Wysokoskuteczne kolumny HI-END!
Mirek, najlepiej abyś wziął Cary-ego 300B i na miejscu gdzieś u dystrybutora w salonie posłuchał dc10audio Berlin R (reference) z ich elektroniką, jak i ze swoją.
Jest jeszcze trochę droższa wersja Berlin R z głośnikami na magnesach AlNiCo model dc10audio Berlin R AlNiCo
Berlin R Alnico
An upgraded version of the magnificent Berlin R.
Powerful AlNiCo motors in the tweeter and woofer further increase the sensitivity while wire and capacitor upgrades capture even more of the music’s nuance. Berlin R AlNiCo is a peerless stand-mount loudspeaker for peerless source and amplification.
It comes complete with acoustically inert Blade® stands in matching solid one-piece wood (plinth, blade, and screw-down base).
SPECIFICATIONS:
Berlin R (alnico)
• dc10audio's horn-loading system includes AlNiCo V-ring dome tweeter
• Hand-turned horn
• dc10audio internal tonewood resonator
• 8-inch papyrus fiber wide-range driver with AlNiCo motor
• Hybrid crossover (no sound-depleting circuit boards)
• Duelund CAST copper foil capacitor
• 6N solid core cryo-copper wire with an additional wire run in pure silver
• Frequency response: 35 Hz-25,000 Hz (+/-3dB)
• Sensitivity: estimated 98 dB
• Impedance: 8 ohms
• Power handling: 300 watts peak program
• Solid heirloom tonewood baffle (See wood choices)
• Curved braced Italian poplar ply cabinet
• Cabinet option: Match or contrast baffle (See wood choices)
• Size: 21" (53.3cm) high x 13.5" (34.3cm) wide x 17.5" (44.5cm) deep each
• Weight: 52 lbs (24kg) each
Price for pair: $24,495 inc GST (price includes matching blade stands)
Na stronie producenta trochę inaczej piszą :
''Several upgrades are available including turned wood phasing plugs for the woofer, beeswax paper capacitors, drivers with AlNiCo motors.''
SPECIFICATIONS:
• dc10audio’s horn-loading system includes ribbon or textile dome tweeter
• Hand-turned horn
• 8-inch wide band woofer
• 6N solid core copper internal wire in pure cotton dialectic
• Bandwidth: 32 Hz-62,000 Hz (ribbon)
• Sensitivity: estimated 96 dB
• Impedance: 8 ohms
• Solid heirloom tonewood baffle (See wood options)
• Cabinet option: Match or contrast baffle & horn (See cabinet options)
• Overall size: 21" high x 13.5" wide x 18" deep each
• Weight: 42 lbs each
Zaloguj się, aby zobaczyć treść (możliwe logowanie za pomocą ) - Specifications subject to change without notice
Zaloguj się, aby zobaczyć treść (możliwe logowanie za pomocą ) - Price for pair: $18,495 inc GST (price includes matching blade stands)
Jakie głośniki/przetworniki grają w tych obu modelach kolumn dc10audio Berlin R & Berlin R AlNiCo – ktoś wie?
dc10audio Berlin R Reference w systemie ze wzmacniaczem, przedwzmacniaczem i gramofonem od Zontek'a – też nieźle
Nieźle?
Dramatycznie słabo,przynajmniej wtedy kiedy ja słuchałem.
Nie wiem czyja wina,kolumn czy elektroniki :)
Dramatycznie słabo
... czyli jak? ... co tam słyszałeś, że aż tak dramatycznie było:
Dramatu nie odczułem w kategorii podstawkowych kolumn, nie były takie najgorsze, przy utworze który wtedy grano było trochę detalu na wysokich.
Zupełny brak basu,nawet jak na podstawkowce,w średnicy hulał wiatr,
żeby z gramofonu i lampowej elektroniki nie było namacalnego grania,
wyjątkowo słabe to było.
Gdzieś był błąd,i trudno zwalić wszystko na pomieszczenie.
Przy mnie nie grano nic z basem i wokalem, więc o tych aspektach nie napiszę.
''w średnicy hulał wiatr'' - to oznacza że poluzowana średnica.
''zupełny brak basu'' - i jeszcze basu nie mają.
A jak szybkość i detal na wysokich?
Tamten dźwięk i tak był po cieplejszej stronie.
Po co dyskutować dalej,o systemie nie wartym uwagi?
Z pewnością były lepsze oparte o kolumny zgodne z tematem wątku,
choćby u Szemisa,ciekawe głośniki i całościowo świetny dźwięk,spędziłem tam sporo czasu.
