TE8802 Asynchronous USB 24/192 DDC-DAC
anadigit
USB 24/192 Native Asynchronous
All of you need I've designed flexble using.
1. USB to S/PDIF with WM8804 Digital Conditioner and DPLL + WIDCOM 82154 Pulse Transformer
2. USB to AES/EBU with PE-65812 Pulse Transformer
3. USB to I2S with RJ45 Connector
4. USB to Analog Output with Wolfson 24/192 DAC
5. SATA HDD II internal
6. USB HUB 2 Port
No need extra power supply or any cable
Support :
Windows all version, Linux, MAC
16BIT & 24BIT, 44.1Khz - 192 KHz
ASIO Driver Specified for this machine
6. USB HUB 2 Port
Support :
https://www.audiostereo.pl/topic/86003-te8802-asynchronous-usb-24192-ddc-dac/
te HDD is for music storage ? is it a music player too ? How do you control it?
the two left USB-A ports are probably inputs for flash drives?
and the top USB-B one is PC input ?
And whats the approx price ?
I come from Malaysia.
My USB DDC-DAC was designed as a share project but I need to explore if there're many guy interested enough.
MY HDD SATA only used for storage data it's not for play any files with stand alone mode.
USB-A for thumb drive or other USB devide
USB-B for connect to computer input.
There're 10 LEDs status = BIT RATE 2, SAMPLING RATE 6, SUSPEND 1, OPERATE 1
There're 8 Connectors = USB PC IN 1, ANALOG OUT 2, SPDIF OUT 1, AES/EBU OUT 1, I2S OUT 1, USB DEVICE IN 2
TE8802 for USB Asynchonous 24/192
WM8804 for Digital Signal Conditioner and DPLL
WM8523 for DAC 24/192 (better than WM8741/42 if used only 5VDC from USB port)
SGM4810 drive headphone directly
HDD SATA II + USB HUB from IBM designed
This's only prototype, a real machine I'll placement all parts to symetry dimension and hi-end looking !
It's price 175 EURO with completed chassis.
My USB DDC-DAC develop from Lindemann USB DDC 24/192 + Firestone Audio ILTW (275EURO + 260EURO)
I can't add my pictures to here ! Maybe I have to use these link >>>
This's my adventure :-)
Thanks
Anadigit
Ok. Now I understand.
How you've got your hands on new Tenor dice?
You are using independent oscillators for 44.1kHz and 48kHz?
Are you planning to add analog stage?
How you switch between inputs and outputs?
Lust is my sister, my muse and my whore
I stand on the mountain, and pray for the war
Yes, I designed a new TE8802 by myself.
Yes, my USB DAC used Sychronous Clock 44.1 - 192KHz
It already has Analog Output L/R, I've add wolfson 24/192 DAC, too
It has only 1 Input of USB but there're several output, analog/SPDIF/AES EBU/I2S all of them automatic detect.
Thanks
Anadigit
  • 1 rok później...
Miał ktoś do czynienia z tymi produktami ?:
