Hi-end&vintage kolumny JBL
Czy jest sens pakowania JBL Ti250 do pokoju 25m2 plus aneks kuchenny 25m2 .
To są świetne kolumny więc jak najbardziej jest sens.
Jakie cuda tworzą w JBL'u :-) … 4367 2-way Studio Monitor Loudspeakers z wypasionymi nowymi hornami, wooferami i driverami.
Specs
Features:
15'' (380mm) low-frequency transducer for low-distortion, natural sound
Extremely smooth and wide frequency response
High-Definition Imaging (HDI™) horn technology
Frequency Response: 30Hz – 40kHz
Speaker Configuration:
3'' (75mm) D2430K D2 dual compression driver (U.S. Patent no. 8280091) with High-Definition Imaging (HDI™) waveguide horn (U.S. patents pending)
15'' (380mm) 2216Nd-1 Differential Drive® woofer (U.S. patent nos. 5664023, 5748760, 6768804, 6847726, 6774510)
Power Handling: 300 watts RMS
Sensitivity 1W @ 1m: 94dB
Nominal Impedance: 6 Ohms
Dimensions (H x W x D): 37-1/16'' x 22-1/16'' x 16-3/4'' (941 mm x 560 mm x 425 mm)
Weight: 135 lb (61.2 kg)
12106883_1203043136378560_2589561833325086344_n.jpg?oh=278c4816e93f8a5464abd0b6951e0d7c&oe=56866C22
Zaloguj się, aby zobaczyć treść (możliwe logowanie za pomocą ) - jedno zdjęcie 4367 z CEDIA 2015
Czyli mamy M2 do użytku domowego - jest i pasywna zwrotka.
Popatrz też z czego są zworki na terminalach - najprawdopodobniej to Belden 8470.
...''The D2 driver operates into JBL's newly developed High-Definition Imaging (HDI™) waveguide that provides neutral frequency response both on-axis and off-axis in both the vertical and horizontal planes and a seamless sonic blend with the woofer. The unique geometry of the HDI waveguide enables the JBL 4367 to deliver superlative imaging on a realistic soundstage, with a natural tonal balance at nearly any listening position in a wide range of acoustic environments.
The 4367 employs the JBL 2216Nd 15-inch Differential Drive® woofer used in the M2, modified with a new spider and a new surround treatment. The cast aluminum frame woofer employs a pure pulp cone material, dual 3-inch voice coils and dual neodymium motor structures to provide articulate, authoritative low-frequency performance down to below 30Hz.''
4367 Studio Monitor (2216Nd-1, D2430K D2) to w ogóle inny projekt, w szerszej/głębszej obudowie z innymi hornami – z M2 (2216Nd, D2430K D2) zostały tylko drivery D2430K D2, bo woofery (w 4367) to już nowsze 2216Nd-1.
Wizualnie bardziej zbliżone do 4365 Studio Monitor (1501Fe, 476Mg, 045Ti-1), ale przetwornikami zdecydowanie bliżej im do M2 Master Reference Monitor.
No i horny całkowicie nowe w 4367.
Zaloguj się, aby zobaczyć treść (możliwe logowanie za pomocą ) Edytowane przez atlon11
4365 … pierwszy raz u Kenrick'a :
…Mr. Suzuki oddał w rozliczeniu 4365 za vintage JBL 4320 (D130, 075) KENRICK Custom Special :-) … no to prawie jak C38 Baron, C36 Viscount 030.
Z 4365 było dla niego nieco za dużo dźwięku, a bas przy wyższych głośnościach odbijał się bezpośrednio na jego narządach wewnętrznych :D …co wyraźnie pokazuje na sobie, w którym miejscu mu wnętrzności przewracało, że aż się pochorował.
On jakiś dziwny, a te 4365 Studio Monitor to tylko się marnowały/ograniczały w jego systemie.
W Kenrick Sound, pewnie zadowoleni z pozyskania 4365 na które klient znalazł się na momencie i kupił je za 895,000¥
JBL Synthesis SDP-75 3D Surround Processor
''The first result of the partnership is the JBL Synthesis SDP-75 Processor. Based on the Trinnov Altitude32 platform, the SDP-75 is designed to be the heart of a JBL Synthesis custom-installation home entertainment system. Deploying Trinnov's powerful processing capabilities and exclusive technologies, JBL Synthesis is now able to bring ultimate performance to the home cinema market driven by 3D Audio, 4k Ultra High Definition video and HDMI 2.0.
The SDP-75 will be available in 16 and 32-channel versions and is configurable surround processor/preamplifier compatible with Dolby Digital Plus, Dolby TrueHD and DTS-HD Audio formats. The SDP-75 also provides full support for all major 3D audio codecs and upmixers including Dolby Atmos, Dolby Surround, Auro 3D and DTS-X. A companion SDEC-5500 digital equalizer will also become available providing JBL Synthesis advanced Adaptive Room Correction and Optimization System (ARCOS) calibration technology and HARMAN's BLU link connectivity for the SDP-75 platform.
In conjunction with JBL's industry-leading loudspeaker technology, award-winning JBL Synthesis SDA amplifiers and new companion SDEC-5500 processor for ARCOS the addition of the SDP-75 positions JBL Synthesis for ultimate performance for high-end residential home theater systems.
The JBL Synthesis SDP-75 will be available in first half 2016 with distribution details and pricing to be announced at a later date.
The JBL Synthesis SDP-75 will be demonstrated as part of a complete 13.4.11 channel theater in the HARMAN booth (#4112) with Trinnov Audio personnel during CEDIA EXPO 2015 (October 14th-17th).
Trinnov Audio is a privately held research company based pear Paris, France. Founded in 2003, Trinnov Audio provides innovative products used worldwide in every kind of high performance audio environment: broadcast and film studios, movie theaters, high performance home installations and consumer electronic products. Our portfolio of unique solutions is protected by five international patents.''...
Absolutna referencja Mark'a Levinson'a w ich pomieszczeniu odsłuchowym: №512, №585, №52, №53, №536, a do nich kolumny głośnikowe Revel Ultima Salon2 i JBL Project Everest DD67000 :
''In the photo at the top of this article, Harman Luxury Global Product Line Manager Dan Radin talks about forthcoming gear I cannot show you.'' :-) … co tam może się kryć, co tam może być, … czyżby jakieś absolutnie topowe nowe dzielone źródło/odtwarzacz, czy co.
Te wszystkie ML-e, to dzieło sztuki elektronicznej i metalurgicznej :-)
Jak w zdjęciu profilowym – tylko bardziej aktualne, niż to co widać, bo tweetery trochę bliżej.
Jak będę miał jakieś nowsze zdjęcia, to coś wrzucę.
Everest DD67000 i K2 S9900 są dostępne (na zamówienie) już w 7-miu ekskluzywnych wykończeniach: Black Gloss, Polar White, Rosso Corsa, Sapphire Blue Metallic, British Racing Green Metallic, Tungsten Silver Metallic, and JBL Orange.
Oto bliższe spojrzenie na cztery (z siedmiu) ww. luksusowych opcji wykończenia, dostępnych w ramach najnowszego programu ''JBL Premium Finish Program'' dla Everest & K2 :
Everest DD67000 w Rosso Corsa i British Racing Green Metallic :-)
K2 S9900 w Polar White i Sapphire Blue Metallic
Bardzo szybko program się zmienił/aktualizował, bo co niedawno pojawiły się w 6-ściu luksusowych/niestandardowych opcjach wykończenia: Deep Black, Polar White, Rosso Corsa, Verde Mantis, Racing Orange, Sapphire Blue Metallic., a już są dodatkowe.
Cennik w ''USA'' dla Everest DD67000 i K2 S9900 wygląda tak – w standardowym wykończeniu najtańsze, a pozostałe luxury :
Everest DD67000
• Rosewood, Maple: $75,000/pr
• Black Gloss: $85,000/pr
• All Others: $90,000/pr
K2 S9900
• Cherry, Wood Grain, Black Zebra Wood: $44,000/pr
• Black Gloss: $50,000/pr
• All Others: $55,000/pr
Oo Panie :-) …
12075026_1204417849574422_1808712146725659559_n.jpg?oh=c059dcf2bbf951c28839f3f7a8120565&oe=568CE7BC
12140801_1204418189574388_9174834813874471529_n.jpg?oh=5b588476280fa7ff805cf1822bc833ee&oe=568DE9D2
12119175_1204418049574402_7942821550099706191_n.jpg?oh=eea4cdf95fd8bf9c894073a904d03ba6&oe=56C0D81C
To jest piękne! Spójrzcie głęboko ile w tym kolorze (tri-color British Racing Green Metallic) jest detali i jak się zmienia w zależności od oświetlenia – co widać nawet na filmiku :
12063603_1204417976241076_2703894144600581789_n.jpg?oh=fd7b681cef7eb9a04ddef6ac0c2414c8&oe=56CDCEF2
11164007_1204417892907751_485486133098938699_n.jpg?oh=9c888846611ab9bec58bffccf4a883fb&oe=56C1BAA4
12107906_1204417782907762_9098941981539035716_n.jpg?oh=e4cdb18ee97535565eec6e2302ed01e6&oe=568F2D42
12122475_1204040859612121_2689010780177071121_n.jpg?oh=9aefd1f0a1d29e7fd3bdfb3810b193ba&oe=56C64537
DD67000 z Levinson'ami połączyli Transparentami (sygnałowe i głośnikowe), a sieciówki to standardowe sznurówki. Tomkly mówił, że do Levinson'ów sieciówki Elrod lub Stealth, a Interkonekty XLR i kable głośnikowe od MIT'a – czyli w całości po amerykańsku.
Jak gra na zwykłych/standardowych kablach zasilających, to jeszcze lepiej będzie z konkretnymi sieciówkami.
12107160_1205900569426150_8458423663326568376_n.jpg?oh=b2c0a37a9bdb644840f4ee3d806150cd&oe=56850212
...z integrą №585 :
...gdzieś W.P. pisał że ''3 x droższy Soulution 530, gra znacznie bardziej miękkim, jedwabistym dźwiękiem'' … eee pewnie jakaś stonowana integra, która więcej dodaje od siebie (ukrywa to i owo ''pod swą gęstą, miękką powłoką'') niż przekazuje z prawdą.
Everest DD67000 to super rozdzielcze liniowe/spójne, neutralne, mega uniwersalne i transparentne brzmienie live, nie ma tam ściemy – jaki sygnał/prąd dostają tak grają. One mają fantastyczną dynamikę, detal, rozdzielczość/selekcję, prawdziwy real ton, genialną scenę i stereo.
A bas (tak jak i cała reszta) o niezrównanej jakości … jak na żywo.
Jaka elektrownia, okablowanie i wysterowanie, takie granie z Everest DD67000 :-)
Tutaj także z Transparent'ami i standardowymi sieciówkami, tylko trochę więcej Levinson'ów m.in. rozdzielcze liniowe i transparentne monobloki №536 :
''This fully differential, fully discrete monoblock drives virtually any loudspeaker effortlessly for impeccable imaging, musicality, and openness. To that end, components are selected based not only on their technical merits, but also on their sonic capabilities. The sound of the № 536 is big, open, unrestricted, natural, and effortless.''...
...monofoniczny wzmacniacz mocy №536 wygląda jakby był stworzony do Bi-wiringu :-) ... który z nim jest prawie jak Bi-amping. Jedno wejście analogowe (XLR / RCA), a dwa osobne wyjścia na przewody głośnikowe, więc nie można zostawić nieobciążonego stopnia wyjściowego i trzeba podłączać Bi-wiring. Ładnie uzbrojony, trafo 1800VA, 40-ści (2 x 20) mniejszych kondensatorów - pewnie aby było szybciej i dokładniej. 48-tranzystorów: 24 x TO-264 Bipolar output transistors, 24 x TO-220 Bipolar driver transistors. Projekt symetryczny jak w odbiciu lustrzanym.
12072746_924003304315552_8262589629665869982_n.jpg?oh=10cf15dd736a2d3dbcde0105ba8fd7f5&oe=56CF76B3
12109272_1162600357102655_5451805973339686707_n.jpg?oh=c16f197c3e13e7a176f8128c0804dfa9&oe=56D099B1
12003399_1156476684381689_8465618657138342186_n.jpg?oh=edbf1159e49547fb4bc2c250d575170c&oe=56BBC6E7
U tego Pana świetny set-up: dCS Rossini, ML №52, ML №53, Everest DD67000
Na drewnianym stoliku platformy, ale już nie drewniane :-) ... i o to chodzi.
A z dołu to jakieś 2 kondycjonery, czy co?
