Hi-endowe nowości
Elberoth
Pewnie uznali, że Aluminium jest lepsze.
Ich rozwiązanie jest jednak inne niż to stosowane przez pozostałe firmy. Zamiast litego alu, obrabianego na CNC, stosują dwa odlewy aluminiowe - wewnętrzny i zewnętrzny - połączone jakimś sziteksem bitumicznym. Jest to więc swoisty 'sandwich' aluminiowy.
“The Lyra is an extremely difficult speaker to build. It has been in design for three years. We committed to take the first pair in August 2015. To our knowledge no other speaker cabinet is as quiet. Each speaker weighs more than 500 pounds. The cabinet consists of two 1.5″ thick aluminum castings, one inside the other with 150 pound of elastic damping material between them. There are no fasteners of any kind between the two complex castings. The assembly is very time consuming. After assembly, the casting must be finished which is another long process. Very few will ever be built because of the intensive effort required to assemble and finish each speaker. The price is $149,500 per pair delivered setup and voiced. If you can make that level of investment, it is well worth it. The price includes our installation and alignment in your room. A full day must be allowed for this process and requires our two-person team. The expertise and knowledge of our team is part of what you get when you buy Lyra from us. No simple geometry or any other computer aided process is a substitute for our team that knows music and does setup by listening.
The Lyra is a 3.5 way system using 5 drivers. The crossover is complex. Once each speaker is finalized the crossover is encased in material to prevent vibration from inducing distortion into the individual crossover components. Each speaker is finalized by the designer, including auditioning in the Rockport sound room.”
szkoda,że nie piszą ile waży taka membrana aluminium sandwitch... dla mnie to jedynie potwierdzenie tego, że marketing jest ważny, żeby sprzedawać, nowe modele wymagają nowych bajek.
i dotyczy to wielu firm tzw. hi-endowych, których ceny są absurdalne. Kiedyś 9 tys. USD kosztowały topowe thiele cs7.0, dziś 10x tyle kosztują kolumny wcale nie lepsze
  • 4 tygodnie później...
dCS zaprezentował swój Network Bridge.
Świetna wiadomość dla wszystkich właścicieli przetworników Elgar/Puccini/Paganni/Scarlatti, a także innych hi-endowych DACów bez wejść USB.
Zwraca uwagę zastosowanie wyjść SDIF-2 - pozwoli odtwarzać pliki DSD nawet właścicielom 15-letniego Elgara+ !
Jest też wejście Clock-In więc będzie można to wszystko spiąć wspólnym clockiem, czy to z DACa, czy to z zewnętrznego clocka.
Making the Network Bridge
Chris Hales, dCS Director of Product Development, gives his take on the new Network Box…
“This is for people who bought into pre Vivaldi, to give them access to network streaming of audio. Scarlatti, Paganini or even classic Elgar owners don’t have access to this – unlike the new Rossini – and it's increasingly becoming the way that people are consuming music”, explains Chris Hales. “This special product really came out of that need. In essence it's using the network hardware that we have in Rossini and Vivaldi, all the IP and know-how that we built up over the period that we have been developing that. It receives audio via UPnP, Apple Airplay, Spotify Connect, TIDAL and other sources and outputs bit perfect au-dio in a form that a legacy dCS DAC can use, and that’s really what we are try-ing to achieve.”
Chris says that it was a case of using the tried and tested dCS streaming plat-form and adapting it for this special box of tricks. “As far as the network hard-ware design is concerned, our platform is now well developed, although need-less to say some customisation was needed.” As with the new Rossini, the net-work hardware itself is supplied by Stream Unlimited in Vienna. “The Rossini uses a Stream 800 board which is a very capable network solution, and the Network Box is using a variant of that – the Stream 820. This is essentially the same board, but with a slightly more powerful processor, plus it’s wi-fi enabled. We really wanted to take advantage of this feature.”
He says that dCS always recommends a wired connection for the best sound, “…if you possibly can. This is because you are guaranteed bandwidth which you are absolutely not with a wireless connection. But some users although they stream all their music files, may enjoy the added flexibility of wi-fi.
“The board itself is self contained and is not modified,” explains Chris, “as de-livered by Stream Unlimited. But needless to say, it requires power supplies and is flexible in its own right. So one of the key things that we have done is to alter the clocking. So the Stream board plugs into a motherboard that has some typi-cal dCS circuitry on it that basically gives you all the benefits of our clocking system that you'd have in any other dCS product. The very high quality clock-ing gives low jitter, and of course it has our usual power supply arrangements. Traditionally we don't make too much fuss about dCS power supplies because it’s something that’s just got to be done right, but perhaps that’s dCS modesty – you need to do things well if you want things to work right. But the Network Box power supplies are typologically similar to what you would find on a dCS control board, with ultra low noise…”
In terms of connectivity, Chris says dCS, “is trying not to be too partisan”, so it could be used with both dCS and a very wide range of other manufacturers’ products too. “But the general idea is that if you have a dCS product, be it the very early Elgar or the most recent Scarlatti, you will be able to use this box to maximum effect. So we have processing options which will allow you to downsample to whatever the maximum sample rate your DAC can cope with, or not as you wish. The idea is to make the box as transparent as we possibly can where we can, and then to process minimally to suit your DAC where that's appropriate.”