Najjaśniejsze (chwilami ostre) i monotonne brzmieniowo były dc10audio Kabuki:
Zaloguj się, aby zobaczyć treść (możliwe logowanie za pomocą ) - też ich słuchałeś? Tam coś w systemie było niedopracowane. Jak już coś bardziej na plus, to może selektywność. I na pewno nie należą do kolumn grających rozmytym przesłodzonym dźwiękiem.
Kabuki również w różnych wersjach są dostępne :
''Upgrade Kabuki's full range driver with AlNiCo or Field Coil motors. Kabuki is available in 8 or 12 ohm impedance and are very easy to drive.''
Nie wiadomo w której wersji grały, bo jak bardziej wypasione to Kabuki Ohaku
Zaloguj się, aby zobaczyć treść (możliwe logowanie za pomocą ) Edytowane przez atlon11
ATLON
Rozmawialem dość dlugo z P.Krauze-to ten gość prezentujacy system i DC10 AUDIO były świeżutkie a gramiak to garard 301w potężnej
obudowie z licha wkladką............to jak to mogło dobrze grać?.........ano nie mogło.
Miałem podobne odczucia.
Dobrze grała jedynie delikatna muzyka akustyczna,reszta słabo.
Jeśli sprzęt był niewygrzany,to szkoda,że dystrybutor to prezentował,
przyniósł więcej szkody,niż pożytku.
Pierwszy raz byłem zawiedziony Audio Tekne.
Mirek, słuchałeś kolumn na starych przetwornikach Goodmans'a: (
Zaloguj się, aby zobaczyć treść (możliwe logowanie za pomocą ) ) Audiom 60 / Midax 650 / Trebax - i jak gra takie zestawienie? ... może dla Ciebie byłyby dobre do Cary'ego 300B pod lekkie bardziej Jazz'owe klimaty ... tak jak lubisz. No chyba że szukasz czegoś bardziej uniwersalnego :-), ale wątpię aby Tobie w starszym wieku gust się zmienił.
Goodmans'y masz tanie jak barszcz:
Przeciez wiesz ze juz posiadam kolumny Goodmans(Twin Axiette 8) teraz jestem na etapie robienia glosnikow wysokotonowych tak ze po swietach beda calkowkicie gotowe i pozostanie tylko zbierac na gramofon i kupowac czarne plyty to ten kierunek w moim audifilskim zyciu.
To sa piekne kolumny wysokoskuteczne, moze w przyszlym roku na AS w Warszawie bedzie mozna je zobaczyc i posluchac z tego co wiem juz dystrybutor jest w Polsce:
Tak wiem że co 3-drogi (3-way) to nie jedna.
Teraz idziesz w dwie drogi i będziesz dostawiał wysokotonowe głośniki. Cóż za głośniki będziesz dostawiał na wysokie?
Toż ten Maxonic był już w tym roku na AVS-ie, ale widzisz że cicho o nim, to wiesz, że ... :-)
...że Wełniany = Rafaell = [email protected]
Ciekawe czy ktoś się domyślił oprócz mnie, że Wełniany to Rafaell :-) ... wiesz u ilu osób Wełniany sobie nagrabił ;-)
Ale chyba nie bylo tego pieknego modelu w tym roku?
Mirek, a jakby inaczej - żałuj że nie byłeś :-) ... w innych SkyBox'ach jak choćby 108 (JBL / Mark Levinson), bo w tym 208 (Natural Sound / Audio Tekne) nie miałbyś czego żałować :D
12122895_1052750241442413_8656636547998400765_n.jpg?oh=a76d4274c760e4e232943efdb385262d&oe=56F236FF
Tu kolega podal ceny w Japoni:
Widze ze stoja cofniete z tylu posrodku,czy graly tez? bo te na zewnatrz stojace sluchalem z tym sprzetem rok temu i byla pelna lipa!
Twoje uwielbione kolumny biale swietnie wygladaja.....
税抜特別価格3,257,100(1pair)
przeliczyc tylko te miliony na zlotowki czy( 1pair) to maja na mysli pare? czy jedna sztuke,bo musze byc teraz uwazny?
Na zewnątrz dc10audio Kabuki grały, a Maxonic-i tylko stały :-)
Project EVEREST DD67000 (Polar White) - świetnie Everesty prezentują się w ekskluzywnych kolorach: Black Gloss, Polar White, Rosso Corsa, Sapphire Blue Metallic, British Racing Green Metallic, Tungsten Silver Metallic, JBL Orange.
