Panowie, pomocy. Może głupie pytanie, ale podpowiedzcie proszę jak dodajecie cały album do ulubionych w myvolumio grając z natywnego Tidal?
Wklejam rezultat komendy:
dmesg --level=err,warn
po zatrzymaniu odtwarzania.
[    0.209552] brcm-pcie fd500000.pcie: could not get clock
[    0.269790] bcm2708_fb soc:fb: Unable to determine number of FB's. Assuming 1
[    0.270163] raspberrypi-firmware soc:firmware: Request 0x00048003 returned status 0x80000001
[    0.270198] bcm2708_fb soc:fb: Failed to allocate GPU framebuffer (-22)
[    0.270251] bcm2708_fb soc:fb: probe failed, err -22
[    0.270284] bcm2708_fb: probe of soc:fb failed with error -22
[    0.297292] bcmgenet fd580000.genet: failed to get enet clock
[    0.297354] bcmgenet fd580000.genet: failed to get enet-wol clock
[    0.297383] bcmgenet fd580000.genet: failed to get enet-eee clock
[    0.297419] bcmgenet: Skipping UMAC reset
[    0.297657] unimac-mdio unimac-mdio.-19: DMA mask not set
[    0.356191] genirq: irq_chip Brcm_MSI did not update eff. affinity mask of irq 53
[    0.440543] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    0.442296] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    0.443926] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    0.446833] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    0.448460] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.347906] systemd[1]: Failed to bump fs.file-max, ignoring: Invalid argument
[    1.423536] usb 1-1.4: config 1 has an invalid interface number: 3 but max is 2
[    1.423584] usb 1-1.4: config 1 has an invalid interface number: 3 but max is 2
[    1.423617] usb 1-1.4: config 1 has an invalid interface number: 3 but max is 2
[    1.423662] usb 1-1.4: config 1 has an invalid interface number: 3 but max is 2
[    1.423700] usb 1-1.4: config 1 has no interface number 2
[    3.466007] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[    3.599408] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[    3.599413] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[    3.615423] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[    3.619435] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[    3.626013] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[    3.932368] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    4.165400] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    4.178923] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Feb 27 2018 03:15:32 version 7.45.154 (r684107 CY) FWID 01-4fbe0b04
[    6.791621] bcmgenet: Skipping UMAC reset
[ 5697.139386] usb 1-1.4: 3:1: cannot set freq 44100 to ep 0x3
[ 5697.141767] usb 1-1.4: 3:1: cannot set freq 44100 to ep 0x3
No jest coś nie halo. Spróbuj najpierw inny kabel (chodziło mi a połączenie z DAC), zwykły 'od drukarki', może ten co masz jest trochę za audiofilski do tego sprzętu ?
Czyli te zmiany z wcześniejszego posta nie pomogły? Jak kończysz odtwarzać utwór, na DACu znika połączenie?
Rega RP2+ // Pro-Ject DAC Box RS // Yamaha A-S1100 // KEF R700
pomoże ktoś proszę?
Na innym kablu podobnie, raz gra raz nie. Dodatkowo w dmesg:
[  127.762852] usb 1-1.4: reset full-speed USB device number 4 using xhci_hcd
I tak jest za każdym razem po przerwaniu odtwarzania.
2 godziny temu, Patrykowski napisał:
Ale pytam poważnie, jak go sformatować. Ma to jakieś znaczenie? nie soniczne rzecz jasna ? użytkowe.  Chce z niego korzystać na Pi4 przede wszystkim ale czesem pewnie się zdarzy podpiąć pod PCta czy makbooka. Może jakieś pliki tam będą w sieci domowej, raczej te dwa zastosowania. Może jakieś partycje zrobić, tylko czy one nie wycofają mi średnicy, którą lubię ?
Ja z tymi rożnicami w dźwieku to  żartowałem.Używam systemu xfs bo jest lepszy do dużych plików niż ext4.
Najgorszy jest ntfs.Tyle ze dysku z ext4 czy xfs nie podłączysz do windowsa.Do macbooka to nie wiem
To wiem ?
No nic, poczytam o tych systemach. Dzięki.
Co masz zainstalowane na tej malinie?
10 godzin temu, jurek1 napisał:
Poświęciłem stary kabel Usb, wykorzystałem czarny i czerwony przewód i nawet nie drgnie
Miałem podobnie jak źle polutowałem kabelek do wtyczki USB C. Kropka cyny stykała dwa piny. Możliwe, że niepoprawnie polutowałeś albo wtyczka/kabel są niesprawne.
