Hi-endowe nowości
Elberoth
  • 1 miesiąc temu...
Dwie nowe elektrownie od amerykanskiego producenta PS AUDIO.
Power Plant 10 - dostarcza do 1250W mocy ciaglej i 70 Amp. / $4999.99
Power Plant 5 - dostarcza do 1000W mocy ciaglej i 50 Amp. / $2999.99
Produkowane w USA, Boulder, Colorado.
Parker's Mood
Nowinki z TRI
końcówka mocy TRI TRX P 6L
Auto Biasing - enables use of 3 different types of tubes.
Tubes: 4x 6L6GC (KT88 or EL34) 2x 12AX7, 2x 12BH7
Power Ourput:
6L6GC: UL - 2x25w / Triode - 2x12w
KT88: UL - 2x30w / Triode - 2x15w
EL34: UL - 2x30w / Triode - 2x15w
Frequency Responce: 10Hz-100kHz
S/N Ratio: 90dB
Input Sensitivty: 600mV
Input Impedance: 100kOhm
Input Gain: 0, -3, -6dB
NFB: 0, 3, 6dB
Input Terminal; 1 RCA
Output Terminals: 4, 6, 8 Ohm
Power Standbye: 100w
Power Running: 220w
Size: 340W x 315D x 187H
Weight: 15kg
Preamp TRX-1
TRI's new TRX Reference series class A tube Pre-amplifier.
It has a unique 4x band frequency equalizer 150Hz, 400Hz, 2kHz, 10kHz
Fitted with ultra high end German Mundorf Capacitors and Japanies KOA Resistors
Remote control
Specifications:
Tubes: 4x 12AX7(ECC83) & 1x 274N(5U4G)
Frequency responce: 10Hz - 100kHz
S/N ratio: 96dB
Input Sensitivity: 250mV
Output Impedance: 6kOhm
4 Band equalizer: 150Hz, 400Hz, 2kHz, 10kHz
KOA resitors (Japan)
Mundorf capacitors (German)
Input Terminals: line 1-5
Output Terminals: 3
Power consumpsion: 30w
Weight: 8kg
Zaloguj się, aby zobaczyć treść (możliwe logowanie za pomocą ) Edytowane przez wiedzmin1973
Nowa, zjawiskowo piękna linia Elegance od Kharmy -> modele DB7 (20 000 euro) oraz DB9 (27 000 euro).
Type: EL-dB7-1.0
System: 2-way
RMS Power: 150 Watt
Program power: 300 Watt
Frequency range: 29 Hz - 30 kHz
Nominal Impedence: 4 Ohm
Efficience 2,83V / 1m: 88 dB
Maximum SPL: 110 dB
High frequencies: 1 x 1-inch True Beryllium tweeter
Mid / Low frequencies: 2 x 7-inch Kharma Composite Driver (KCD)
Type: EL-dB9-1.0
System: 3-way
RMS Power: 250 Watt
Program power: 500 Watt
Frequency range: 26 Hz - 30 kHz
Efficience 2,83V / 1m: 89 dB
Maximum SPL: 113 dB
Mid frequencies: 1 x 7-inch Kharma Composite Driver (KCD)
Low frequencies: 2 x 9-inch Aluminium woofer
Tutaj więcej zdjęć:
Nowe monitory studyjne średniego/dalekiego pola z Polski: APS Spanily 3way
Specyfikacja:
Bas:
Woofer - Ø 10,24" (26cm), celuloza
Wzmacniacz - 300W RMS @8 Ohm, klasa A/B na el. dyskretnych
Średnica:
MidWoofer - Ø 5,9" (15cm), celuloza
Wzmacniacz - 100W RMS @6 Ohm, klasa A/B na el. dyskretnych
Góra:
Tweeter - Ø 1" (2,5cm), do wyboru tytanowa lub tkaninowa
Wzmacniacz - 100W RMS @6 Ohm. klasa A/B na el. dyskretnych
Zwrotnica:
Aktywna, częstotliwości podziału: 300Hz i 4000Hz
Pasmo przenoszenia w polu swobodnym:
+/- 2 dB: 25 Hz - 30 kHz
Wymiary:
Wysokość x Szerokość x Głębokość: 60 cm x 32 cm x 56 cm
Waga: 45 kg
Zaloguj się, aby zobaczyć treść (możliwe logowanie za pomocą ) Edytowane przez Kyle
Nowe APS'Y przypominają trochę Atlasy od Harpii - tylko niskotonowy mniejszy o parę centymetrów.