Głośnikowe MIT-y były (w starszych set-up'ach) i się skończyły ... to chyba jednak nie są takie najlepsze :-) ... może te ich filtrujące puszki :D ...za dużo dodają od siebie. Komedia, aby jakieś puszki były na kablach ... ja bym je powycinał i wyrzucił. W Purist Audio Design Ex-NASA engineer Jim Aud żadnych puszek nie wstawia:
Gdy grały MIT-y wtedy był jeszcze №512, ale już go nie ma, czyżby nie dorastał poziomem dźwięku i przejrzystości do nowego/referencyjnego przedwzmacniacza i monobloków Levinsona.
Jak ML №512 jest lepszy bardziej neutralny i precyzyjny od AR Ref CD9 ...to ten drugi musi być nieźle stępiony/mlonowaty, bo już co niektórym №512 trochę zaokrągla. Jazz-owcy ten odtwarzacz ML-a bardzo lubią, znaczy Ci co słuchają więcej Jazz'u :-) ... ale i tak to jeden z najlepszych odtwarzaczy "jednopudełkowych".
Na obecną chwilę, na stronie ML-a w liście produktów:
Zaloguj się, aby zobaczyć treść (możliwe logowanie za pomocą ) ...nie widać żadnego źródła, tak jakby coś nowego się szykowało.
10407552_1163496713679686_1347834518333428902_n.jpg?oh=4cd3d842cb6bd1bb233e0be4f3df2f48&oe=568A55EA
Ludziom chyba jesienna nuda zaczyna doskwierać bo mamy wysyp trolli/spammerów. Najczęściej w wątkach o diorze/tonsilu.
Zamknij ich wszystkich na bocznicy w wątku 'tylko dla trolli i hejterów' – i niech tam siedzą w żywiole ze swymi paranojami.
Trolle i hejterzy to szkodniki, których przeważnie coś uwiera i świerzbi, więc przeżywają frustracje i próbują odreagowywać swoje niepowodzenia i rozmaite fobie/schizy.
System z pierwszego powyższego zdjęcia znajduje się u Lexus'a :-)
Nawet w linku przy trzech zdjęciach napisano ''Lexus Hà Nội'' … a na obrazach w odbiciu widać Lexusy, więc pewnie to jakiś salon Lexus'a w Hanoi.
Może to tutaj, bo wszystko wewnątrz bardzo podobne :
System od tego samego Pana, znaczy z:
Zaloguj się, aby zobaczyć treść (możliwe logowanie za pomocą ) - gdzie mają świetne marki i topowy sprzęt.
Nie wchodzą do obudów!! Mają za szeroki kosz, to jest bardziej 16 cali niż 15.
Mierzyłem je Daytonem DATSV2 i wyszło mi na jednym Fs=24Hz, na drugim 32Hz. Możliwe że muszą się od nowa jakiś czas pobujać na sweepach 20-60Hz.
Szkoda, że Emilary EW15-8A nie weszły Tobie do obudów 4343ASF, tak byś posłuchał jak grają w porównaniu do 2235H. Czyli co daremny zakup? … kupiłeś i sprzedasz, a może już sprzedałeś bez posłuchania w kolumnach.
Oryginalnie, do jakich skrzynek / obudów były aplikowane Emilary i w których najlepiej grały / grają ?
Pisałeś, że super woofery, to E145-8 i byś ich posłuchał.
To prawie jak 150-4H w starych Everestach DD55000
Tyle że wiesz, 150-4H do Everestów DD55000 … tak aby były w swym żywiole.
Na temat Emilarów nie znajdziesz nic jeśli chodzi o paramtery TS i w jakich paczkach były stosowane. Wygląda na to jakby firma robiła tylko same przetworniki.
Myślałem że to joint-venture z Cetec Gauss ze względu na podobny kolor kosza i żeberka na magnesie ale jednak nie - gaussy miały podwójny spider.
Szkoda że nie wchodzą ale nie mam miejsca już żeby zrobić z nich DIY. Według naklejki przetwarzają od 20 to 1200Hz także można by z nich zrobić świetne 2-way z powiedzmy 2445H z Radianem 1245-16 po taniości na jakimś fajnym drewnainym hornie i ew. na górę dodać 2405H
Pomiar z DATSv2 pokazał to na temat EW15-8A:
Edytowane przez Marek.S
Coś tam dla nich wymyślisz, jakiś project ;-) … rasowy, który nawet w 20m2 bez adaptacji akustycznej, w naturalnych warunkach, zagra o niebo lepiej, niż jakiekolwiek pyrkające/amatorskie kolumienki w zaadaptowanym akustycznie pomieszczeniu. Najważniejsze są kolumny głośnikowe i jak najlepsze ich wysterowanie, a dopiero później metraż pomieszczenia i akustyka. Najlepiej aby była naturalna/prawdziwa akustyka jak na wolnym powietrzu, i nigdy stonowana.