“The motherboard has a big Field Programmable Gate Array (FPGA) on there as you’d expect from a dCS product, which does all the processing and all the logic and so forth. It’s not quite the monster that we have inside the Rossini but nevertheless we've got a lot of processing in there that can interface with the Stream 800 board and take that and send it out onto the digital output and so forth. So the processing platform is typically flexible and upgradable, as ever with dCS. All the software is done in-house as usual, from our algorithms to the control coding. What we have inside is by no means a generic Stream 820 by the way – there are lots of features which didn't exist before we commissioned them to build those in. We had a lot of dialogue with Stream Unlimited to shape the architecture of this board and to integrate these new features into our pack-age. I think many of the performance features wouldn't have been developed, if we weren't the lead customer on those…”
Overall, Chris says the new Network Box is an interesting niche product that will expand the horizons of both dCS fans and the wider audiophile public alike. “It’s a product for the legacy market, but with very much the quality of that processing that you would expect from dCS.”
Zaloguj się, aby zobaczyć treść (możliwe logowanie za pomocą ) Edytowane przez Elberoth
Rockport, śladem Magico i YG, poszedł w aluminium
Przyjdzie dzień, w którym z tego materiału zrezygnuje.
Accuphase DP-950/DC-950
Czy nie nazbyt często zmieniają te swoje flagowe modele.
Coś dla miłośników ,,czystego prądu" i wielbicieli wyrobów Transparent Audio.
Przy okazji można zauważyć, że takie urządzenie może wyglądać zgrabnie i nawet małżonka je zaakceptuje;-)
Transparent OPUS PowerIsolator
W komplecie jest też 2 metrowy przewód - OPUS Power Cord
Dżentelmeni o cenach nie mówią, ale wszyscy inni mogą się dowiedzieć, że ta nowość została wyceniona na $15,950 USD.
"Puszka Pandory" juz teraz wiadomo za co placimy,coraz ladniejsze puszki,ktore kosztuja wiecej niz sprzety audio,na co musimy liczyc po otwarciu takiej "puszki pandory" opisuja cytuje " Pandora, niebacznie otwarłszy wieko, pozwoliła by zawartość – uleciawszy – powróciła do siedziby bogów; ludziom pozostała tylko nadzieja"
Czy ktoś zna cenę tego dCS-a ?
Jeszcze nie podali.
Pozdrawiam wszystkich,
czy miał może ktoś okazję widzieć i słyszeć to na żywo ?
Nie sądzę. To taki supermarket z różnymi gadżetami za spore pieniądze. Często przerost formy nad treścią.
za niebawem Jadis wprowadza do swojej oferty nową integre....cena 2tys euro
pewnie będzie to konkurencja dla małego Lebena i innych wzmacniaczy do 10tys
15 W w klasie AB
4 x 6L6
2 x ecc83
1 x ecc82
Dla Lebena nie ma konkurencji w tym przedziale cenowym :)))))
Taki zarcik ,ale zawsze można zweryfikować :)))
Nie ma ale będzie...tego dotyczył wpis Kolegi Miroslava
Gość Paweł Skurzewski
Mały Leben to nie ma konkurencji do wielokrotności 10 tysi,tylko trzeba słuchać muzyki a nie rajcować się zerami po przecinku.
300F i np. Harbeth30.1 kasuje wiele,naprawdę bardzo drogich wynalazków,tylko trza nastawić własnych uszu a nie cudzych.
Podjedz Paweł posłuchasz mojej wersji :)
Zapraszam
Od Lebena 300 lepszy i tańszy jest Lar . Leben jedynie wizualnie mi się bardziej podoba ale tutaj chyba znaczenie ma jakość dźwięku.
Nie chcę tu offtopować,ale słuchałem tego sławnego Lara,błagam litości,obok Lebena i to nawet takiego na Sovtekach nie powinien stać,to jest inna klasa dźwięku inny pułap,wystarczy odrobina osłuchania. Lar oprócz łupnięcia nie ma niczego wciægającego,słabiutka stereofonia,szara barwa,kluchowaty bas,tylko jebnięcie,ale sorry to za mało. Czytałem Twoje przygody z wyborem pieca,cóż dużo przyjemności życzę....
Noworuskie paranoje!
Nowe OPPO 203 z obsługą 4K UHD i HDR nadchodzi:
Nowa wersja Klimaxa DS - Katalyst:
Nowy VPI Titan z napędem magnetycznym !
....faktycznie nie można odmówić małemu Lebenowi uroku.....bardzo miło słucha się muzyki
ale ale....jeżeli nowy Jadis zachowa zalety które posiadają wyższe modele tej firmy...to kto wie jak będzie ...w każdym bądz razie kibicuję Jadisowi ;-)
proponuję mały zakładzik (tak dla zabawy) o butelczynę gorzałki ;-)....co Ty na to?
... zrobimy małe porównanie tych wzmacniaczy na Harbeth m30.1
I to jest klasyczne piękno i nadzieja dla słuchających muzyki;-)
Transparent faktycznie przegina z ich "filozofią kreowania cen" sama sieciówka Opus to u nas 15 kilo zł;-(
Nawet lobbujący za Lebenem Pacuła dał swojego do poprawek dla twórcy Lara i przyznał że ten jest lepszy od Lebena.
No i jakoś LARa nie kupił a Lebena 300F zamówił w ciemno. Nic mi do Twoich wyborów,swoje wiem. Pozdrawiam.
Prośba o nie robienie off topów.
Dyskusję o Lebenie można prowadzić w przeznaczonym do tego wątku:
