Hi-endowe nowości
Elberoth
Ideą wątku jest wklejanie info o gotowych produktach - ze zdjęciem i danymi.
Podejrzewasz że jeszcze tych kolumn nie wyprodukowali? Przypomina mi się pra premierowa reklama Orfeusza firmy Sennheiser, pózniej nie mogli go jeszcze przez 3/4 roku poskładać żeby jakoś działał a nie tylko wygladal.
Czytamy ze zrozumieniem.
Najnowsze Magico M3:
Magico, the leader in high performance loudspeaker design and manufacture, is pleased to announce the new M3.
The 2014 release of the M-Project provided a glimpse of the innovative designs and advanced technologies that were being developed at Magico. Since then, we have continued to develop and refine the concepts and vision introduced by the M-Project. The new Magico M3, picks up where the M-Project left off, and not only builds upon its legacy, but takes it several steps further. A new Carbon-fiber side panel design, an all- graphene midrange and bass driver design, a new driver coupling system and the phenomenal 28mm diamond coated beryllium tweeter, previously found only in the M-Project, all come together in what is the most sophisticated loudspeaker we have ever created.
Magico is the world’s first manufacturer to utilize graphene in the development of a leading-edge loudspeaker cone design. Graphene has many extraordinary properties and is approximately 100 times stronger than the toughest steel. The newly designed Magico six-inch midrange and seven-inch bass driver cones found in the M3 are both manufactured from Multi-Wall carbon XG Nanographene and a new proprietary ultra-stiff carbon weave which is 20% lighter and 300% stiffer than the cone material used in previous Magico loudspeaker offerings. The underhung neodymium base motor system provides an ultra-stabilized magnetic field for the pure Titanium voice coil to operate within. This radical new driver design offers the lowest THD in the industry and sets the performance benchmark for others to aspire to.
The M3 midrange driver operates in a purpose built sub-enclosure made of a proprietary polymer that enhances midrange control and articulation. This sub-enclosure concept was first used in the S3 and is now applied to our more recent 3-way speaker designs. Three seven-inch M3 bass drivers are vertically aligned to achieve ideal room integration and reproduce the lowest registers of bass frequency with speed and accuracy. A solid copper gasket is applied between the driver’s chassis and enclosure to maximize the coupling effect and diffuse resonances between the two surfaces. The M3 bass drivers are optimized for minimal music related distortions in the frequency and time domain using the latest state-of-the-art FEA simulation of acoustics, mechanics, electromagnetic and thermal behavior. The testing process is now completed on a single platform allowing optimization levels to be taken to a higher level.
The M3 incorporates the diamond coated beryllium diaphragm tweeter (28-mm) used in the M-Project. The optimized geometry and the diamond coating on the beryllium aligns the acoustical properties closer to perfection without adding the extra weight of a full Diamond dome. This revolutionary tweeter design offers a near perfect weight to stiffness ratio that is unmatched in the industry. The new tweeter provides extra-long excursion movement and uses a neodymium based motor system that is customized to match the sensitivity and power handling capabilities of the M3 while maintaining ultra- wide dispersion characteristics and ultra-low distortion measurements.
An internal three-axis matrix framework encapsulated in a sandwich Carbon-fiber skin, contributes to an extremely rigid yet damped enclosure and eliminates unwanted resonances and colorations, allowing all drivers to perform with stunning resolution and dynamics. All five drivers in the M3 are acoustically integrated using Magico’s exclusive Elliptical Symmetry Crossover topology.
Driver Complement
1 1” MBD28 Tweeter
1 6” MAG6004RTC Graphene Nano-Tec Midrange
3 7” MAG7012RTC Graphene Nano-Tec Bass
Specifications
Sensitivity: 91dB
Impedance: 4 Ohms
Frequency Response: 24 Hz – 50 KHz
Recommended Power: 20–500 Watts
Dimensions: 48”H x 19”D x 13”W (120cm x 49cm x 34cm)
Weight: 320 lbs. (145Kg)
MSRP $ 75,000.00 / pair. Ship date – 3rd Quarter 2016
Paradigm-F4-Speakers.jpg17605169965_4c4f0fe664_k.jpgciekawie się zapowiada Paradigm Concept 4F
Zaloguj się, aby zobaczyć treść (możliwe logowanie za pomocą ) Edytowane przez mztv
Ciekawe jak będą wyglądać :)
75,000.00 USD
This is Madness...no, this is MAGICO;-)
Elac Concentro
Im droższe kolumny tym trudniej zaprojektować coś gustownego...
...ciekawe ile będą kosztować...
Coś się zapatrzyli na Wilson Benesch z tym karbonem...aluminium już się opatrzyło?
A Wilson Benesch zrobił pierwsze na świecie kolumny z KOLOROWYM karbonem...
No i jest oficjalna premiera BP9000.
