Niedrogie kolumny do ....
pitek
W linku znajdują sie pomiary tych B&O
Mieciu przeczytaj to:
to gowienko naprawde jest super
" We're a competitive lot at TNT-Audio. Often we find something interesting and sort of spring it on the others on the staff as our "find". So you can imagine my annoyance when I received an email from our illustrious editor - quote: "BUY a Sonic Impact T-Amp. At 20$ it is the most incredible thing I've ever come across in 25 years of HiFi Passion. I'd like to receive feedback from other trained ears...."
Damn...
You see I'd been sitting on the same amp for a month and was just getting round to doing some serious playing with it and getting very excited in the process. Lucio's email meant he beat me to it, but it also showed something that I'd experienced myself, a certain need to check I wasn't losing the plot before going to print.
So Lucio - here's my take on the thing...
Regular readers will know that my main system is powered by am Audionote M3 pre/Quest Silver 300b SE monoblocks driving a pair of Loth-x Polaris full-range horns. Now rumours on the web had the Sonic-Impact (SI) competing with megabuck single-ended valve amps so I guess I was perfect for the comparison. The Polaris have got to be one of the most efficient, and easiest to drive speakers out there so the SI would be in it's element, never needing to draw more than a couple of watts.
So purely in the interests of research I unplugged the Audionotes, wired the Audionote Zero CD player direct into the SI via a pair of cheapo cables and a phono-jack adaptor (not even gold plated!). As the usual Sonic Link hosepipe wouldn't cram enough of its strands into the naff spring clips I used some really cruddy thin speaker cable I got with some cheap car speakers I'd bought years ago.
Switch on and of course the thing was silent, none of the hiss and hum of the valves. Putting on a bit of Steely Dan 'Aja' I sat back.
Holy s**t! For less than half the cost of one of the cheapest 300b valves this thing was making music. Huge soundstage width, detail right up there with the Audionote pairing, fast and punchy. This would seriously impress the neighbours. Obviously it'd go really loud.
This isn't my review, and I'm not going to go into great detail here, but to put this into perspective (did I really say that? A $30 amp against a $15,000 combo?) if tomorrow I invited one of you readers into my home and wired up half a dozen of the big-buck valve amps I'd had here over the last couple of years and, sight unseen, slipped in the SI as one of the test amps it wouldn't have been out of place.
But, and it's a big BUT, it doesn't sound like an SE. Crippled as it was by the worst possible cables and connectors it managed to sound hard and flat next to my own amps, I can't measure emotion, but some of it was gone. It lacked the warmth and soul and ambience that they bring to the party.
The 3-d imaging was limited but the soundstage width stunning, the detail top notch and the music relatively undamaged, it also lacked the grain of any transistor amp within 30x its price. That said I would take it over some very expensive amps I've heard, and if I was forced to "downgrade" my system by $15,000 it would be the SI that would make it bearable.
But think on - what would it do with decent cabling? What about playing with better power supplies? (the Graham Slee PSU's from his phono stages might be perfect). What about swapping a couple of components/connectors for decent stuff. What about buying two and bi-amping, or four and quad amping? What about running one as a power-amp using a high-end pre? Buy an active x-over and go mad. What about buying a really flash box, putting on some blue LED's and some chunky binding posts and sockets, a BIG volume knob and selling it for $10,000 muha, muhaha! muhahahaha argh gurgle!
But seriously folks - how's this for an idea? Buy two. Build some high efficiency boxes, maybe our TNT BFB and run "monoblocked" with one channel from each amp driving a full-range driver and the other a supertweeter? High-end for $150? I'm not going to tell you what or how to do it because at this money you can just PLAY!
Me? I've just hit Ebay for a pair of 40 year-old Goodman 401 full-rangers (12") for $50 and I have plans. After three years of disappearing up my own backside with more and more expensive equipment I feel like hi-fi is suddenly exciting again.
GO BUY ONE, then write a thankyou note to Lucio.
Geoff Husband - www.tnt-audio.com "
>Mieczysław
Po prostu wpisz w wyszukiwarkę "t-amp", będziesz bogatszy w wiedze:)
T-amp z linku bez przeróbek gra tak sobie, po przeróbkach jest naprawdę fajny. Ale do dobrej lampy to mu dosyć daleko. Określenie "gra jak klocek za 3- tys." to paranoja.
Trochę sensu poproszę.
Z moich doświadczeń z t-ampem dotychczasowym. Tani i jest, gra i nieźle, ale kolumny trzeba do niego dobrać trudno. Tym trudniej gdy kupuje się używane :/
nie przejmuj się są w twoim wieku, to nie ma znaczenia
A co sądzicie o :
Gale 303
Tannoy Mercury F1
Magnat Monitor 880
Magnat Monitor 990
kupa złomu z hipermarketu
ot co
bardzo łatwo teraz stać się ofiarą marketingu
młody, nie uzywaj za bardzo oczu , nie kupuj tego co się świeci
nie jestem pewien, może ktoś ma to odpowie. ale moje f4 w 22m2 stoją daleko od ścian a i tak pozatykalem bass refexy. z kolei w jednej z knajp w Bydgoszczy słuchałem f2 podwieszonych pod sam sufit i bas był super
artPaw-owi rację
jarekeraj-owi też rację, ale co do F2 to nie wiem, jakoś niepewny zakup, nigdy ich nie słyszałem
M2 chodzą po około 600 zł
Polecam Liberty 1+ - starsza wersja, z czarnymi głośnikami, lepsza od srebrnej w zakresie średnicy, która to srebrna ma opinię w zakładce "Opinie". Do 10m2 jak znalazł, do hip-hopu też, a i pozwolą nauczyć się słuchac muzyki :).
