Jeśli nie Marantz NA11S1 to co?
Janusz72_sa
A co powiecie na ten player J Feng HDM-03 lub HDM-03S . Wykonanie pierwsza klasa, cenowo również poza zasięgiem europejczyków
Dlaczego cenowo miałby być poza zasięgiem? Z tego co widziałem ceny to 2500USD/1750Euro. Ważniejsze pytanie to jak to gra?
Dokładnie cena to ok €700-800. W tej cenie tyle sprzętu cieżko dostać.
Co nie tak z supportem? Strona jest, firmware do sciagniecia jest, cos robia:)
SUNDRY COMMENTS
A downside to the whole experience is the lack of after sales support. It’s not just the language barrier either – I get the impression from the manufacturer website that they aren’t as focused on individual sales as they are on finding OEM partnerships. For example, there are several firmware updates, but there is very little info as to the changes each one brings. Each time I’ve updated I’ve had a nervous feeling like I may be about to ruin the machine. There is also the matter of finding a matching WiFi adapter which has been mildly frustrating. Most companies would have a list of recommended adapters, or a forum where fellow users can post their results, or something to help the situation. Not so in this case. I'm also scared that I may somehow damage the remote, which would be a big deal. Many functions are only accessible with the remote. I'd have to contact the manufacturer and hope I could get a new one. I should hurry up and program my Harmony remote to duplicate this remote, just in case.
There also appears to be a recent upgrade to the main processing module. The website doesn’t really say how one can update to the new version. It does list the specs, which happen to be the same as I already have in the HDM-03S (the newest of all the different models). So perhaps I already have the newest processor installed? To make matters worse, the new module is not quite a plug and play upgrade – each model has a different set of instructions for some hardware modification necessary to support the upgrade. It involves cutting traces and soldering. Since instructions exist to do this process for the HDM-03S, do I then logically conclude that I don’t have the updated processor after all? I don’t know. There are some very recent firmware updates that specifically state they only work with the upgrade. If I try them, will I brick my unit? I need to have someone translate for me to get answers to my questions. For now I’m keeping it as-is with the older but solid firmware.
Welly, welly, welly, welly, welly, welly, well. To what do I owe the extreme pleasure of this surprising visit?
Czytałem to również:) To jest post sprzed 3 lat. Od tamtej pory fw zostało poprawione. Są dostepne wifi dongle w sprzedaży także nie ma problemu. Wg mnie za tę cenę jest to interesujące urządzenie, lepsze niz magic6 i pioneer n50.
Ja zaryzykuję i kupię tego chińczyka:)
Czy brałeś też pod uwagę inne player'y np:
Co o nich sądzisz ?
Tego akurat nie poniewaz potrzebuje wyjscie analogowe:)
Ten jest tez ciekawy, parametry podobne do j fenga.
Wszystkie te ostatnie propozycje są dosyć budżetowe, a przypomnę szukam czegoś co mogło by zastąpić Marantz-a 11S1, który w kilku zagranicznych recenzjach nazwany był mianem referencyjnego.
A co z tych cudeniek ma serwis Spotify? Primare NP30 i któryś CA to obsługuje. Cocktail-e współpracują z serwisami streamingowymi niedostępnymi w PL. Chodzi o bezpośrednie połączenie, bez pośrednictwa kompa czy telefonów
Gość rochu
Najlepszą i obsługę serwisów streamingoych ma Sonos.
Ma też największy wybór tych serwisów.
Przez wiele miesięcy korzystałem z Qobuz za posrednictwem Sonosa pomimo tego, że serwis ten nie jest dostępny w PL.
Szukasz wysokiej klasy w plikach to od lat nr 1 jest...Linn. Są drogie ale nie musisz kupować nówki. Inne wysoko oceniane plikowce to Cyrus.
Tylko że te linn nawet nie mają jednego złącza usb. W dzisiejszych czasach to minimum;) Kazdy ma dysk z muzyką...
Zaloguj się, aby zobaczyć treść (możliwe logowanie za pomocą ) ale nie pracuje z ape
Do Linn-ów stosuje się dysk NAS. Moźna kupić interfejs do zwykłego dysku USB i też zrobić z niego NAS. Kupowanie chińskich wynalazków jest bez sensu. Zawsze po jakimś czasie chce się wymienić na coś lepszego a swój sprzęt sprzedać. Tyle, że chińskiego wynalazku nikt potem nie kupi.
Tutaj (
Zaloguj się, aby zobaczyć treść (możliwe logowanie za pomocą ) ) jest Soundware D100 pro opisany przez właściciela zestawu Marantz PM11S.