Potem będę analizował co nie tak. Narazie sprawdziłem na ładowarce że urządzenie sprawne i zastanawiam się co na nim postawić, bo na karcie jest Raspbian. Ściągnąłem Moode, szło chyba trzy godziny i nawet jak postawie to dalej nie wiem jak Tidal uruchomić. W Daphile to było proste, a tu czytam jakieś tutki na angielskojęzycznych stronach. Ale puki co ta ciemność widzę ?
Spoko, jak mnie się udało odpalić tidala, też dasz radę :)
To nie jest do końca  prawda. Zależy do czego ten dysk ma służyć, bo np. ->
Tuta już widać, że coś się dzieje.
Ale wcześniej też nie jest OK. System aktualny? Dłubany ręcznie?
Podłączyłem mainę z systemem Moode, kabel ethernet i wpisałem na telefonie adres podany w instrukcji, i nie mogę się połączyć, co robię nie tak?
Edytowane przez jurek1
A masz zdefiniowane wifi na malinie już?
Nic nie mam, korzystam z kabla, i nie mam pojęcia jak ten adres zdefiniować. W tutce Ruci jest to klarownie wytłumaczone, i wygląda na to że jest to zaledwie kilka czynności i że można wpisać adres Moode lub maliny którego nie znam
Sprawdź jakie IP ma przydzielone Moode na routerze. Czymkolwiek ?
On się sam przydziela. Tylko trzeba podejrzeć.
Ale najpierw trzeba zdefiniować wifi w malince.
Fajnie, tylko nie mam pojęcia jak ? myślałem że Daphile jest trudne w konfiguracji, ale byłem w mylnym błędzie
Zapomniałem dodać że wszystkie czynności, jak format karty i zapis obrazu wykonałem na jabłku, adresu Moode też szukałem w Safari, może to ma jakiś wpływ...
Idź według te jinstrukcji
Podłączyłeś kablem ethernetowym, to już nie dotyczy cię wariant AP (access point)
  • Moderatorzy
Fajnie, tylko nie mam pojęcia jak myślałem że Daphile jest trudne w konfiguracji, ale byłem w mylnym błędzie
Zaloguj się na router i sprawdź IP albo jakis IPScaner
Ja tę instrukcje znam, i nią się też po części kierowałem. Tam przy kablu AP jest też wymagany, a żaden z podanych tam się nie otwiera. Nic, znalazłem jakiś skaner na maca i poszukam IP
Poszło. Zainstalowałem skaner, znalazłem IP maliny, ale teraz z kolei nie widzi mojego przetwornika. W polu wyboru jest NA
  • Moderatorzy
Prawy górny róg – moode - configure audio i tam wybierz swoje hifiberry lub allo digione
i zatwierdź set
później moode - restart -reboot
wyskoczy reconnect to zaakceptuj
wejdź jeszcze moode configure-audio -MPD edit settings
i tam powinno być volume control - disable
sprawdź czy tak masz
i czy  Audio output jest i2saudio device
to jest przetwornik Wadia na usb. Po części tak robiłem ja piszesz Ruciu, ale podkusiło mnie żeby coś pogrzebać w modyfikacjach. Zaznaczyłem architekturę 64 i była jakaś opcja usb do odhaczenia . Po restarcie nie widać IP maliny i nie swieci się zielona dioda. Jak wspomniałem zasilam to maleństwo z ładowarki tel, może jest jakiś system zabespieczeń przed przciążeniem, więc wyłączam na jakiś czas bo malina zimna jak lód, jakby umarła
Zrobiłem zasilanie ULPS pod gniazdo usb-c i zaświeciła się dioda czerwona, na ułamek sekundy zielona i malina dalej zimna. Pod portem ethernet dioda swieci się na żółto
Jest 5,3v na liniowym i dokładnie takie samo pod obciążeniem, a zasilanie impulsowe było z ładowarki tel, tyle że tylko 2A. Wuczytałem gdzieś w sieci że malina ma jakąś formę zabespieczeń wewnętrznych, która powoduje odcięcie układów na droższy czas, piszą że nawet nakielski dni. Pytanie czy to jest zabezpieczenie przed wyższym napięciem, czy działa to ona zasadzie jakichkolwiek odstępstw od normy np: za mała wydajność prądowa zasilania ?
Moode 6.4.0. Próbowałem volumio, rune, raspotify na raspiana i wszędzie podobnie.
Tutaj już widać, że coś się dzieje.
Po zainstalowaniu moode, zrobiłem jeszcze rpi-update.
Odnoszę wrażenie, że po włączeniu maliny wszystko gra ok, a z czasem zaczyna się sypać.
Raz wcześniej, raz później.
Jakim obciążeniem, i gdzie mierzyłeś?
Sama malina bierze ok. 0,5-06 A. bez obsługi zewnętrznych urządzeń.
