Hi-endowe nowości
Aurender pokazał swój pierwszy kompletny streamer:
The new Aurender A10 should be arriving this summer for approximately $5,000 and should cover just about all of your digital file playback and streaming needs. Inside will be a 2TB drive for storage and 120GB SSD cache to improve playback quality, with Tidal native as well.
On the back are both balanced and unbalanced analog outputs and USB, Ethernet and optical digital inputs. Formats handled include PCM up to 32/384 and DSD128.
Tu więcej zdjęć:
Dan D'Agostino Progression Mono Amplifier, o mocy 800Wat.
dan_dagostino_matej_isak_2015_mono_and_stereo_matej_isak_test_2016_new_2015_%2B-%2B1.jpg
Bryston CUBED SST3 Series Amplifiers - czyli nowa seria wzmacniaczy mocy Bryston'a z 20-sto letnią gwarancją.
Inne nowości :
Nowy PS Audio DirectStream DAC Junior.
Tańszy niż DirectStream i ma od razu wejście Ethernet.
There was only one problem for PS Audio owners...
The advanced FPGA and pure DSD technology employed in DirectStream was expensive, our most expensive DAC ever made. PerfectWave customers were asked to spend an additional 41% to enjoy the benefits of designer Ted Smith's seminal effort at redefining the very architecture of digital to analog conversion. And many thousands of customers did.
But not all could afford DirectStream. Many loyal PS customers had to sit on the sidelines, priced out of the market. Within a few months of DirectStream's launch, work began on a lower cost version code-named "Junior".
DirectStream Junior
Ted Smith learned much in the 7 years it took him to develop DirectStream. At first blush it seemed a relatively straightforward task to develop a lower cost version by taking costs out of low hanging fruit like the chassis, user interface, and PC boards. But our goals were loftier than that.
Our product directive asked for similar architecture to DirectStream in a PerfectWave-like chassis, with the network Bridge built in and performance not less than 85% of the original. A tall order by any measure.
Retooling the chassis, replacing the touch screen with a less expensive OLED display and manual volume control was relatively straightforward work by PS Engineering. The real challenge fell upon Ted Smith's shoulders. How do you get 85% of an instrument's performance with 41% less to spend? The answer turns out to have a number; two years of hard work. The end result is DirectStream Junior.
Who did we build DirectStream Junior for?
Customers who want to uncover what's been missing in their libraries, but could not manage a DirectStream DAC. At $3,999, DirectStream Jr. (DSJ), with its built in Bridge II, is slightly more than half a similarly outfitted DirectStream (DS). That makes it a a more cost effective DAC than even the original PWD.
No, it is not a DirectStream when it comes to ultimate performance, but DirectStream Junior offers 85% of DirectStream's performance at a significantly lower price.
ATC SCM10 Signature Edition
ATC was founded in 1974 by our Head of Engineering and Managing Director, Billy Woodman. In March this year, Billy celebrates his 70th Birthday!
Celebrations deserve something special and to mark the occasion we are building a very limited run of one of our earlier models and, a favourite of Billy, the SCM10.
The visual design of this very limited Signature Edition was just as important as the louspeakers’s performance and the finest craftsmen and materials have been used to create a visually stunning loudspeaker.
The cabinet is finished in a deep-blue, hand polished high gloss lacquer and the front baffle has been upholstered in a complimentary shade of dark blue leather. Silver anodised metalwork finishes it off and every pair will be supplied with a 20 page hardbound book detailing ATC and Billy’s history.
Zaloguj się, aby zobaczyć treść (możliwe logowanie za pomocą ) post-15174-0-63031600-1455807969_thumb.jpg
To może ja w uzupełnieniu powyższego posta dodam, że inne topowe kolumny atc również w tym roku doczekały się wersji SE:
Fajne. Ciekawe czy dystrybutor ma demo w Pl ?
Ponoć ta średniotonowa kopułka to jeden z najlepszych na świecie średniotonowców. Jest też dostępna w lepszej specyfikacji oznaczona jako S.
Miło wspominam odsłuch ESA Profi 01 jeśli chodzi o średnicę właśnie z takiej kopułki - chciałbym mieć taką u siebie.
Niestety reszta trochę kulała, ale może to pomieszczenie czy też reszta toru nie spasowała.
Może kiedyś będzie okazja posłuchać czegoś większego z ATC.
No właśnie Elb popytaj w np. blueaudio z Warszawy- mają sporo z atc, ale nie wiem czy coś najnowszych produktów. Jestem ciekaw Twojej opinii o atc (najlepiej aktywnych w połączeniu z muzykanlnym dac'iem i lampowym pre).
Czyżby? mam takie inne wrażenie kto od kogo odgapił.
Dystrybutorem chyba jest (był ?) Decibel ?
Gość kennijczyk
a u nas cena podobnie:
dystrybutor pewnie bez zmian, choć ja pisałem o sklepie, który ma na stanie sporo modeli i z odsłuchem pewnie nie powinno być problemu.
Ze stajni Musical Fidelity nadchodzi zintegrowany komputer, strumieniowiec, dac i końcówka mocy
Zapraszamy na profil Triangle Audio Polska
www.facebook.com/TrianglePolska/
Dobre! Zanim przeczytałem post sly'a, pomyślałem o swojej kuchni. Radio internetowe na tym tez odbiera? Ile to stoi?
I czy jest coś takiego w niepełnej szerokości, poniżej 40 cm. Nie musi być MF, i nie musi mieć wzmacniacza.
Less is more
No właśnie, jak by jeszcze gotował i serwował poranną kawkę to można byłoby się zastanowić nad zakupem.....
No cóż pasował by do tego topowy Magnum Dynalab ale w obecnej chwili zaniku kultury panującej w dawnym radiu kupowanie nowego tunera radiowego nawet z "cudownym" DAB jest bez sensu!!!
Tutaj Rafal wkleilem pomiar mojego echa,tak odnosnie braku firanek :))
Zaloguj się, aby zobaczyć treść (możliwe logowanie za pomocą ) Edytowane przez piotr112
Wrzuć T60 cwaniaczku ;)
JBL Synthesis SDP-75 3D Surround Processor
Sugerowana cena $25,000.00 za wersję 16-kanałową, i $32,000.00 za 32-kanałową
To nie jest JBL. Ten procesor to Trinnov Altitude. JBL kupuje od Trinnova i dokłada swoje napisy. Był projekt dobrego procesora Lexicon, firmy należącej do grupy HK, ale projekt upadł. Dziś Amerykanie muszą kupować procesory od Francuzów.
Edytowane przez sly30
Tak, posiada radio internetowe i kosztuje 26.000zł, generuje 225W / 8 ohm na kanał. Pewnie to wszystko za mało na wątek hi-endowy.
Słuszny ruch. Jak nie możesz pobić konkurencji, to ja wykup (albo kup od nich IP). Trinnov ma obecnie najlepszy projekt procesora AV na świecie.
A tak to się powinno robić:
Naim Mu-So Qb
Cena $999 ('duży' muso $1499) wiec u nas pewnie ok 4kzł.
Gdzieś już to widzieiliśmy
Na dniach pojawi się w Polsce wzmacniacz Nu-Vista Black. Także do odsłuchu
