Primare Prisma NP5
Ktoś posiada?  Jakieś porównania z digione signature, pi2AES lub innymi plikowcami ?  Ogólne wrażenia?
Edytowane przez MrSalieri
https://www.audiostereo.pl/topic/147189-primare-prisma-np5/
Jeszcze nie. Ja dostanę lada dzień , zamówione w tej promocji i zapłacone. Czekam na informacje ze sklepu o terminie wysyłki.
A tak na marginesie, zobaczcie co mi odpisali . Jak zadałem im pytanie o kulawo działające apki na androida i IOS.???
We have confirmed that with the latest Android and Apple operating system updates, and the enactment of GDPR privacy protocols, have resulted in serious malfunctioning of both our APP and AIR applications for PRE60, NP30, I32 MM30 and PRE32 MM30.
As our development team worked to finalise the new Prisma application and related technologies it became clear that an update to the existing APP and AIR control applications would simply not allow those customers using our past control and connectivity technology to incorporate all of the features possible with the Prisma platform.
As a result, the NP5 Prisma network player and update campaign was developed to provide existing customers with an unprecedented update opportunity to incorporate latest streaming features (see attached "NP5 Prisma Update Program" document for more details).
However, it is understood that some customers may not wish to take advantage of this opportunity. If that is the case, we recommend the use of readily available DLNA/UPnP control applications.
We have experience, and can recommend the following, having found them to be stable, easy to setup, and work well with our products, while also providing not only embedded TIDAL, with MQA, and Qobuz music services, but also Chromecast connection and control.
Edytowane przez paul klacska
33 minuty temu, rambo54 napisał:
A to już dostępne?
Widziałem w ofercie jednego sklepu ale doczytałem o pierwszych dostawach z początkiem listopada.  W takim razie trzeba będzie poczekać.
Myślałem o tym odtwarzaczu jako następcy dla wykorzystywanego do tej pory mojego Auralica MIni. Problemem jest jednak wykorzystanie Chromecasta. Nie wiem czemu ale to rozwiązanie nie działa stabilnie w niektórych sieciach światłowodowych. Przerabiałem to u siebie w UPC. Rozmawiałem z gościem ze sklepu, potwierdził występowanie tego problemu. Jak zachowa się ten Primare? Trzeba będzie przetestować. Choć na szczęście mi się nie pali i poczekam na aktualizację aplikacji sterującej.
Widziałem, że w swoim "o mnie" masz wpisane to urządzenie.  Między innymi dlatego pomyślałem, że jest już dostępne w sprzedaży.
Takie mam info ze sklepu, możliwe że już leży na poczcie. Jestem na urlopie,wracam za tydzień do Norge. Rozwaliłem swój telefon i nie mam informacji o wysłanej przesyłce do mnie w aplikacji.
Info ze sklepu:
Supert! Vi bestiller opp en batch for levering ca 1. Nov.
Jørgen
W Polsce zaraz na początku listopada będziemy mieli pierwszą dostawę, zapraszam serdecznie na odsłuchy, prezentacje, będziemy mieli urządzenia z pierwszej dostawy.
A czy wiadomo jaki prąd potrzebuje to cacko? Pytam, bo to da mi odpowiedź czy liniowiec który posiadam na wypożyczeniu go zasili.
A mogę zapytać, jaki to liniowiec?
Keces P8. Kurczę i już widzę, że NP5 to 5V - czyli ta wersja co mam na testach nie pasuje. Nic to docelowa będzie pasowała (oczywiście jak NP5 będzie pasował mi dźwiękowo ? )
11 godzin temu, rambo54 napisał:
Kupie by porównać z Usbridge Sign.
To czekamy na porównania. Ja też będę chciał posłuchać to urządzenie w dwóch systemach.
Będzie na rynku kilka urządzeń do wyboru. Malina z digione,  pi2AES,  prisma NP5.
Ja też biorę jak tylko znajdę chętnego na wypożyczenie. Coraz poważniej chce swojego squezebox wymienić na coś co nie kosztuje w okolicach 8tys a gra lepiej na razie z marnym skutkiem. Jak to się nie sprawdzi to pozostaje ostatnia nadzieja malina.
Nie rozumiem skąd bierze się poruszenie dotyczące tego sprzętu. Trudno to nazwać pełnoprawnym transportem skoro jedyna opcja sieciowa, poza BT i AirPlay, to Chromecast - a więc nawet nie ma gapless. Roon Ready jest dopiero w zapowiedziach. Przecież Malina czy Allo Sparky to przy tym szczyt elastyczności i funkcjonalności. To samo SOtM, Sonore, Project czy mała Waversa.
W kontekście możliwości cena 2 tys. to jakiś żart.
a jaką masz alternatywę do 2-3tys pln mogącą konkurować z malina z dobrym HAT'em (np. Allo Sign) ?
Edytowane przez h3x_Lukasz
Podałem 4 - wszystkie w podobnej cenie i o lepszej funkcjonalności. Jest jesze NuPrime Omnia. 2 razy droższy ale ma DLNA/UPnP i nie potrzebuje zasilacza.
Omnia może być też serwerem DLNA/UPnP - więc teoretycznie sprawę może załatwić MConnect Controller i dysk USB. Czy to działa w praktyce - to inna sprawa ale to samo można powiedzieć o Primare, który z takim SBoosterem będzie kosztował niewiele mniej.
Wszystkie które podałeś posiadają tylko USB.  A gdzie RCA/ BNC?  O AES już nie mówię. Także są to dość konkretne przykłady pod konkretny interfejs.
Malina z digione,  pi2AES,  czy prisma NP5 oferują jednak teoche więcej.
Digione signature gra lepiej.  Sprawdzone ?
No niestety wszyskie są ciekawe i sotm słuchałem i było dobrze ale wszystko ma wyjście USB a ja mam dac bez USB. Dac mi brzmieniowo odpowiada więc nie opłaca mi się wymieniać i wydawać 2x tyle za podobnej klasy dac z USB. No chyba że podłączyć pod konwerter hiface evo. Na razie squezeboxa nie widzi po USB więc z innymi problem może być podobny.
Edytowane przez antymalkontent
Ja mam cienkie USB w swoim przetworniku także nie nastawiam się na taki rodzaj połączenia.  Interesuje mnie BNC/RCA a najlepiej AES/EBU.
Prisma ma może więcej wyjść - ale jak z tego słuchać własnych plików? Wychodzi na to, że wydajesz 2 tysie na Prismę i minimum dwa razy tyle na Roon, serwer pod Roon i zasilanie. We wszystkich innych rozwiązaniach Roon nie jest konieczny.
Dlatego chcę poczekać z odsłuchem NP5 do momentu certyfikacji roon ready bo tylko takie urządzenia mnie interesują.
Piętą Achillesową tego typu urządzeń jest przeważnie aplikacja sterująca.
Jedynie Waversa Wstreamer posiada USB i RCA.
Z Prisma da się słuchać też bezpośrednio plików podpinając się pod USB. Dodatkowo Prisma też jest UPnP/DNLA i możesz nią sterować z mconnect czy BubbleUPnP. Sam producent podaje w dokumentacji na stronie alternatywy do sterowania ich produktem.
Dlatego oprócz NP5 trzeba będzie kibicować też Pi2aes ? .
