Hi-end&vintage kolumny JBL
lukag72
Pmcomp dobrze pisze, bo podobnie jest nawet Everestach w trybie Bi-Amp odpada filtr górnoprzepustowy dla drivera średnio-wysokotonowego i dolnoprzepustowy dla woofera grającego bliżej owego drivera.
Nawet jest napisane :
HF Drive/LF Drive
''These jumper bars allow you to set the loudspeakers for normal operation (using a single stereo amplifier or pair of mono amplifiers) and bi-amp operation (using two sets of stereo amplifiers and an external dividing network). The shorting bars are set at the factory for Normal (single-amplifier) operation, so move the shorting barsonly if you are bi-amping the loudspeakers.
Setting the LF- and HF Drive shorting bars in the Bi-Amp position bypasses the speaker’s crossover function for the full-range woofer and the high-frequency driver. The low-frequency woofer and the ultrahigh-frequency drivers are unchanged. Setting the shorting bars in the Bi-Amp position requires the addition of an external dividing network (electronic crossover) to provide the 750Hz (DD65000) or 850Hz (DD67000) primary crossover point for the system. The built-in attenuation and equalization for the 476-series high-frequency driver remains in place. The high-frequency level trim control remains operational, as does the diode biasing for both the low-frequency and high-frequency network sections.
Normally, all three sets of shorting bars (two LF and one HF) would be moved together to set the loudspeaker for bi-amping. It is possible to operate the system with just the low-frequency system or the high-frequency system set for bi-amping. In this circumstance, it would be necessary to use a combination of an external dividing network and the internal network. However, this is not generally recommended.
The graphs below shows the low-frequency and high-frequency voltage drive functions necessary to properly bi-amplify a DD65000 or DD67000 system using an external dividing network and two amplifier channels. Neither the low-pass nor the highpass drive is a standard Butterworth alignment or, for that matter, a standard alignment at all. The provided drive curves were derived using the internal passive network and resulting acoustic low-pass and high-pass shapes. Duplicating these shapes will result in the same frequency response and directivity pattern as the passively driven system. The low-pass section is made up of two cascaded second-order sections and the high pass is a single high-pass section. The values within a high-quality analog dividing network can usually be modified to achieve these results. Recent digital crossover units will have no problem duplicating these curves.''...
Hmm, przecież w trybie Normal powinno się dać podłączyć Bi-wiring po usunięciu tylnych zwór głośnikowych przy terminalach/zaciskach głośnikowych. A jak Bi-wiring by się dało, to i Bi-amping bez żadnych zewnętrznych/elektronicznych zwrotnic? ...tworzących jeden dolno i górnoprzepustowy filtr w trybie Bi-Amp.
To Ty Pmcomp masz podobnie w swych 4343, bo górnoprzepustowy dla drivera (HF) idzie z lampowej zwrotnicy Audio Research EC-4, a z pasywnej dolnoprzepustowy dla drivera (HF) i górnoprzepustowy dla tweetera (UHF).
Co to ma niby dać? Nie lepiej aby całość była pasywna i wtedy nie trzeba żadnych dodatkowych zwrotnic :-)
Zaloguj się, aby zobaczyć treść (możliwe logowanie za pomocą ) Edytowane przez atlon11
Tak jest w standardzie ale to "głupie" połączenie bo cała para na basie idzie psu w dupę przez ten przełącznik który jest w 100% zaśniedziały i druciki 0.5mm między wooferem a terminalami.
Dlatego nie ma sensu tego tak podłączać tylko puścić kable bezpośrednio do woofera i wtedy jest jak pisałem.
OK, zgadza się, sam tak mam.
Ale puszczanie reszty przez pasywny filtr górnoprzepustowy przez te same druciki zamiast wykorzystać zwrotnicę aktywną IMHO mija się z celem. Ale to moje zdanie, chyba że masz te 52uF na Duelundach ;).
Pozdro
No tak, ale w twojej opcji sygnał dla obu par wzmacniaczy wchodzi w zwrotkę, a tam do tych tub to tylko dla sekcji basowej i dla reszty w ogóle omija zwrotnicę, czyli ona w ogóle "nie widzi" sygnału dla średnicy i góry. To trochę dziwne.