Ja bym chętnie kupił coś firmowego typu linn/cyrus tylko że takie drogie pudełka a nie mają dostępu do USB. Nie mają WiFi. Cyrus odtwarza jedynie 24/96, wyświetlacze mają wielkości pudełka od zapałek... Słabo to wygląda oj słabo zważywszy że cenią sobie dużo oj dużo... Dla mnie odpadają już na starcie. Dlatego taki chińczyk może być dobrą alternatywą , zwlaszcza jak jest dobrze zbudowany.
Jest jeszcze NW-T od Ayona jesli ktos lubi te szkole dzwieku, nieco tanszy od Linna , z usb i radiem internetowym
Konto w trakcie usuwania
Pisałem już, że są interfejsy NAS do dysków USB. Synology taki ma, Qnap i inne firmy też. Podłącza się do tego dowolny dysk USB i w całej domowej sieci jest dostęp do tych plików. Można z czasem mieć np drugi taki odtwarzacz plików w innym pokoju i tak samo mieć dostęp do tych samych zasobów muzyki. Co do wyświetlacza to zupełnie nie rozumiem. A kogo obchodzi wyświetlacz? Kto z tego korzysta? To jakieś jaja są chyba. Wiadomo, że steruje się iPadem czy smartfonem i do tego wcale nie musi być drogi ipad najnowszej generacji. Wystarczy używany, dwie generacje wstecz i za grosze jest sterowanie, które bije na łeb nawet największy, kolorowy wyświetlacz w samym odtwarzaczu plików. Ale widzę, że uparłeś się na chińczyka to kupuj chinola. Nikt tobie nie broni.
Na stronie Cyrusa jest kilka modeli plikowców w tym najnowszy który czyta 24/192, ma wbudowane USB, ma DAC i prosty preamp. Na pewno lepszy niż chinol.
Wiesz... dla mnie to są jakieś jaja żeby kupować tablet do takiego playerka. To ma być pełnowartościowy produkt. Dla mnie akurat nie jest. Ja lubię wygodę czyli; podchodzę z przenośnym dyskiem 2.5'' podpinam do usb , właczam power, wybieram muzykę z dysku / radia internetowego i gra. I tyle. Żadne serwrey, nasy dodatkowe włączone komputery itp mnie nie interesują. Dlatego potrzebuje jakieś 5'' lcd i jest git.
Ja to tak widzę :) Każdy woli co innego. A w większości te ''topowe'' playery mają chińskie bebechy przepakowane w ładne pudełko i x10 cenę wyższą - choć zaznaczam od razu że nie wszystkie żeby wojny nie wywoływać:) Ale jest już jeden wątek o takich ''przebierańcach'' z modnym logo na przodzie:)
Jak już kupię tego chińczyka to się chętnie pochwalę i napiszę czy jest taki jaki sobie wyobrażam/chcę.
Wesołych
Ja lubię wygodę
hehe…lubisz wygodę i zamiast tabletu do sterowania chcesz mieć wyświetlacz na playerze? Nie żartuj sobie.
Najwyraźniej nie miałeś co czynienia ze sterowaniem z tabletu. Co ciekawe do tego nowego Cyrusa jest duży pilot z wyświetlaczem. To na pewno nie jest tak wygodne jak tablet ale wygodniejsze niż wyświetlacz na playerze. Sterowanie plikowcem z wyświetlacza na playerze to najgłupsze rozwiązanie. Totalny non sens. Na forum były już opisy eksperymentów z różnymi chińczykami. Miało być tak pięknie, a później był płacz i próba pozbycia się wynalazku.
Wesołych
Ja dokładnie to samo. Na dodatek przyszły standard nie jest ustalony. Z tego co Koledzy piszą wnoszę, że plikom daleko jeszcze do doskonałości i CD pozostanie przez długie lata punktem odniesienia. Nie wiem, czy specjalnie czy nie, ale żadne z urządzeń nie spełnia oczekiwań w zakresie funkcjonalności. Albo są za bardzo rozbudowane o jakieś wzmaki, daki, wymagają współpracy jakiś aparatów telefonicznych czy innego porno dla ubogich. Nie dziwne to? Ja w każdym razie dalej czekam do pierwszego modelu, spełniającego moje- niewygórowane potrzeby
Ja słucham muzyki a nie gapię się w tablet:) Nie mam triku nerwowego i nie zmieniam utworów co minutę:)
Tak jak pisałem każdy woli co innego. A tablet + najtańszy nas serwer to połowa tego chińskiego playera.
