Hi-endowe nowości
cir=>
To tak jak z sieciówkami - czyli płacisz za efekt końcowy ;-)
Nie ważne ,że budowa jest prosta jak budowa cepa , materiały tanie jak barszcz ............
Ja uważam ,że 100$ to trochę za mało ,polakierować z 10 razy ,dorobić ideologię,
że ręczna robota, że kapitalnie wykonane ,mała seria, gwoździe kriogenicznie "wygrzewane" itd..............
I myślę ,że 500$ ....... mona krzyczeć
nowe kolumny Pioneer TAD R1 i Fostex G2000
SACD player Luxman D-08
nowy zestaw Denona
SACD player DCD-SX i wzmacniacz PMA-SX
szykuje sie nowa integra Krell`a S-300
Mniejsza moc niż w 400xi ale za to wejście dla iPoda i wbudowany DAC. Chyba znak czasów.
・ Employing a massive 750 VA toroidal transformer and 38,000 microfarads of capacitance, the
  S-300i sets the performance standard for integrated amplifiers.
・ At 150 Watts per channel into 8 Ohms and 300 Watts per channel into 4 Ohms the S-300i is
  built to meet the demands of today's latest loudspeaker technology.
・ A KRELL Class A, direct coupled design, fully balanced preamplifier circuitry utilizing KRELL
  Current Mode topologies provides unequaled signal bandwidth.
・ Direct coupled circuitry eliminates impact-robbing capacitors from the signal path ensuring
  the preserva-tion of the audio signal.
・ Unique for the category, the S-300i taps audio from the fully differential output included in
  the internal DACs of an iPod/ iPhone and maintains this balanced signal throughout the
  circuitry. A direct iPod connectivity cable is provided.
・ The S-300i has balanced, single-ended, and iPod inputs. KRELL Theater Throughput mode is
  assignable to an input, allowing simple integration into a home theater system.
・ A new menu system, adjustable via the custom-machined volume control or remote control,
  allows personalization of input labels, volume gain and bal-ance settings as well as several
 other functions.
・ The included solid aluminum remote control replicates all front panel options as well as
  providing control for a connected iPod/ iPhone. The S-300i also has 12volt trigger input/
  output, RS-232 and RC5 capabilities.
・ WBT binding posts are incorporated, providing superior loudspeaker cable terminations. The S-
  300i is also rack mountable with included rack ears
・ Available in brushed aluminum silver finish only
・Stereo Integrated Amplifier
・150 W, 300 W (8, 4 Ohms)
・750 VA toroidal transformer
・38,000 microfarads of capacitance
・Krell Current Mode
・RS-232, RC-5, 12 VDC Triggers
・Discrete Balanced Class A Input Stages
・Direct iPod Connection with Balanced Circuitry
・43.82 W, 10.16 H, 44.45 D cm
FM ACOUSTICS Resolution Series FM 1811
€125000
Piwo dla tego kto zobaczy we wnętrzu te 125.000 EUR !
Gość Paweł Skurzewski
JarlBjorn, 6 Lis 2008, 14:49
>Cos wiecej o tej integrze Krella??
>Cos czuje ze trzeba bedzie szykowac pieniadze
Ale dlaczego?bo jest srebrna,ma gałę na środku i napis KRELL?Co takiego czujesz?
P
nowy SACD player Luxmana robi wrażenie... szkoda że nie jest tańszy;)
Świat się kończy - miniwieża McIntosha !
McIntosh new MXA60 "Executive System", scheduled for availability in the third quarter of 2009. This will be McIntosh's first tabletop integrated audio system.
Ciekawe, czy wtyki Oyaide wysadzane kryształami, na zdjęciu parę wpisów wyżej, spełniają wymogi dyrektywy RoHS? Jeśli się nie mylę, kryształ w odróżnieniu od zwykłego szkła zawiera ponad 20% ołowiu ;-)
Na CES 09' jest premiera najnowszych glosnikow Avalon Acoustics - Aspect. Moze ktos z forumowiczow (Elberoth:>), wybierajacych sie na wystawe moglby zrobic fotke?
Najnowsze Avalony Aspect. Brzydkie jak noc.
Nowy "budżetowy" odtwarzacz CD Wadia 381 @ $6,950
Nowy wzmacniacz cyfrowy dopasowany do iTransportu - Wadia 151 @ $1000
Nowy DAC/pre - Wadia 121 @ $1500
Najnowsze Audio Aero La Source @ $30.000
Zasilacz impulsowy, drive Esoteric VRDS-NEO i brak lamp na wyjściu.
