Nagrody EISA AWARDS 2006/2007 rozdane..
Pixeel
Nagrody EISA AWARDS 2006/2007 przyznane...
EUROPEAN AUDIO PLAYER
Marantz SA7001
The Marantz SA7001 is a disc player dedicated to music for stereo lovers, able to read Compact Disc and the two-channel layer of Super Audio CDs. The construction of this product is taken seriously – its drive mechanism is carefully isolated against vibrations with a decoupled chassis, and the output stages use exclusively discrete components enclosed inside a Marantz current-feedback HDAM module. For digital-to-analogue conversion, it uses the same 24/192 ‘Super DAC’ as fitted to the more costly SA-15. This player brings a superb and realistic sense of life to the music – the stereo image is well-focused, high frequencies have good definition and midband is magnificently warm and smooth.
https://www.audiostereo.pl/topic/27637-nagrody-eisa-awards-20062007-rozdane/
EUROPEAN TURNTABLE
Pro-Ject RPM 9.1
Despite its stylish look, the Pro-Ject RPM 9.1’s performance is far ahead of lower-priced trendy turntables which are appearing during this renaissance of pure analogue hi-fi. The heavy construction consists of a rigid high-gloss finish plinth, topped with a thick platter of clear acrylic. Both materials fit perfectly together in terms of sound and reduce resonance. To keep unwanted noise away from the chassis the motor is built in an external housing. It drives the platter via a soft rubber belt. In addition, the one-piece carbon-fiber tone arm can handle a wide range of quality cartridges, and offers high stability with low mass. Quality features such as the high-precision platter bearing deliver a convincing, dynamic and natural sound from your beloved vinyl.
EUROPEAN TWO-CHANNEL AMPLIFIER
Denon PMA-1500AE
It’s not everyday that we see a company launching a stereo amplifier of audiophile quality so the Denon PMA-1500AE is a very welcome addition for all consumers who strive for the best quality in two-channel reproduction. The output power of 140W per channel into 4 ohm should be enough for even the most demanding loudspeakers, thanks to the use of latest generation UHC MOSFETs at the output stage and a leakage canceling power supply transformer. Bandwidth extends to 100kHz and the full set of inputs includes Phono for easy integration with a turntable. It's not easy to find anything comparable at this price level, when one has in consideration build quality and the neutrality and transparency of the reproduced sound.
EUROPEAN LOUDSPEAKER
B&W CM1
B&W's CM1 is a masterpiece in the audiophile class of mini-monitor loudspeaker. Physically small but big-hearted, the CM1 plays music with passion, having a full-bodied bass with fresh, clean and sweet highs. The acoustic concept is based on a minimalist first-order crossover using a carefully selected high-grade capacitor, united to the now-familiar B&W Kevlar and aluminum diaphragms drivers, here tuned to work at its optimum with the purer type of filtering. And the look of CM1 perfectly suits its sound – a simple, traditional shape of box, beautifully finished in natural veneers in fashionable colors, with polished aluminum rings to complement its drive units. The CM1 gives more than a touch of high-end quality at a comparatively modest price.
EUROPEAN HIGH-END AUDIO PRODUCT
Linn MAJIK System
With the Majik System, comprising a CD player, KONTROL pre-amplifier and 2100 power amp, Linn gives a clear statement for the traditional enjoyment of two-channel music. In this new series, classic yet at the same time modern, sonic and engineering aspects combine perfectly with housings of elegant design and solid craftsmanship. Convenience to the user is delivered by the intelligent link between units, all under the control of a single remote handset. A big plus is the option to integrate the MAJIK components into a Linn multi-room system with nearly unlimited possibilities. Vinyl lovers will find a newly-developed, excellent sounding phono input for MM or MC cartridges. Linn’s “majikal” trio is real “high-end” from every point of view, despite its reasonable price point. Don’t let the minimalist look mislead you. The Linns reveal the pure magic in music.