Everesty DD67000 w British Racing Green Metallic (tri-color) od razu bym sobie brał gdybym miał z pół baniaka 450 000,00 - 500 000,00 zł
Masz Pan pojęcie jaki potencjał brzmieniowy mają Everesty DD67000 ? :-)
Nie przegrzewało i nie chłodziło brzmienia takie neutralne wierne brzmienie (nawet ze zintegrowanym wzmacniaczem Mark Levinson No.585), jakie to równe/spójne. Wszystko co się pojawiało było przedstawiane bez kompresji żadnych podbarwień i zniekształceń, świetne całe pasmo od basu po samą górę. Tych ich mega realistycznych/wiernych dźwięków nie da złamać na żadnej muzyce. Do tego dochodzi mistrzowska scena i stereo.
Ogromny potencjał, kolumny jak z innej planety w porównaniu do wszystkich pozostałych na całym AVS 2015 ..., które to grały różnymi stylami/charakterami (pod jedną lub druga muzykę) i im więcej różnej muzyki i dłuższego porównywania tym bardziej wychodziłyby ich ograniczenia na tle Everestów DD67000.
Bardzo łatwo rozwiać wszelkie wątpliwości w realu podłączając Everesty DD67000 w Bi-ampingu z jakimiś świetnymi monoblokami - wymiatałyby maksymalnie :-) ...a pozostałe kolumny (w większym lub mniejszy stopniu) byłaby przy nich skompresowane i stonowane.
Mirek, jak w końcu wygrasz w lotto, to dla mnie trochę dorzuć ;-) abym mógł kupić sobie owe kolumny :-) ... w British Racing Green Metallic, Rosso Corsa, Polar White, lub jeszcze innym kolorze.
Tu kolega podal ceny w Japonii:
Tak za parę, i tak masz dużo razy mniej niż za DD67000 w którymś z ekskluzywnych kolorów.
Tutaj możesz przeliczyć te 3,257,100 JPY na PLN:
Widze ok. 104000zl to jest cena w Japoni a w Polsce ile sprzedawca sobie policzy i gdzie to bedzie mozna posluchac?
Everesty DD67000 ten niebieski metalik jaki ladny....
Oni powinni wiedzieć gdzie osobiście możesz sobie posłuchać Maxonic'ów nawet z własnym Cary'm Audio CAD 300-SEI (300B)
Jesli driver dziala to nie dotykać bo po rozmegnetyzowaniu trzeba taki driver ustawić - elementy trzymają się na samym magnesie alnico. Nie dajmy sie zwariowac z tym remagnetyzowywaniem alnico.
W STXsie wiedzą co robią i znają się, potrafią układać pola i kleić rdzenie, choć nie zawsze chcą się tego podejmować.
A co do Maxonic
Kolumny TW 7000R są dostępne do od słuchu i jest dostępny kit, przetwornik 15" plus zwrotnica, projekt obudowy przy zakupie.
Ale kiczor z tym orłem...
Ale odlot:Viva Master Horn
To do wypaśnego KD ?
Mirek,
Co za kolekcja … ile vintage'owych rarytasów :-)
Skąd żeś tyle tego nazbierał?
Podaj pełne nazwy driverów, w kolejności od największych do najmniejszych, i pełne nazwy diaphragms jakie w nich się znajdują. - do tego dobrze byłoby gdybyś poodkręcał tylne pokrywy, i zrobił zdjęcie, tak aby było widać wszystkie diaphragms. A jak gardła w tych największych? Masz LE85 w dwóch wersjach, bo starsze/niebieskie z 60-tych lat mają impedancję 16 Ohms, a nowsze/czarne z 70-tych lat o impedancji 8 Ohms.
Większe Alteci 288C, a mniejsze to jaki model? ...bo nie widać.
Odsłuchiwałeś je wszystkich u siebie? ...napisz w jakich zakresach słuchałeś poszczególnych driverów i jak najdokładniej opisz/porównaj ich brzmienie?
2440/2441 można rozkręcić/rozłożyć na części pierwsze – nie było problemu, a za drugim to już w ogóle błahostka, tak samo jak i ze złożeniem. Magnesy można przykleić od środka obudowy na całej przedniej płaszczyźnie i szybko idealnie wycentrować, tak, że magnes jak przyspawany, nie drgnie w żadną stronę. Stare AlNiCo mało co tam tracą mocy, ale jak ktoś chce, może wpuścić nowe moce (20,500 gauss) jak ja to zrobiłem dla 2440., bo dla 2441 gęstość strumienia pola magnetycznego ma wynosić 18,000 gauss / 1.8 tesla.
To jest wieczne, nic tam nie może się popsuć, jak nikt nie będzie stukał młotkiem po driverach, czy ogromnych magnesach AlNiCo.