Cały świat przeszedł na sterowanie tabletami. Co innego włączenie jednej płyty CD, a co innego przeszukiwanie zasobów różnych plików, których na dysku HDD mogą być tysiące. Do tego musi być wygodny, duży ekran i łatwe poruszanie się po nim. Czy tego chcecie czy nie, taki jest standard i nic tego nie zmieni. Oczywiście można się męczyć na wyświetlaczu w urządzeniu, ale to non sens, walka w wiatrakami. Kto raz spróbuje sterowania z ipada, ten nigdy nie wróci do opcji wyświetlacza w playerze. Niemniej jednak zwykły pilot też jest fajny choćby do tego, że na szybko zatrzymać muzę,np gdy dzwoni telefon, albo do przeskakiwania na kolejny utwór co czasem się robi.
Tak czy inaczej taki dodatkowy pilot się przydaje, ale i tak 90% sterowania odbywa się z tabletu.
Pewnie tak. Dobre zawsze kosztuje. Lepiej jednak kupić dobrą używkę znanej firmy niż nowego chinola, bo używanego chinola u nas nie dostaniesz. Różnice docenisz z czasem poprzez wsparcie techniczne, aktualizacje softu czy późniejszą odsprzedaż.
Okazuje się, że to nie do końca jest prawda. Tak czasem się ludziom wydaje. Kiedyś też tak myślałem, ale czas pokazał, że czasem bywa inaczej. Udowodnił to Jobs. Nadal wolę Nokię jako telefon ale takich jak ja jest niewielu. Świat wybrał smartphony i porzucił klasyczne rozwiązanie doprowadzając gigantyczną Nokię do bankructwa.
Nie próbowałeś Linn-a. Wraz z dyskiem NAS i tabletem/smartfonem jest najbardziej funkcjonalny.
<br /> Kto raz spróbuje sterowania z ipada, ten nigdy nie wróci do opcji wyświetlacza w playerze. Niemniej jednak zwykły pilot też jest fajny choćby do tego, że na szybko zatrzymać muzę,np gdy dzwoni telefon, albo do przeskakiwania na kolejny utwór co czasem się robi.<br />
Osiołkowi w żłobie dano w jednym owies w drugim siano.
Tak się zastanawiam i dochodzę do wniosku że te nowe technologie uniemożliwiaj nam nacieszenie się na spokojnie muzyką i daną chwilą!!! Pstrykamy tym przyciskiem next a nóż coś następnego będzie jeszcze lepsze i nie jesteśmy w stanie w spokoju do końca nacieszyć się tym co obecnie słuchamy. Po co nam taki pęd dokąd on ma zmierza, kto nas tak nakręca i po co?
Kolejna puszka pandory w eleganckim tablecie, kolejne uzależnienie; codzienna kawa przy tym to tylko drobna słabostka :)
Trochę racji masz, ale tak to już jest. Podobnie skacze się pilotem od TV. Przy muzyce jeśli słucham na poważnie to nie ma potrzeby skakania. Ale jeśli przeglądam muzę, np dostanę paczkę z płytami i mam sobie z tego coś wybrać to funkcja SKIP przydaje się. To narzędzie same w sobie jest bardzo dobre, a że nie wszyscy używają go z umiarem to już wina ludzi. Podobnie można wysnuć tezę, że internet i smarfony to szatańskie przekleństwo XXI wieku i dowodów na to jest sporo. Już się leczy uzależnienia od tego diabelstwa.
Co do sterowania tabletem to się zgadza, że lepiej i wygodniej ale dlaczego niektórzy producenci uparli się na wsparcie tylko produktów Appla. Nie lubię być zmuszany do zakupu czegoś czego nie chcę, bo mam już tablet z androidem. Wielu producentów pytanych o to kiedy będą aplikacje na androida odpowiadają "w przyszłości" lub "w przygotowaniu" i tak od paru lat.
Życie jest pełne uzależnień, takich czy innych. Problem leży w samych ludziach, a nie w sprzętach i używkach dostarczających owych uzależnień. Mnie też nie podoba się wiele zmian jakie wnoszą obecne czasu. I z wielu z nich nie trzeba korzystać. Wielu można powiedzieć NIE. Ale nie zmieni to świata. Jest jak jest.
Linn ma do obsługi wiele aplikacji w tym takie na Androida. W tym przypadku nie ma problemu.
No cóż w takim razem stałem się wolnym człowiekiem! TV ani kablówki nie mam od ponad 10lat.
Radzę to innym na spokojnie przemyśleć; z "Nextów" spotify też mam ale omijam go jak TV :)
Ależ każdy nasz czyn go modeluje, cały czas go zmieniamy :)
Miło jest oglądać Hobbita czy komedie w domowym zaciszu. Głupiej TV i przeklętych reklam nie cierpię ale dobry film jest ok. Wolę to niż chodzenie do kina.