BP9080x, topowy model serii:
- zejście do 25Hz
- 12 calowy aktywny głosnik niskotonowy z dwiema membranami pasywnymi moc: 375W RMS każdy, do tego wbudowany procesor DSP
- zintegrowany moduł Dolby Atmos / DTS:X ze stosownymi certyfikatami
- 2 tweetery
- 3 głosniki 4.5 cala
- aluminiowa podstawa
- aluminiowe wykończenie góry
Po Johnie Legendzie, Definitive Technology zaprosił do współpracy perkusistę zespołu Interpol.
https://www.youtube.com/watch?v=RvH_k8XaoXQ
Edytowane przez RAFKO_Dystrybucja
Zapraszamy na profil Triangle Audio Polska
www.facebook.com/TrianglePolska/
Ciekawy ten model 9080x... Mały błąd chyba się wkradł :) ?
- 2 tweetery
Chodziło mi bardziej o to , czy model 9080x nie miał specyfikacji ( tak jest na rysunku powyżej ) :
(5) 5.25" (133mm) bass/mid drivers
(3) 1" (25mm) dome tweeters
(1) 12" (305mm) subwoofer
(2) 12" (305mm) sub radiators
Ach tak. Ja po prostu podałem bez górnego modułu Dolby Atmos / DTS:X, który jest w standardzie. Nie wiem, jakim cudem naliczyli tam pięć średniotonowców. Ja widzę na przekroju cztery i tyle podaje specyfikacja w dokumentacji dla dilerów. Na stronie najpewniej jest błąd.
Kolejne zdjęcia live
Fajne, choć wole swoje Mythosy :)
Genelec wprowadził następców topowych monitorów bliskiego pola 8240 i 8250, w postaci 8340A i 8350A. Co ciekawe nowe wersje nie schodzą już tak nisko jak starsze (stary 8240 schodził do 41Hz @-3dB, a nowe 8340 kończą na ~45Hz @-3dB). ... może za to ten bas jest dokładniejszy.
Zaloguj się, aby zobaczyć treść (możliwe logowanie za pomocą ) Edytowane przez Kyle
Jeśli białe, to nie sądzę by były to 8340 (czy starsze 8240). Raczej coś z serii G (niższa rodzina o jedno oczko i z segmentu "domowego" choć pomiędzy tańszymi "pro" 8040 a domową G four różnic nie widzę).
Dlaczego?,..ale Dlaczego?...dlaczego,...się rozmawia o produktach, na których najwięcej się zarabia, nie biorądz pod uwagę brzmienia, np w Munich Avangardy nie miały zainteresowania,..czyżby Polski dystrybutor się nie dogadał?,..a wiem że się nie dogadał,...a dlaczego?, słaba marża?, w Hi-End nie rozmawia się o brzmieniu, tylko o pieniądzach.
Był Genelec. Rok temu słuchałem - całkiem fajnie to grało. W tym roku przywieźli jakieś takie monitory na pół ściany.
High End idzie w gabaryty :)
Gryphon Kodo Reference Loudspeaker System
The all new Gryphon Kodo flagship is a four tower loudspeaker system that weighs a tone, stands 2.37 meters tall, and incorporates 38 drive units and costs 220.000 euro (plus 23% VAT in Portugal). The bass towers houses eight 8 inches woofers and a built-in 1Kw amplifier with 4Kw peak power. The center of the Kodo upper/frequency towers is a Mundorf Air Motion Transformer high frequency driver. Directly above and below it are bass/mid modules each housing two 4 inches Scanspeak Illuminator midrange drivers and three proprietary 5 inches Gryphon midbass drivers.
If you buy it, three months after installation at home by the local distributor, you will be visited by a specialist from Gryphon, who could be Flemming himself if he happens to be in the neighborhood. And during those three months you will get a 15% discount on any Gryphon product.
C.E.C pokazał w Monachium nowy konwerter DA 0 3.0 mający być idealnym kompanem dla napędu TL0 3.0
Wilson Audio podało, że najnowsze kolumny z ich stajni będą nazywały się Yvette (na 99% będzie to następca modelu Sophia III).
Wilson Audio Yvette w całej okazałości. Zdjęcie z profilu Wilson Audio na Facebooku.
Z taką nazwą to nie mają czego szukać na rynku, gdyby nazwali kolumnę Iwan - to co innego.
"Naukowe teorie mnie nie interesują. Zresztą kogo tu interesują? To jest forum dla audiofilów."
Ayre QX-5 twenty, pierwszy DAC i streamer w jednym wykorzystujący chip ESS SABRE ES9038PRO, dodatkowo oferujący dostęp do Tidal, Deezer i "Roon ready".
Nazwa trochę nie pasuje do kolumn o tak zwalistym kształcie...
No i jest bardzo popularna w innym sektorze produktów...jak wpisałem Yvette to mi coś takiego się pojawiło;-)