Tamte 2 kondycjonery to:
Jeden do monobloków №53, drugi do przedwzmacniacza №52 i odtwarzacza dCS Rossini'ego.
hmm, takie kondycjonery nie osłabią blaszek i ataku
第39回 マラソン試聴会
Pograli sobie w Japonii :-)
Everest DD67000 + Mark Levinson №53 + Mark Levinson №52 + Linn Klimax DS2, Linn Klimax LP12 :
K2 S9900 + McIntosh MC601 x2 + McIntosh C50 + Denon DCD-SX1, Marantz NA-11S1, Luxman PD-171AL + Ortofon AS-212S + Goldring Legacy, Luxman EQ-500 vacuum-tube phonostage :
Grały także nowiusieńkie 4367 Studio Monitor z McIntosh'ami MC601 i C50, ale bez odtwarzacza McIntosh-a, które mogą być za bardzo zaokrąglone, aby grać w firmowym zestawieniu z preamp'em i monoblokami McIntosh'a. W tle (na innym rack'u) wyłączony pre-amp C2500, który w tym zestawieniu nie uczestniczył.
Przedwzmacniacze i Wzmacniacze mocy McIntosh'a dość często podłączają do JBL'i. Takie MC601 to minimum – poniżej nie ma co schodzić, jedynie wyżej wchodzić do poziomu MC2301(KT88), MC1.2KW, lub jeszcze lepiej MC2KW. Z preamp'ów co najmniej C1100T+C1100C, C1000T/C1000P+C1000C. Z tańszych przedwzmacniaczy na początek ujdą C52, C50, C2500.
Nie od dziś wiadomo, że z topowych McIntosh'y (jak i Levinson'ów) można stworzyć świetny set-up z JBL'ami.
Ciekawe jakby to grało w zestawieniu (ML + Mak) np. przedwzmacniacz Mark Levinson №52 + monobloki McIntosh MC2301(KT88), lub jakieś inne piece Maka.
Program dwudniowego maratonu ''Live'' w którym uczestniczyło ponad 20-par kolumn – jest nawet rozpisane w jakich zestawieniach grały :
Z ''pole position'' wystartowały Everesty DD67000
Zaloguj się, aby zobaczyć treść (możliwe logowanie za pomocą ) - fotogaleria / 2015年10月18日
Witam Panowie!
Stoję przed małym dylematem, po remoncie salonu i małym przemeblowaniu prawdopodobnie będę chciał zamienić swoje jbl xpl200 na jakieś ciekawe monitory studyjne. Jest to ciężka decyzja z racji świetnego dźwięku z tych paczek ale cóż, czasami tak trzeba.
Trochę wątków o słynnych monitorach przeczytałem ale nie miałem niestety okazji przesłuchać żadnego z mniejszych monitorów jbl-a.
Prośbą do Was Panowie co by mi doradzić coś ciekawego.
Modeli o których myślałem jest kilka, poczynając od L100, L112, 4412, century gold wszystko zależy od tego jaki sie trafi o oczywiście od stanu.
Po cichu myślę o nowszych 4319, 4429 ale to troszkę droższa impreza i na chwile obecną nie dam rady finansowo.
Generalnie ma być czysto, klarownie z fajna stereofonią , dynamiką i szybkim basem .
Kolumienki narazie bedzie napedzal krell kav 300i ale to sie pewnie zmieni za jakis czas i pójde raczej w stronę hybrydy od Wile.
Z góry dzięki za pomoc
Krystek
Kolego Krystek - NIE RÓB TEGO!
To tak na początek :-)
XPL to inna liga niż 4412/431x. (W moim mniemaniu 4311/4312 ze standardowymi zwrotkami są takie sobie, daleko im do neutralności XPL).
Jedyną kolumna z tych które wymieniłeś i która może powalczyć z XPL200 to Century Goldy albo 4429 tylko że na odpowiednich standach to trochę rozwiązanie "nie kijem a pałą" bo gabarytowo będzie podobnie jak z XPLami które są jakby unikatami - 4 drogi i duża tytanowa kopułka.