Te tuby nie przenoszą najniższych częstotliwości, kończą się na przypuśćmy 100hz. (Nie chce mi się sprawdzać w ich spec.)
Nie muszą być podłączone do aktywnej zwrotnicy bo mają na tej częstotliwości naturalny spadek.
Subwoofery podłączone są do aktywnej zwrotnicy po to, aby je "uciąć" na górze, na tych "100hz" i pewno pochylić odpowiednim rzędem tak żeby zgrały się ze średnicą.
Proste i tanie rozwiązanie.
Mało wyrafinowane do tak wyrafinowanego systemu.
Ale tutaj Mirek ma rację, że przełącznik i kabelki to zło którego trzeba się pozbyć.
Całość pasywna nawet z midrangem?
Wtedy potrzebowałbym dodatkowo kupę dobrych, pasywnych elementów:
- kondensator 20uF i cewkę 1,7mH
- kondensator 4uF plus kondensator 13,5uF i cewka 1 mH
- ok. 7-u dobrych rezystorów Mundorfa lub grafitowych.
Policzcie ile to kosztuje. Kondensator 4 uF i 20uF coś dobrego bym wybrał ale 13,5 uF musiałbym składać najprawdopodobniej z trzech albo i więcej. To średnitonowy papier więc zapewne musiałyby być Jenseny. Majątek. Na szczęście na cewki taśmowe mam dobre i tanie źródło ale tekiw wartości będą wielki i tanie też nie będą.
Do tego obudowy, druty Beldena, gniazda z czystej miedzi. Uffffff.
Ponieważ mam wszystko na zewnątrz najprawdopodobniej kiedyś zbuduję zewnętrzną zwrotnicę na pasywnych elementach zgodnie z oryginalnym schematem. Z nudów jak mi się znudzi słuchanie muzyki i zacznie mnie swędzieć :).
Pozdro
BTW mam do sprzedania oryginalne zwrotnice do JBL 4343 czyli model 3143. Nie ruszane, nie grzebane, działające, w oryginalnych obudowach. Ze wszystkimi oryginalnymi drutami, przełącznikami i tylnymi panelami z terminalami głośnikowymi. Bez L-Padów bo one robią w moich kolumnach za ... maskownice :).
Pozdro
Pozdro
Całość całość, nawet z LF ;-) i wszystko z CC na diodach prostowniczych jak w powyższych DD65000 & DD67000
Możesz sprawdzić tamte autotransformatory (Finemet Autotransformer Attenuator) i cewki (Finemet Cut Core Coil) z najnowszych zwrotnic Kenrick'a w których są sygnowane jego logiem – ale wyglądają podobnie do Teramoto.
Grają razem z Jantzen'ami Silver Z-cap i Mundorf'ami M-Resist Supreme, w jego najlepszych zewnętrznych zwrotnicach do 4343
Tu masz ciut starsze zwrotnice do 4350A na słabszych Jantzen'ach Superior Z-cap i ogromnych cewkach Big E-Core Coil :
Kondensatory w środku to ... słabe ;).
Ja wolę lampową zwrotnicę aktywną. Jej podstawową zaletą jest możliwość prostej i szybkiej regulacji wzmocnienia dla każdego pasma oraz kształtowanie brzmienia poprzez wymianę lamp.
I kosztuje mniej niż wypasiona zwrotnica pasywna, na której BTW tracone jest od cholery mocy.
Wady zwrotnicy to potrzeba zastosowania dodatkowych interconectów.
Pozdro
Co interconektów sobie nie potrafisz zrobić , przecież to banalnie proste ;)
Niektórzy kupują co najmniej jakieś reference za pierdyliony więc lojalnie uprzedzam. Jedna para wejściowa i trzy pary wyjściowe. Może wyjść drożej niż całe kolumny ;).
Pozdro
W High Endzie nie ma umiaru, liczy się końcowy efekt ale najgorsze są wąskie gardła o dziwo czasem do usunięcia za parę złotych.
