Amplitunery z hdmi 2.1 gruba wtopa?
Jak to
Okaże się prawdą to grubo ...
https://www.audiostereo.pl/topic/152573-amplitunery-z-hdmi-21-gruba-wtopa/
We are currently investigating the issue further and will offer a permanent solution at a later date. Meanwhile, we would like to provide a couple of workarounds to prevent the issue in its current state:
 You can connect the system to the display directly via HDMI and use the display’s ARC/eARC functionality to feed the native audio back to the AVR using the connected HDMI cable between the AVR and display. This will allow users to decode the native audio format sent from the source. With this method, the display’s CEC/ARC option must be enabled as well as the AVR’s HDMI Control and/or the AVR’s ARC option. In the AVR, this option is located within the GUI under “Video – HDMI Setup.”
 Another workaround is to leave or change the source’s video output to 4K/60Hz instead of 4K/120Hz until a permanent solution is available. This will ensure reliable communication between the source, the AVR and the display. The source’s default is set to output at 4K/60Hz, so if no change was initiated out of the box, then nothing further needs to be done.
We apologize for this inconvenience and we are currently working tirelessly to release a permanent solution so you can enjoy the 4K/120Hz experience using the latest sources with your AVR. We will have an update soon regarding the timeline of a permanent solution. We appreciate your patience.”
W kilku słowach tak jest problem, podłącz pan xboxa do tv a dzięki earc będziesz miał dźwięk albo ustaw sobie obraaz w urządzeniu na 4k ?
Badamy problem i damy znać..
I co? teraz wyjdzie może ze onkyo/pioneer nie wypościli amplitunerów bo wiedzą o problemie? kto wie kto wie....
Może nie będzie tak złe będzie akcja serwisowa i wymienią płyty każdemu.
Beka, a mialem w październiku kupic zestaw heco victa prime 5.0 i denon x2700 i cale szczęście mam póki co inne wydatki i zakup przełożyłem na nowy rok.
Ja 2 msce temu kupiłem Denon X3700H, jak i pare osób na forum, ciekawe czy każdy egzemplarz ma ten problem czy tylko wybrane, ktoś doczytał?
Te chipsety są chyba też w nowy Xbox series X i kartach Nvidii tak?
Ciekawe gdzie jeszcze
edit:
Update 1: It seems the problem is specific to XBOX Series X and NVIDIA graphicscards. PS5 should work, but is not proven. Problem stems from different implementation how the data is transfered. Thats why ps5 seems to work and xbox/nvidia not.
Że PS5 niby działa, ale to chyba trzeba spokojnie zaczekać na jakieś oficjalne info i potwierdzenie, bo PS5 mogło chyba tylko samo Sony do tej pory testować
Zaloguj się, aby zobaczyć treść (możliwe logowanie za pomocą ) Edytowane przez Fanek
Raczej trudno przypuszczać żeby Sony poszło w stronę skompresowanej wersji - obstawiam, że każdy wybrał maksymalną jakość, zatem nieskompresowaną.
Problem mają tylko te, które długo śmierdziały po zakupie ?
17 godzin temu, bl4ck napisał:
Jak to
Pierwszy raz coś nowego nie działa? Problemy wieku dziecięcego. Nie ma co panikować, naprawią i tyle. Większym problemem są usterki w samochodach, które wywołują pożary albo inne gnioty zagrażające życiu.
Sorki ale nie do końca się z tym zgodzę. Jak długo mamy być królikami doświadczalnymi, na rynek w pośpiechu jest wydawane coraz więcej bubli i mamy mówić, że nic się nie stało? Przepraszam ale ja na takie coś się nie piszę. Widać wyraźnie parcie na kasę i nic więcej. Tu mamy uwalone hdmi, tam mamy uwalone nowe karty nvidii, gdzie indziej żyjący swoim życiem soft do najnowszej wersji sprzętu Arcama. Co to kuźwa ma być ? Jajko niespodzianka.
Już nie wspominając o telewizorach bo wypuszczają co rok tylko żeby wypuścić, tam to są buble z oprogramowaniem.
Edytowane przez bl4ck
Zgadzam się z Tobą, że wielkie firmy tak działają i ogólnie rzecz biorąc sprzęt jest coraz "gorszy" ale uwalone HDMI to nie koniec świata. Myślę, że dla tych firm to nie jest najlepsza wiadomość. Koszty poniesione przez taką akcję serwisową będą bardzo duże + koszty prawne aby się z Panasonikiem wykłócić. Więc skok na kasę się zemści.
Tak czy inaczej dalej uważam, że są gorsze konsekwencję błędów produktowych gdzie zagrożone jest ludzkie życie a nie, że nie mogę odpalić 8k na TV przez ampli ?
No wiesz, nie po to się sprzęt kupuje by zaraz biegać z nim po serwisach. Moje dwa ostatnie przypadki to PS4 i tzw. niebieska dioda śmierci. Konsola po wyjęciu z pudełka i podłączeniu do sieci wywaliła błąd. Mina dziecka w wigilijny wieczór bezcenna, syn już nie chce nawet słyszeć o konsoli Sony do dziś. Tu skończyło się fajnie, Sony wymieniło konsolę. Oczywiście padła po okresie gwarancyjnym po wgraniu nowszej wersji firmware , ale to już szczegół. Drugi przypadek, zakup bluray Yamahy, uwalony napęd. Serwis powiedział, że to moja wina. Sprawa załatwiona dopiero przez adwokata. Tak więc pogoń za królikiem przestała mnie interesować już jakiś czas temu.