EUROPEAN HIGH-END LOUDSPEAKER
Jamo R 909
With the sculptural R 909 speaker, Jamo’s development engineers have demonstrated what they are capable of delivering, when cost is no object, and only the best components and materials are good enough. The R 909 is among very few speakers that work without a box enclosure, which normally makes it difficult to reproduce low frequencies. So, a pair of high-efficiency 15-inch bass drivers and an ingenious crossover is Jamo’s response to this challenge, and since there is no ordinary box-generated resonance, the R 909’s sound is free of cabinet coloration, stunningly unrestrained, crisp and dynamic. This large speaker comes with an exemplary finish and superior attention to detail – an impressive “high-end” statement, which deserves the best amplifier that a demanding music lover can afford.
EUROPEAN COMPACT SYSTEM
JVC EX-A10E
The design of this micro system not only attracts the eye with its aesthetics but also the ear with its impressive audio performance. The brushed aluminum finish of the main unit is matched to bi-amplified wood-cone speakers, optimized by having separately-powered tweeters and mid/bass drivers. Capable of filling a small room with sound, this system includes many modern functions, not only playing CD and DVD discs, but it’s also able to read MP3, JPEG and WMA files. To enhance sound quality further, the system uses JVC’s K2 technology for both uncompressed and compressed sources, giving a flavor of high-resolution sound. This JVC micro system has the best acoustic performance that you can find in its price category.
żródło, oraz pozostali nagrodzeni:
Pixeel
>Marantz SA7001
Sluzyl niedawno jako zrodlo przy odsluchu Triangle Altea w Top Hi-Fi. Brzmienie niczego sobie. Gorzej z ergonomia, zastanawiam sie na czym poprzestana projektanci w niepohamowanym pedzie do miniaturozyowania przyciskow.
Czytalem niedawno wywiad z K.I. w którym stwierdził ze "duzi" szykują powrót do stereo. Okazuje się, iż chociaż dużo osób kupje KD to jednak rzadko która ze względów praktycznych decyduje się na instalację 5+1. Z reguły są to instalacje dwukolumnowe. Nawet bez centralnego lub suba. W związku z tym segment dwukanałowy ma być dominujący. Tak twierdzi Ken ;-)
lolo, 18 Sie 2006, 10:16
No to juz w relacjach z Monachium byla mowa o powrocie do stereo, ilosc wystawcow z tego segmentu po raz pierwszy od lat zwiekszyla sie. I bardzo dobrze imho.
Tak naprawdę to gęste formaty typu SACD który wygrał w tym roku i praktycznie już tego wszyscy wystawcy się trzymają, czy DVDAudio od początku były stereofoniczne (referencyjne płyty stereo 24/192 i podobne stereo SACD), natomiast płyty g este wielokanałowe to fajna sprawa, ale trudna i kosztowna w realizacji. Możemy cieszyć się hiendem wielokanałowym w postaci AERO Jarra czy Dark Side Floydów, ale nie myslmy że tak drogich perełem bedzie masa. Lepiej żeby wydawali płyty w doskonałej jakości 24/192 stereo itp. niż by mieli na siłe uprzestrzenniać stare nagrania. Wspomniany Dark Side od początku nagrany był i wykonywany na koncertach przestrzennie, stad tak doskonała jakość tej płyty w wersji surround, natomiast wersje surround Police itp to w wiekszosci ciekawostki i fajna zabawa. Natomiast mysle ze wszyscy czekamy na doskonałe realizacje stereo SACD/DVDAudio i za to brawa dla Denona i innych firm, które rezygnując z produkcji starodawnych odtwarzaczy CD zmuszają producentów płyt do zaprzestania produkcji starodawnych 16 bitowych płyt CD.
  • 11 miesięcy później...
podobno są już wyniki na 2007/2008
cd Pioneer Cd-06
integra CA 840
itd....
Gość rochu
privaten>
A niby kogo mają realizować? Dodę czy Mandarynę?
Prawie wszyscy wielcy są już piętro wyżej na niekończących się wakacjach.
Nikt już nie powtórzy kilku sesji Milesa, nie zagrają Zeppelini, nikt nie wyciągnie z grobu Janis Joplin.
Zastanów się czy to tak dobrze jak sam mówisz i puknij się w czoło - byle mocno.
są jeszcze wielcy ! np lada dzien bedzie nowy studyjny album Bruca "Bossa" Springsteena wraz z E-Street Band ! dzis w stanach ma sie ukazac singiel promujący to wydawnictwo . Mysle ze facet pokarze jak zawsze jak sie gra w wieku 58 lat !