Do 4350 / 4355 (z 2 x 15'' + 1 x 12'') to można dostawiać domowe HL90 lub pro 2395 slant-plate acoustic lenses
4350 podłączył pod starą elektronikę Levinsona, która gra ciemnym/gęstym dźwiękiem – nie moje granie, wolę nowe/lepsze Levinsony. On tam powinien podłączyć ultra-transparentną i jaśniutką elektrownię, a nie stare ciemne Levinsony, ale pod stary Jazz to mu wystarczy.
W tych tubowych kolumnach; wysokie, średnie, i wyższy bas ze zwrotnicami o nazwie Active Biased Xover, a subwoofery z Active line Bass Xover included.
4 Way Horn loaded
Solid MDF buit Horns
Frequency response
from 25 Hz to 40 kHz
Active Biased Xover
Multiamp ready
Sensitivity 110 dB
ABW* Separate Bass System
Configured to your room size
Custom options available
Xover Points : 110Hz / 650Hz / 9kHz - jak widniało kiedyś na stronie sadurniacoustics, ale już nie widnieje, bo pewnie sami nie mają ich ostatecznie ustalonych, dlatego na innych stronach podawano np. 125Hz / 600Hz / 10kHz, albo jeszcze inaczej dla modułów basowych 120Hz.
Rozpoznaje, że na UHF gra Horn Tweeter Fostex T500AMkII
Nie widać co w średnio-wysokotonowym zakresie i wyższym basie, ale wooferki z zewnętrznych modułów basowych może ktoś rozpozna?
ct6a7474.jpg?w=860&h=572
ct6a7475.jpg?w=860&h=572
ct6a7488.jpg?w=860&h=572
...o proszę, myśleli że nie znajdę wspomagaczy / dopalaczy ;-) ... a jadą na dopingu / koksie z bateryjką 9V :-)
To są ABW Bass Modules :
''An array of 3, 4 or more Bass modules per side can be used according to room size and bass appeal. Please consult with us about your needs.
For smaller rooms 2 bass modules are enough and stay almost out of sight hidden behind the horns.''
Ale jak skojarzyłeś sobie z tzw. tubami basowymi, to możesz spróbować wstawić do auta takie dwa czworo-paki ;-) ... ale prędzej Tobie wejdą dwa czteropaki :D
To co nazywają tubami basowymi to są subwoofery w obudowie typu ''tube''
Bass Horn jest na wyższym basie, ale to nie tuba :-) ... tylko Upper Bass Horn
A może to połączenie tuby z hornem ;-)
Jak by nie te "moduły basowe" to bym pomyślał,że ktoś wreszcie skonstruował "tuby basowe" :-)
Tuby basowe istnieją od lat, GOTO / YL-Acoustic miał w ofercie taki potężny driver, specjalnie do basu:
Zaloguj się, aby zobaczyć treść (możliwe logowanie za pomocą ) Edytowane przez Marek.S
Niezła kolekcja tweeterów :
Air Motion Transformer (AMT), TAD PT-R9, Yamaha JA4281B, Fostex T500AMkII, Fostex T90A-EX, Fostex T90A, TAD ET-703
Nie za dużo tych przetworników – aż 7-dem w paśmie średnio-wysokotonowym i to na wypasie
Dostawka do 4343 – Elac 4Pi Plus.2 super-tweeter (0.006 mm aluminum ribbon)
Srajan Ebaen pisał o nich :
Najlepsze tweetery, dokładnie ultra-wysokotonowe drivery grają z D44000 Paragon – z góry tuż nad hornami są dostawione JBL UT-045Be
K2 S7500 (1400Nd / 475Nd) + UT-045Be
Wcześniej było tak :
K2 S7500 i S9500 to kolumny o konstrukcji modułowej. I tak, dla S7500:
B95 System Base Module – moduł bazowy, podstawa (50kg / szt.) z możliwością regulacji/wypoziomowania na czterech punktach oparcia.