Wiem co Twój syn czuł bo byłem w podobnej sytuacji jako dzieciak. Dla ojca kupienie PS2 było już wydatkiem, konsola przestała działać jeszcze w czasie gwarancji, Sony nie uwzględniło... naprawiliśmy na własny koszt... nawet teraz jak o tym wspominam to jest mi przykro bo byłem dzieciakiem i było to dla mnie cenne urządzenie w tamtym czasie.
dlatego ja kupuję używane stare klocki na ile jest to możliwe. Nowe kupuję tylko to co nie da się kupić używane i musi być w miarę na te czasy (TV, komputer). Wszechobecna tandeta w elektronice jest zatrważająca, Tym bardziej, że w elektronice NIE MA SIĘ CO ZEPSUĆ!
Ze sprzętów nowej ery najdłużej działający w stosunku do ilości przepracowanych godzin był biały macbook z 2006 - działał mi ponad 13 lat, używałem intensywnie przez 11. Pewnego dnia się nie uruchomił, bylem smutny ? ale nie zły.
Ze sprzętów starej ery to używam tunera z końcówki lat 70. Używany od ponad 10 lat kilka godzin dziennie - działa dalej. Mam też 20 letni wzmacniacz kina domowego i też działa u mnie chyba z 5 lat. Flagowy japoński produkt - dobra konstrukcja, podzespoły najwyższych lotów i też działa.
Absolutnie nie bronię producentów bo nie mam w tym interesu ? po prostu - chyba - się już z tym pogodziłem.
co do gwarancji, wg mnie dla wielkich marek Polska to nadal 3 świat. Jesteśmy młodymi konsumentami i mają nas w d. Nie potrafimy walczyć o swoje.
Edytowane przez PawelMitsu
Update from GROBI.TV regarding HDMI 2.1 issue with 4K HDR 120Hz:
"Update. We used yesterday RTX 3080 with Marantz SR 7015 and LG Oled CX in 4k HDR 120 HZ. Itwas buggy, but working. So we think that this combination can be fixed by Update of Graficcard Driver. We made two tries. 10 Days ago direct connection RTX to Marantz to LG 4K 120 HZ - No Problem. Yesterday evening the same but 4K HDR 120 HZ. First try black image, restart of PC and then a picture with no problems. But then while "playing" black image. New start and running again. So we would say, its working, but in the moment not stabil. So its probably a job for the graficcard driver. Here is the Video of the first try - 4k 120 Hz - RTX 3080 to Marantz 7015 to LG GX OLED"
Nie rozumiem tego bełkotu pier.. coś o sterownikach do karty graficznej ale przecież sprawdzali na xbox series X czyli co konsole też mają uwalone sterowniki? co to za partacze to ja nie wiem.
Tak długo nimi będziemy, jak długo ludzie będą kupować takie produkty.
Niestety, ale na to składa się wiele czynników, które wynikają z chęci maksymalizacji zysku.
Pośpiech, żeby zdążyć z nowym produktem przed black friday/świętami/konkurencją. Co rok nowy model, no bo przecież klient chce nowości. Optymalizacja kosztów produkcji (czyt. wyprodukować jak najtaniej) i outsourcing projektowania/produkcji/developmentu oprogramowania. Celowe postarzanie (czasami mocno przegną).
To dotyczy niestety wszystkich branż i większości firm, nie tylko dużych, bo mniejsze też muszą się dostosować, żeby przetrwać na rynku.
Autentyczne zdarzenie: spotkanie producenta pralek z producentem łożysk u podwykonawcy.
Producent łożysk: na jakie obciążenie jest ten element?
Producent pralek: 8kg
PŁ: no to to łożysko jest za słabe, musicie użyć tego i tego
PP: łożysko zostaje. Gwarancję wytrzymuje...
Arcam miał olbrzymie problemy z softem do nowych modeli (już jest dużo lepiej), ale miał je też NAD I inni, którzy chcieli za szybko wypuścić nowości.
Ale już np. taki Lyngdorf opóźnił dostawy nowego modelu o kilka miesięcy, żeby dopracować soft i zdobyć wszystkie obiecane certyfikacje (gdzie taki Arcam do dziś nie ma certyfikacji Roon dla nowych modeli, a NAD dostał ją dla wielu modeli wypuszczonych 2 lata temu dopiero we wrześniu tego roku).
Więc są jeszcze producenci uczciwie podchodzący do sprawy, ale jest ich niestety mało i zwykle ich produkty są droższe od konkurencji.
denon-info-jpg.3055161
lg-cx-hdmi-info-jpg.3055162
windows-display-settings-png.3055163
Ktoś potwierdził że na 3080 i Xbox series X podaje mu obraz i dzwiek w 4k120hz
Wygląda na to, że naprawili ?
A ty zadajesz sobie sprawę że chodzi o 8K a nie 4K?
A nie 4K i 120hz to też był problem, trzeba poszukać czy z tym nie ma problemu też.
38 minut temu, bl4ck napisał:
Jak nie ma na czym a karty graficzne a ps5 xsx?
trzeba mieć tv 8k, ps5 ani xsx nie obsługują w tej chwil 8k60. ps5 ma dostać w przyszłość updejt.
4k120 działa na 3080 i xsx.
  • 6 miesięcy później...
Buga naprawili już jakiś czas temu w firmware dla kart Nvidii i PS5, ale w Xbox series X dalej występuje problem z 120/4k, wypuszczają przystawke którą można zamówić za darmo, wysyłka od 15 maja