LE15A, PR15, 375, LE85, 075 – domowych nie tykam, szkoda tykać domowe najlepiej odpicowane i najdroższe rarytasy w najnowszych wersjach. Są to najnowsze wersje wooferów z szarym piankowym niezniszczalnym zawieszeniem. Passive radiators na sztywnym zawieszeniu tzw. harmonijce, także nowsze. Oba nowsze drivery (black) – z których to wydłubałem (zabezpieczający przed rozkręceniem) bardzo twardy czerwony wosk z logiem JBL, żeby podłączyć na krótko, bez terminali/zacisków, bezpośrednio do voice-coil. Tweetery nadal z nienaruszonym woskiem na śrubach, i to nowsze 075-ki 8 Ohms, bo starsze były 16-sto ohm'owe. Oczywiście nic na wymianę, ani na na sprzedaż.
W mniejszych driverach 1'' gardła (throat) ze stali nierdzewnej. Duże drivery mają 2'' throat z bardzo twardego/mocnego plastiku. W domowych jeszcze nie widziałem na żywo aby któreś miały nadpęknięte gardło, ale w profesjonalnych już tak. Tylko co trzeba robić z driverami pro 2440/2441 aby uszkodzić gardło? 2440 grają w Studio Monitor 4350, 4350A, 4350B. Drivery 2441 w 4355 Studio Monitor. Poza studyjnymi paczkami, to już w profesjonalnych systemach nagłośniających, od profesjonalnych kin po estradę, i z estrady będą w najsłabszym stanie, szczególnie jakieś wykręcane kupowane osobno/luzem, a nie w komplecie.
Przy montażu hornów, calowe śruby muszą być tak dobrane aby nie stykały się z magnesem AlNiCo, bo inaczej przy dłuższych śrubach jak ktoś będzie dokręcał na chama, to może coś uszkodzić w driverach.
Kenrick Sound, mocniej nadpęknięte 2'' throat wymienia na własne wykonane z brązu. Łatwo je wymienić, bo nie trzeba nic rozkręcać, tylko wsunąć od przodu drivera, w miejsce poprzedniego.
Oo, Kenrick co wydumał na JBL 1500AL woofer + JBL 375 Special driver, w cenie 4,280,000 JPY
Kondensatory Jantzen Audio Silver Z-cap, rezystory Mundorf M-Resist Supreme, no i podstawa... jak najlepsze cewki na jak najlepszym żelazie i materiale przewodzącym, bo na jakichś tam z polinku, to daleko nie zjedziecie, gdyż ze swoimi ograniczeniami nie nadają się do tak wypasionych przetworników, tylko do jakichś amatorskich/audiofilskich skompresowanych 'plumkaczy'...gdzie nie będzie tak słychać ich ograniczeń.
Stare oryginalne z rdzeniem EI i cynowano-miedzianym przewodnikiem - to jest inna bajka, tak gra na oryginalnych, że już nic się nie chce testować.
Cewki które widać u Kenricka, mają rdzeń z materiału o nazwie FINEMET® (FT-3M), lub FINEMET® F3CC Series Cut Core :
Zaloguj się, aby zobaczyć treść (możliwe logowanie za pomocą ) - kto pierwszy przetestuje, może Ty Mirek?
New Nanocrystalline Core Performance Versus Finemet® For Highpower Inductors:
Więcej informacji w broszurze Hitachi-Metals :
A below diagram shows the process for the creation of amorphous ribbon for FINEMET® and a typical FINEMET® core. The amorphous ribbon is the precursor material of FINEMET®. This ribbon, “which is about 18µm in thickness”, is cast by rapid quenching, called “single roll method”, then the amorphous ribbon is wound into a toroidal core. Finally, the heat treatment is applied to the core for crystallization in order to obtain excellent soft magnetic properties of FINEMET®.
The core loss of FINEMET® (FT-3M) cut core has less than 1/5th the core loss of Fe based amorphous metal and Mn-Zn ferrite, and less than 1/10th the core loss of silicon steel at 10kHz, Bm=0.2T. FINEMET® has significantly lower core loss and thus makes it possible to reduce the size of the core for high frequency power transformer. Also, the magnetostriction of FT-3M is 10-7 order and, as a result, cores made from this material will make very little audible noise when compared to cut cores made from Fe based amorphous metal and silicon steel.
The core loss of FINEMET® F3CC Series cut core has less than 1/3rd the core loss of Fe based amorphous metal, and less than 1/8th the core loss of silicon steel at 10kHz, Bm=0.1T. FINEMET® has significantly lower core loss and thus makes it possible to reduce the size of the core for high frequency power transformer etc. Also, the magnetostriction of FINEMET® is 10-7 order and, as a result, cores made from this material will make very little audible noise when compared to cut cores made from Fe based amorphous metal.