3000M Low Frequency Module – 8-kątny moduł niskotonowy o objętości około 57-litrów pracujący w systemie bass-reflex z wooferem 1400Nd. Są to pierwsze na świecie niskotonowe przetworniki z neodymowym układem magnetycznym.
4500M High Frequency Module – w jego skład wchodzi wypasiony driver 475Nd (MF/HF) i elegancki horn z akrylu! – górna i dolna cześć horna. Boczne prawdopodobnie są z Medium Density Fiberboard i mają powierzchnię alumite wykończoną na lustro. Część do którego przykręca się driver jest wykonana z aluminium. Cztery pręty ze stali nierdzewnej przechodzą przez horn i z obu stron łączą się z wkręcanymi stopkami, z góry na stożkowych wgłębieniach, od spodu horna na kolcach.
Ho Ngo pisał, że ''about 75 lbs each'' – dla jednego horna...
Space Age Acrylic Horn
''The exceptionally inert S9500 horn is based on an acrylic material originally developed by the US space administration NASA. Two and a half times denser than MDF fiberboard, the horn is virtually non-resonant and stronger than any wood.''...
Zaloguj się, aby zobaczyć treść (możliwe logowanie za pomocą ) )%20-%20Depliant%20(English)%20(2000).pdf
''The horn would be designed as a monolithic acrylic molding that would physically separate the two bass enclosures.''
75M – górna płyta, tylko dla K2 S7500!
...''The clear acrylic horn is acoustically inert, and actually machined to precise tolerances. It incorporates a unique tubular energy transmission system. The horn assembly has no air spaces which could induce resonance.''...
Waga K2 S7500 to 124kg / szt., a K2 S9500 to 149kg. Ale ale, wyższy model (zamiast górnej płyty o nazwie 75M ... .) posiada dodatkowy moduł ''2000M Low Frequency Module'' – coś jak 3000M, tyle że niższy dla upper / second low freq. unit
K2 S7500 & K2 S9500 były produkowane w czterech wykończeniach: BQ, GYQ, GMQ, WMQ – dwa ostatnie droższe.
ZAIKA 845 PP (monaural) ? - kto to widział, kto to słyszał.
Prawie jak w piosence o Rafaell'u :-) ...
Piosenki o Rafaell'u śpiewają i jeszcze jak oczy do niego mrużą w min 0.25 - 0.28 / 1.18 - 1.20 :-)
Albo uśmiech w momencie 2.01 - 2.02 ... ''to :) Twoje imię''
Dalej śpiewa: ''znaczy dla niej srebrną noc złoty dzień śniegu biel'' ...czyli trochę inaczej niż w oryginale, autorki tekstu do piosenki o Rafaell'u.
Nie toż, że Rafael ma piosenkę o sobie, to jeszcze w kilku wersjach...
A którą wersję woli sam Rafaell.s.cable? ...
RAFAEL (wersja 1)
Ach! Kto to słyszał kto to widział mieć na imię Rafael?
Czy przy muzyce czy przy winie ktoś Ci dał imię to Rafael?
Rafael (x2)
Jak to tak ?(x2)
Czemu tak? No powiedz…
Rafael
Rafael nie zatańczysz nie zagadasz to nie szyk, nie styl
Rafael życie mija trudna rada a Ty wciąż chodzisz zły
Rafael (x2)
Jak to tak ?(x2)
Rafael
Gdzieś na tym świecie jest dziewczyna której nie śmieszy to
To Twoje imię znaczy dla niej srebrną noc złoty dzień
Śniegów biel
Rafael (x2)
Jak to tak? (x2)
Rafael (x4)
Zieleń łąk,
Śniegów biel (x2)
Rafael (x…)
RAFAEL (wersja 2)
Rafael (x2)
Czy Ty masz (x2) w życiu cel ?
Rafael
Rafael nie zatańczysz nie zagadasz to nie szyk nie styl
Rafael Zycie mija trudna rada a Ty wciąż chodzisz zły
Rafael (x2)
Czy Ty masz w życiu cel?
No powiedz…
Rafael
To Twoje imię znaczy dla niej srebrna noc złoty dzień śniegów biel
Rafael (x2)
Czy Ty masz (x2) w życiu cel?
