Hi-endowe nowości
Elberoth
Gramofo AV Design Haus Dereneville VPM 2010-1
$650.000
Ultimate turntable, electronic microscope built in, tightest tolerances ever.
Translated from German
Heavy, solid Corian chassis (60 kg), standing on air suspension feet.
Toe angle measurement by laser, Tangential linear unit with a stepper motor.
Belt drive with two frequency-controlled motors Tern EBM-Pabst.
Speed ​​measurement using a pulse ring with 24,000 pulses per revolution.
Plate mass: 20.5 kg ball bearings, worn by Neodyn magnetic disks.
effective shielding due to large mu-metal layers in the dish.
Scanner-camera to the empty groove recognition, track selection via touch screen.
Gimballed special tone-arm, length and height.
Integrated digital scale at the parking position of the pick.
Balanced XLR audio output. Video output S-Video / BNC
2 built-in microprocessor controls, touch screen remote control.
Ethernet connection for easy software updates and remote diagnostics.
All parameters, such as system operating hour coverage, speeds and much more,are always available on the touchscreen.
Integrated high-resolution Miniature camera to observe the sampling system during playback.
Completion mid 2011
ARC Reference 150
150 Watt
Tube stereo power amplifier using (4 matched pairs) KT120 (Power output); 6H30 for each of the output stages.
Features:
* Solid-state, multistage, regulation
* Larger, wide-bandwidth output transformers
* Each channel is fan-cooled using low-turbulence intake grates, with three selectable fan speeds.
* Balanced XLR inputs
* 12V triggers arrayed on the rear panel.
* 20-amp IEC power connector
Na razie nie mam budżetu ... ale kto wie :)
Mnogość oferty na audiomarkt duża,a tu narzekania na brak budżetu?
Wydaje mi sie ,że przy swoim kupnie klocków po prostu przepłacasz!!
Elberoth pomógł bym Ci pomóc szczerze piszę,ale mnie zbanowali w wątku h-end w niskiej cenie-na tym się znam!!
Nie wiem czy by Cie to usatysfakcjonowało,bo u Ciebie to tylko h-end w wysokiej cenie jest-taki preferujesz?
Najnowsze Martiny Logany EM-ESL. W stanach kosztują tylko $1999 - ciekawe ile u nas sobie za nie AK zażyczy ? 8kzł ?
Cena jest na pewno okazyjna jak na głośnik elektrostatyczny - $1999 kosztowały w 1992 ML Aerius, które od EM-ESL były dużo mniejsze (sam panel ES w EM-ESL ma aż 90cm wysokości, dzięki czemu ma aż o 40% większą powierzchnię niż ten w Aeriusach). Zważywszy jak bardzo wzrosły ceny sprzętu przez ostatnie 20 lat - jest to fakt godny odnotowania.
Efektywność 91dB, a więc wysoka, i impedancja 6 Ohm.
Ciekawe czy będzie w Monachium ?
Może nie nowości, ale nie ma tego za bardzo gdzie wrzucić jako ciekawostkę
Zaloguj się, aby zobaczyć treść (możliwe logowanie za pomocą ) ktoś miał do czynienia z ktorymikolwiek z nich?
Hmmm ...
Synergistic Research Tesla Series SE AC Power Cords
The unique part of the new TESLA SE AC Power Cords is their ability to change the voicing via three different Active Shielding Modules (“Bullets”). Each module has a different sonic balance:
- Silver Module = Open and airy
- Black Module = Warm and rich
- Grey Module = A hybrid of both the Black and Silver
Now you can fine tune your system’s AC to perfectly match your components, and when or if you change components, you can change the voicing as well. It’s like having 3 Power Cords in 1.
Zaloguj się, aby zobaczyć treść (możliwe logowanie za pomocą ) Edytowane przez Elberoth
Strasznie brzydkie ... i drogie :(
The Magico Q1 is a 2-way stand-mounted monitor housed in a fully braced, fully damped hard anodized aluminum and copper enclosure with a completely new set of Magico-designed drivers including a 1-inch Beryllium tweeter and 7” Nano-Tec® mid/woofer that has been developed to extend 7 cycles lower than the Mini II's and deliver improved system efficiency and greater power handling. This allows the Q1 to be satisfactorily powered by high-quality amplifiers with as little as 50 watts.
