Brak humoru na forum | Dobre dowcipy... | Żarty
fajne ćwiczenia na zgrabną figurę dla forumowiczek...
niezły wkręt na telefon
Znalezione na drzwiach pewnego profesora...
Certification examination
Instructions: Read each question carefully before you select the two questions you wish to answer. Of the possible 16 questions, answer only two. When the instructor tells you to begin, turn your test paper over and begin. You will have one-half hour to complete your test.
Questions
1. HISTORY: Describe the history of the papacy from its original form to the present day. concentrating especially but not exclusively on its social, political, economic, religious and philosophical impact on Europe, Asia, America and Africa. Be brief, concise and specific.
2. MEDICINE: You have been provided with a razor blade. a piece of gauze, and a bottle of Scotch. Remove your appendix. Do not suture until your work has been inspected. You have fifteen minutes.
3. PUBLIC SPEAKING: 2,500 riot-crazed aborigines are storming the classroom. Calm them. You may use any ancient language except Latin or Greek.
4. BIOLOGY: Create life. Estimate the difference in subsequent human culture if this form of life had development 500 million years earlier, with special attention to its probable effect on the English parliamentary system. Prove your thesis.
5. MUSIC: Write a piano concerto. Orchestrate and perform it with flute and drum. You will find a piano under your seat.
6. PSYCHOLOGY: Based on your knowledge of their works, evaluate the emotional stability, degree of adjustment, and repressed frustrations of each of the following: Alexander of Aphrodisias, Ramses II, Gregory of Nices, Hammurabi. Support your evaluation with quotations from each man's work. making appropriate references. It is not necessary to translate.
7. SOCIOLOGY: Estimate the sociological problems which might accompany the end of the world. Construct an experiment to test your theory.
8. MANAGEMENT SCIENCE; Define management. Define Science. How a they relate? Why? Create a generalized algorithm to optimize all managerial decisions. Assuming an 1130 CPU supporting 50 terminals, each terminal to activate your algorithm, design the communications interface and all necessary control programs.
9. ENGINEERING: The disassembled parts of a high-powered rifle have been placed in a box on your desk. You will also find an instruction manual printed in Swahili. In ten minutes a hungry Bengal tiger will be admitted to the room. Take whatever action you feel appropriate. Be prepared to justify your decision.
10. ECONOMICS: Develop a realistic plan for refinancing the national debt. Trace the possible effects of your plan in the following areas: Cubism, the Donatist controversy and the wave theory of light. Outline a method for preventing these effects. Criticize this method from all possible points of view.
11. POLITICAL SCIENCE: There is a red telephone on the desk beside you. Start World War III. Report at length on its socio-political effects, if any.
12. EPISTEMOLOGY: Take a position for or against truth. Prove the validity of your position.
13. PHYSICS: Explain the nature of matter. Include in your answer an evaluation of the impact of the development of mathematics on science.
14. PHILOSOPHY: Sketch the development of human thought; estimate its significance. Compare with the development of any other human thought.
15. GENERAL KNOWLEDGE: Describe in detail. Be specific and objective.
16. EXTRA CREDIT: Define the Universe; give three examples.
:)) ciekawe czy u nas by zatrzymala policja za taka tablice
ciekawe co by powiedzieli w sklepie z dewocjonaliami ?? :D
michal
Światowa wystawa sprzętu komputerowego w Berlinie. Na stoiskach najwspanialsze osiągnięcia znanych firm. Szlagierem jast najnowszy procesor Intela o częstotliwości 3,3 gigahertza AMDX Atlon XsuperP wielkości główki od szpilki. Dla zademonstrowania jego walorów organizatorzy przeprowadzają publiczne testowanie wszystkich dostępnych na wystawie procesorów i nagle okazuje się , że dużo lepsze osiągi ma produkt z maleńkiego stoiska gdzieś w kącie sali targowej, należącego do mało znanej firmy „diora” Sp.z o.o. z Lubartowa. Sprawdzają jeszcze raz. No nie da się ukryć, procesor z „diory” jest o niebo lepszy i szybszy od innych. Naukowcy z Intela łapią się za głowy. „ Może to jakaś sztuczka ?” Ściągają ze swoich laboratoriów najlepszy na świecie mikroskop elektronowy. Wkładają w niego procesor z „diory” , jeden z naukowców spogląda przez okular i zamiera w bezruchu. Potem powoli prostuje się, odwraca się do reszty inżynierów elektroników i zbielałymi wargami mówi :
- Panowie ku*wa, nie uwierzycie. On jest lampowy.
Hicior na czasie, czyli ZIZU w akcji
"I am an audiophile"
Nie wiem, czy oglądaliście wczoraj "Szkło kontaktowe" na TVN24, ale była świetna scena, w której dwie kaczki się obdarowały, wyglądało to przezabawnie ;-)
ciezko powiedz co jest bardziej zabawne: przedmit aukcji, zdjecie gostka na dole czy tak ogromne zainteresowanie kupujacych.
Butelka - "Nie działa mi dekoder Telewizji TRWAM" ->
Zaloguj się, aby zobaczyć treść (możliwe logowanie za pomocą ) ;-D
Nie działa mi dekoder Telewizji TRWAM jest super.
Trochę mogli by popracować nad solówką która zaczyna się fajnie a potem "kiepścieje"
ale pomysł i wykonanie jest super.
pzdr
zmiana ramówki w TVP
najlepsze to;
"Rzuć na tacę" - magazyn ekonomiczny
"Herbatka u Tadka" - luźne dywagacje z Torunia na temat bieżącej sytuacji politycznej
"Zwal zboże na tory" - program rolniczy w niedzielę
"M jak Maria" - serial o Marii Magdalenie
"Od wałacha do Maybacha" - magazyn motoryzacyjny
"Woda czy wino" - magazyn poranny
"Moda na sutannę" - jedyny zagraniczny serial USA
A świat się śmieje... ->
a oto filmiki z ostatniej imprezy w bielichach
w roli glownej bansujący pan Kajok:D:D:D:D:D
zwala polecam
ps.ma facet wyczucie rytmu:D
cos ala "Dżon trawolta"
Facet jak facet ale ten glos pani nagrywajacej filmik - to jest jak dla mnie lepszy numer(ek). Moglaby u Prince'a zrobic kariere - patrz plyta 'Come' - ostatni kawalek ;-)
pzdr
soso
tu też filmik - specjalnie dla ministra Giertycha, i jego taty, i jego dziadka...
muzyka łagodzi obyczaje