Rafael (x…)
Zieleń łąk
Śniegu biel…
アレキサンドライト邸を訪問
Ciekawe, L19 i 4301 jednak nie są takie same. Paczki z L19 są płytsze i szersze od 4301, te mają idealnie kwadratową podstawę.
Szkoda że te 4301 mają tak zmasakrowane obudowy, szczególnie na spodzie gdzie brakuje 50% rogów. Na razie są na diecie - piją tylko rozcieńczony klej do drewna :-)
Jakoże obudowy w JBLach to paździerz muszę najpierw wzmocnić wszystkie obicia zanim je zaszpachluje bo inaczej dalej będą odpryskiwać albo szpachla będzie pękać.
Co do szpachli jeszcze nie jestem pewien, ta do drewna będzie raczej zbyt miękka żeby odnowić rogi obudowy. Myślałem nad szpachlą epoxy, taką do naprawy łódek ale cena zabija.
Będę potrzebował jeszcze pary LE25 bo w moich były te obrzydliwe LE25-4 ze srebrną obwódką i jedna kopułka jest wgnieciona.
No i jeszcze zostaje kwestja wooferów 116A, 116H. Mam idealną parę ale w L-19 a szkoda mi ich rozbierać na części.
Poza tym - ostrzeżenie gdyby komuś, tak jak mnie przyszło do głowy myć fronty w małych JBLach - rozsypią się zaraz po zamoczeniu.
W 4343 stelaż jest z drewna, w L100 Century również, dlatego można je normalnie spryskać płynnym proszkiem do prania i spłukać zimną wodą.
Stelaż w L19 i innych maluchach jest z jakiegoś paździerza który chłonie wodę jak gąbka i nawet po wyszuszeniu rozsypuje się w drobny mak.
Panowie,
Mam uszkodzony kosz w głośnikach Urei 809c, poszukuję nowego na wymianę. Słyszałem, że takie kosze były w różnych głośnikach, zna ktoś może jakich mam szukać? Ewentualnie czy aluminiowy kosz można zespawać ?
Pozdr
strumieniowiec, lampy i tuby
To zmodyfikowany kosz JBL 2214H,
Pozostaje tylko wymiana, JBLe mają tak małe tolerancje że raczej na pewno kosz zostanie krzywy.
Dzięki za odpowiedź, spróbuję z pastą aluminiową kleić a w międzyczasie będę szukał kosza na wymianę. Na ebayach narazie bida:-)
Ciekawe, w jakich okolicznościach mógł pęknąć ten kosz?
I w którym miejscu? Jak pękł w jednym miejscu, to jakimś 'najlepszym' kilkuskładnikowym klejem do aluminium, można to mocno skleić.
W Urei 809c masz coś w stylu coaxial'a o nazwie Urei 803 :
Jak piszą w technical'u do JBL/UREI 809A, jest tam Co-axial Transducer (803) i Compression Driver (2416H-1) :
Czym się różnią poszczególne wersje JBL/UREI 809 ... A / B / C ?
JBL PROFESSIONAL PRODUCTS - REPAIR KIT "GOES INTO" LISTING:
Jakże podobne przetworniki grają z osobna w 4425 (2214H / 2416H+2342 Bi-Radial Horn) i S101 (2214H / 2416H+2371 Bi-Radial Horn) :
Dzięki Atlon11, kosz pękł dookoła przy miejscu mocowania do obudowy, o dziwo sam głośnik gra idealnie. Kurier kulomiot nim chyba rzucał:-) obudowa też do naprawy. Mam już miejsce w krórym mi zrobią tj. zespawają precyzyjnie.