Specification are 86dB sensitivity, 5-ohm impedance, 32Hz to 50kHz bandwidth, dimensions including stand 44” H x 15.2” D x 10” W and weight of 120lbs. The Magico Q1 will sell for $24.950/pr when it becomes available in the third quarter.
Rzeczywiście brzydkie,ten co to projektował pojęcia ani gustu nie posiada.Basowiec jednak zacny,no i te wieżyczki...dramat i pachnie chińszczyzną na kilometr.
Gość HarpiaAcoustics
Tymczasem te kolumny są "amerykańsko-polskie" :)
Edytowane przez HarpiaAcoustics
Ja pisałem że Magico brzydkie !
Tyle było mowy o SD playerze AA, o tym jaki to przełom itd.
Tutaj gotowe rozwiązanie do kupienia od ręki, w budżetowej cenie, ale kto wie, może to jest high-end:
Nośniki trzymane w pudełku po butach...tak to jest przyszłość.
Krell Cipher CD/SACD
We are excited to announce the new Krell Cipher SACD/CD player. The Cipher extends the elegant Krell industrial design while advancing the state of the art in SACD/CD reproduction. Housed in a classic Krell machined Aluminum cabinet and available in silver or black, the beautiful exterior only hints at the sophisticated disc playback technology within its walls.
Featuring an advanced disc drive and coupled to the latest Krell digital and analog output circuitry, the Krell Cipher delivers the ultimate performance from today’s highest resolution source material. Every performance enhancement is incorporated to retrieve the most accurate signal from SACD and CD music titles. Isolated mechanically from the underlying chassis, the drive mechanism utilizes composite mounts to minimize vibration induced errors. Special sound dampening material is strategically placed inside the unit to minimize mechanical resonances even further. Krell customized disc drive firmware enhances reading accuracy, drive mechanics, and operational parameter. As an ultimate final step, the separate SACD and CD laser heads are individually calibrated by hand for the precise output levels required for reference quality SACD and CD playback.
All signals are fed into a custom designed Krell anti-jitter module that reduces jitter to a virtually immeasurable level. From there, signals are fed to a 24 bit/192 KHz digital filter and then to a pair of balanced 24-bit/192 kHz digital-to analog converters (DACs). Conventional players use one DAC for both channels and convert the current output of the DACs to voltage, a process that invariably causes signal distortion. Instead, the Cipher uses one DAC per channel and feeds the native balanced current output directly to Krell Current Mode circuitry. The sonic penalties of current-to-voltage conversion are thus gracefully avoided. By using balanced DACs, the Cipher maintains a dual differential balanced signal from the DACs all the way to the output connections. This lowers distortion and improves signal to noise ratio to their maximum levels. Core Krell technologies of discrete, complementary, direct coupled circuitry are employed throughout the surface mount based output stage. Evolution CAST and balanced connections are included for optimal stereo playback. Multichannel SACD playback is also supported.
The backbone of all audio components is the power supply which is often minimized in lesser players. The Cipher includes independent power supplies for the digital and analog sections to maintain signal isolation between these circuit areas. The Cipher linear power supply is sourced directly from the designs used in Krell Evolution e Series amplifiers. This massive design preserves the dynamic contrasts that can get muted in players using switching or digital power supplies.
The Cipher has a US retail price of $12,000 is available now.
Dynaudio Confidence Signature
Accu A46
Kolejny brzydal:
O kurna!Ale potwór ;).
Shunyata jakąś niespodzianke przygotowała?
Anacondy głośnikowe i interkonekty,ceny "przywoite":
Daniel Hertz tez brzydkie:
Cena $100,0000 jak zwykle w przypadku ofert M. Levinsona budzi mieszane odczucia:
Ponoc najdrozsze kolumny podstawkowe swiata - Magico Q1 za jedyne 25 tys. zl.
Plus o polowe tanszy odtwarzacz CD Krella - CIPHER.
