze logo VL Shaping Circuitry :P
terminale głośnikowe są pozłacane (i mają przeźroczyste nakrętki),
kolumny głośnikowe są całe na połysk (w CS-325 tylko fronty)
Dobry_chlopak napisał:
"Dziękuje za foty mam jeszcze 1 pytanko czy pod wejscie DOCK moge podłaczyć np.DVD to jest to samo co AUX?"
Nie mam pojęcia. Nic dodatkowego nie podłączałem.
https://www.audiostereo.pl/topic/48555-onkyo-cs-525/#findComment-1569315
Witam ja także posiadam tą miniwieżę. Pozwolę sobie zamieścić kilka zdjęć.
https://www.audiostereo.pl/topic/48555-onkyo-cs-525/#findComment-1574737