PS. Fajne zwrotnice, też będę sobie takie zamawiał, trochę mam okazję się pobawić tymi monitorkami
Tak to już jest z tymi firmami kurierskimi, gdzie po części pracują jełopy, którzy przy przeładunku rzucają paczkami o inne paczki. W paczkach np. sprzęt audio, a obok jakieś żelastwa owinięte samą folią i to wszystko rzucają jedno na drugie. Ilu osobom fizycznie uszkodzili sprzęt audio: odtwarzacze, przedwzmacniacze, czy końcówki mocy w których grube aluminiowe radiatory wyglądały jakby ktoś w nie przy....dolił z grubej stalowej rury. Albo tak jak w Twoim przypadku z kolumnami Urei 809c – ona musiała konkretnie gruchnąć o coś, że tak pękł kosz, a sam przetwornik swoje waży, pewnie gdzieś z 12 kg, a razem z obudową 27 kg / szt., do tego opakowanie i będzie z 34 kg dla sztuki.
Przy takim pęknięciu nie ma co kleić, bo gdy dasz głośniej a z tym i więcej basu, to jeszcze odpadnie to klejenie/łączenie. Ale jak elegancko/precyzyjnie zespawają to powinno być OK.
Ciekawe, która firma kurierska tak uszkodziła Tobie kolumnę?
Wiesz jak u nich jest, choćby w 'UPS Polska' mają masę reklamacji, a ku.wy w dziale prewencji i likwidacji szkód, piszą to co im tam każą, czyli jak nawet sami wiedzą że uszkodzenie jest z ich winy, to i tak zawsze mają pisać że nie stwierdzono zaistnienia odpowiedzialności.
To tak jakby kurier dostał w facjatę z gaz-rurki i nikt nie stwierdził odpowiedzialności :D
Ci kurierzy podczas swej jazdy nawet koła urywali, bo jeżdżą po krawężnikach na skróty. Albo specjalnie rzucają paczkami o glebę, gdy tylko zobaczą napis lub naklejkę: ostrożnie, szkło - lub coś w tym stylu.
Do pracowników UPS pasuje jak ulał: 'Ups...niechcący opuściłem / rzuciłem paczkę' :D
Since JBL's inception, the purist of audio perfection has been the driving force behind everything we do. This is exemplified by the use of Beryllium as the diaphragm material for the high-frequency and ultra-high-frequency compression drivers used in the DD67000. A rare and extremely expensive precious metal, Beryllium is the ideal material to achieve the lifelike clarity, detail and dynamic sound that has made this flagship JBL loudspeaker legendary.
Mogę firmę zareklamować:-) , to Siódemka S.A, Zmartwiłeś mnie tym klejeniem, miałem nadzieję, że już po sprawie.
Skrzynka już pojechała do naprawy.
Przy okazji, jak zerknąłem na okablowanie wewnętrzne to aż się prosi o wymianę na coś pożądniejszego, Masz jakieś propozycje?
Wogóle myślałem o wyjęciu zwrotnicy na zewnątrz, z zamówienie nowej na lepszych elementach. Lata robią swoje a wiem, że w tych głośnikach tkwi duży potencjał. Chcę dodatkowo dodać supertweeter więc zrobiłbym wszystko za jednym zamachem:-)
Zwrotnice czy okablowanie w UREI / studyjnych JBLach to nigdy nie był hi-end, to po prostu miało działać. Możesz dać dam coś porządniejszego typu Belden/Canare czy Van Damme, na tweeter raczej nie więcej niż 2.5mm2 bo mogą się zrobić za ciemne.
Belden 9497 byłby dobry ale ciężko go dostać i jest drogi.
Ciekawostka - ostatnio rozebrałem dwie zwrotnice model 3103 ze Studio Monitorów 4301 i pomierzyłem kondensatory (Electro Capy, te zasypywane piaskiem) - jak nowe!
Wlutowałem je spowrotem i tylko wyczyściłem L-pady.
Dzięki za info, kabelki poszukam, przy okazji dziwne czasy nastały, że starocie trzymają parametry, a nowe się po roku rozjeżdżają, jakiś czast temu do monobloków sprawdzaliśmy kondensatory blackgate WKZ i rzeczywiście stan igła. Szkoda, że nie można już ich dostać.
Niby studyjne i nie hiend, ale jak wczoraj u znajomego podłączyliśmy moje stare Urei 813c to powyrywało włosy z tyłków. Już nie robią takich kolumn.