A jeżeli juz chodzi o sprzęt do łojenia w rocku i techno, to Soniaki z linku:
miałem kiedyś takie, nawet je trochę przerobiłem. Dobrze napędzone wytwarzają ścianę dźwięku, bas jak z subwooferów, minus to brak finezji w środku i górze, ale do robienia czadu zajebiste no i za grosze.
Zaloguj się, aby zobaczyć treść (możliwe logowanie za pomocą ) te bez reflesku, czyli też do 10m2 jak znalaz, zagrają cieplej niż obecnie tworzone skrzynki
A co do basu, to będzie pod dostatkiem. Na początku drogi ze sprzętem wydaje mi się, że ważne aby miał konturowy wykop i był zróżnicowany w zakresie barwy (pomijając tak oczywistą sprawę, aby był w odpowiedniej ilości, czyli takiej, aby zachowana była równowaga tonalna całości - kwestia: sprzęt gra za szczupło albo zbyt przytłaczajaco dołem, czyli za grubo). Gdy ustawi się duże podłogówki w małym pokoju, jest zbyt duże ryzyko zamulenia dźwięku, czyli oczywiście bas będzie, będzie cieplej, ale znikną kontur, barwa i wykop i moze być męcząco.
Aha, co do podstawek, to polecam alternatywę, czyli podwieszenia takich monitorków do sufitu :) - oczywiście sznurkami na tyle długimi, aby wisiały górną krawędzią skrzynki góra 90 cm od podłogi. Jak się dobierze ładne cieniutkie sznurki (na przykład takie do kupienia do wieszania prania), albo po prostu łądne i sprytnie się zamocuje, to efekt wizulany fenomenalny zjaebisty. Problem, że dźwiękowy niepewny, przykładowo Eltaxy i Tannoye w to wchodzą (lepszy bas i efekt znikania), ale z dużymi moniotami (szczególnie o obudowie zakmniętej) albo z membraną bierną, to nie wychodzi, znika twardość dołu i wogóle dół (czyli przykłądowo z tymi Infinity to raczej nie wyjdzie).
A tak w ogole czy mozna komus doradzac wybor kolumn?
Przeciez kazdy ma inny gust. Trzeba samemu odsluchac kilka zestawow kolumn i wybrac ten ktory odpowiada.
Ja mam Eltaxy 6.3 i jestem zadowolony, ale komus innemu w tym samym pomieszczeniu lepiej pasowaly by Tannoye lub Quadrale itp...
tomeus, 7 Cze 2007, 23:15
>Potrzebuje ładny bass bo słucham głównie albo techno albo rocka, musi być zaznaczony tam
>gdzie ma być a nie ryczeć cały czas.
O tym już autor wspomniał ;-)
To odwołuję Soniaki :)
Bierz Eltaxy, zaoszczędzisz 200 stówy conjamniej względem Tannoy M2, a skrzynki nawet może i lepsiejsze. Muzyka zagra a i bas Cię zadziwi :).
>Chruper, 8 Cze 2007, 21:01
>...co do podstawek, to polecam alternatywę, czyli podwieszenia takich monitorków do sufitu :) -
>oczywiście sznurkami ...
>z dużymi moniotami (...) albo z membraną bierną, to nie wychodzi...
Można by dodać stabilizatory żyroskopowe ;-).
Jestem Europejczykiem.
Albo poszukaj monitorow Alesis. Jesli szukasz ze wzmacniaczem - moga Ci sie spodobac aktywne M1 Active Mk2 - odpada Ci w tym momencie szukanie wzmacniacza. Ostatnio akurat kolega kupil na ebayu za ok 780 zl (uzywane).
Jeśli libery 1+ grają tak ładnie, to te też powinny, tyle że moc większa.
Czy lepiej mi podstawki ? Bo od czasu do czasu oprócz słuchania muzyki chciałbym urządzić jakieś domowe party :P i boje sie że podstawki nie uciągnął
Jeśli chodzi o techno w takim pokoju to najlepiej tannoy F2 bo za 800zł to możesz nówki kupić (ewentualnie M2 używane jeśli znajdziesz do 500zł, bo więcej to już nie warto za nie dać). Do tego wzmacniacz Yamahy albo Sonego. Za 800 zł raczej lepszych kolumn do tej muzyki nie kupisz.
tomeus =>
możnaby i rzeczywiście lepiej zniosłyby imprezę. Swego czasu byłem taki sprytny, że spaliłem dwa rózne modele 1+ (wyoskotonówki sa wrażliwe na przeciążenie, ale można w szeregu wstawić termistor dla wysokiego i po sprawie) - 120 watowy wzmacniacz, brak słyszalnych kompresji na skrzynkach przy rozkręcaniu wzmocnienia, zapomniałem się i . . . a to na imprezach się zdaża, czyli ryzyko istnieje, ale termistor dobre rozwiązanie :) , ale pomyśl o czymć takim, że 3+ to dosyć głębokie skrzynki, z bassrefleksem z tyłu, czyli wymagają conajmniej 20-30 zm tyłem skrzynki od ściany, czyli wyobraź sobie czy masz na nie miejsce. Wyjdą Ci na środek pokoju, pod ścianą ich nie upchniesz. Jeżeli już sie uprzesz na podłogówki, to suzkaj z rurą z przodu, albo starszych podłogówek, które miały często bass refflesky strojone bardzo nisko i założoną kompresją objętości na rurze - one nawet lubiły upchnięcie pod ścianą.
A co sądzicie o seri SYMPHONY 6.3 lub 8.3. Nadadzą się ? Słyszałem że dźwię jest troche bez koloru, ale jest czysty może grać głośno i ma dobry wykop. Ma ktoś je ?