Moja rada - zatrzymaj XPLe (gwoli ścisłości - to była kiedyś topowa linia JBLa oprócz serii Studio Monitor).
Przełącz w bi-amping z oddzielną końcówką na bas i jazda.
Nie za ostro masz na górze z tym KAV300i?
Marek, dzięki za odpowiedź
Cały czas myślę czy jednak nie zostawić sobie tych xpl-i właśnie z racji tego , że wiem co one potrafią i jak grają..
Najbardziej w tych kolumnach wkurza mnie ten tylny bas reflex który wymusza odstawienie kolumn od sciany stąd pomysł o zmianę na coś z frontowym br.
Bi ampa juz próbowałem, co prawda było to granie na starszych Nadach, słabych kablach ale rzeczywiście dzwięk sie otwierał, stereofonia zdecydowanie polepszała, próbowałem nawet biampingu aktywnego ale miałem jakaś lipną zwrotnicę i za bardzo buczało w głośnikach.
Niestety ten biamping jest cholernie drogi, dwa razy dobre kable, dwie dobre koncówki, dobry przedwzmacniacz z wyjściem na dwie końcówki ech ... choć na forach w US piszą, że te kolumny z DX-1 czy tam innymi dobrymi aktywnymi zwrotnicami daja radę więc coś w tym jest.
Co do krella to ostrawo było na słabych kablach, po wpięciu sieciówki i głosnikowych od Wile + xlr-neotecha z czystej miedzi zrobiło się naprawdę przyjemnie, krell ma swoje wady, wokale nie są na nim najlepsze z racji wg mnie cofniętej srednicy ale za to ma szybki głęboki bas co ożywiło te kolumny + świetną przestrzeń i mnóstwo detali, teraz sporo jazzu słucham gdzie jest mniej wokali więc aż tak bardzo mi to nie przeszkadza.
aaa 4429 miałem odsłuchiwać w środe w audiopunkcie ale niestety nie dałem rady i odsłuch przełożony , pewnie będzie po audioshow i się zobczy co potrafią, są jeszcze 4425 i nowe 4319 ale nie mam jak ich odsłuchać, może jest ktoś z Warszawy co je ma to chętnie się umówię na sprawdzenie ich możliwośći.
Myslę ,że te odsłuchy pomogą mi w podjęciu ostatecznej decyzji w sprawie xpl-i
witajcie,
Z czym dobrze zagrają JBL4312E? Chcę zmienić swój dotychczasowy wzmacniacz. Nie powiem jaki, żeby nic nie sugerować:) Kasa do wydania 5-6 tys. XLR-y mile widziane bo CD to Primare 30.2
Stawiam na Classe albo Electrocompanieta albo może coś ze stajni Primare, do kompletu.
Kabelki z czystej miedzi dobrze działają w kombinacji z JBLami - sam używam AQ i Eichmannów. Szkoda tylko że są takie sztywne.
Co do aktywnej zwrotki to fakt - tanie modele wyraźnie słychać. U mnie dopiero Bryston 10b "zniknął" w systemie.
Tak, tak Primare to śmieć.
A czym jest Sansui?
To stare graty z wystawki z Niemiec, których kult od jakiegoś czasu został wytworzony przez handlarzy starzyzną.
A czym jest Sansui?
XLR w Sansui to wejście bezpośrednio na końcówkę czyli z Primare sobie nie pogra(?).
Poza tym, czy mówimy tu o 'prawdziwym' czy po obu stronach jest desymetryzator?
Nie znam 911 ale D11 i AU-X1 to bdb brzmiące klocki ale z problemami. D11 miałem a X1 często słuchałem u znajomego. ale niestety znowu się rozsypał i dał sobie spokój, to był chyba już 4 raz kiedy poleciały tranzystory na wyjściu.
AU-X1 to genialnie brzmiąca (detal, dynamika) ale przeklęta maszyna która od byle g. wpada w oscylacje i wywala tranzystory mocy. Facet dwoił się i troił żeby poprawić błędy ze schematu i po ostatniej wymianie wzmak pograł ze 2 lata i padł.
W moim D11 szumiał któryś z tranzsystorów w sekcji Phono MC, czytając w internecie dowiedziałem się że "Sansui tak czasami ma"...