Czy to już było ;
Ciekawe czy gra tak jak wygląda ;-)
Gość Arek__45
..a moze to....
Here are some meaningless specs:
• Dual core 1.6Ghz Intel processor
• 4 GB ram
• 128 GB SSD (solid state drive) capable of storing over 200 uncompressed CDs or 2000 high quality mp3 CDs
(there's provision for 2 more drives so you can increase your capacity as your music collection increases)
• Blu-ray drive (including DVD/CD writer)
• IR remote control
• Windows 7 Pro
• J River Media Player 15 (full version)
Built in DAC in the form of the highly regarded Xonar Essence
• This has been modified and improved from stock
• Built in DAC eliminates the need for expensive interconnects or external clocks
Separate high quality dual linear power supply
• One 300va supply for the PC
• One 300va supply for the built in DAC
FSQF (Figlet Sound Quality Factor): 11 (out of 10)
http://thehifisubjectivist.noadforum.com/viewtopic.php?f=3&t=341&st=0&sk=t&sd=a
Piękny składaczek, zwłaszcza ta standardowa blaszka z płyty głównej. O gustownym podświetleniu i filarkach z pleksy juz nie wspomnę.
Ale mozna uzyc jako cokol pod kolumne wiec nie jest nudny.
Jak kosztuje 1000 zł to spoko - bo tyle samo mój pecet kosztuje :) Poza tym nie lubię niebieskiego.
P.S. mozna sobie podłączyć głośniczki 5,1 creative`a do tego :D i joystic do giercowania :)
NVA to manufaktura, ktora istnieje na rynku wiele lat, nigdzie sie nie reklamujac.
Nie lekcewazyl bym tego sprzetu nie majac wogole pojecia jak gra.
Opinie uzytkownikow.
Hi-endowych nowości mnóstwo na EXPONA, Atlanta, GA.
Świetna organizacja, miła atmosfera i dużo dobrej muzyki!
Zaloguj się, aby zobaczyć treść (możliwe logowanie za pomocą ) Edytowane przez Firebird
OPPO BDP-95
Już od lutego pojawi się zabójca chłamu. Poważnie przewartościuje rynek odtwarzaczy swoją jakością i możliwościami. A oto niektóre tylko cechy: genialne przetworniki audio SABRE do stereo i multichanel, video BD3D, czyta DVD-AUDIO, SACD, FLAC i WAV, używa streamingu, bezprzewodówki, posiada dwa HDMI, USB i eSATA do przyłączania pamięci masowych jak dyski z plikami!!!!
Kolega na sąsiednim forum ma to "cudo" i wcale jakoś nie pieje z zachwytu. Robił już parę odsłuchów różnych formatów dźwiękowych, ale w euforii nie jest! A przed zakupem też spodziwał się "cudów", ale to tylko produkt made in china!
Więc skąd to Twoje gdybanie?
Zaloguj się, aby zobaczyć treść (możliwe logowanie za pomocą ) Edytowane przez THX Ultra 2
Sony KD85-ZG9? , Denon AVC-X6700H + Monster Power MPA-3250 + Emotiva XPA 7-kanałowa gen.2 , Pioneer UDP-LX800.Projektor JVC RS2 - Adeo Tensio professional pro 110",Monitor Audio-Platinum PL 300 + Platinum PLC 350 + SVS Ultra + GX100 + 4 szt. sufitowe Dali Phantom H-80 +VELODYNE DD-15 Plus. Kable do kolumn: QED Genesis Silver Spiral, Chord Odysey 2. Listwa Monster Cable HTS 5100 + Power Center HTS 1000, kable sieciowe Monster Powerline 400 . Apple TV4K.
Jak wy ufacie opiniom innych :-) Same ochy i achy w szczególności Elba i wszyscy kupują np. rdaca....potem opychają w ogłoszeniach niezadowoleni...., bo jednak się im nie spodobał....jedna opinia taka sobie i już kupuje niewielu, albo i prawie nikt, ale ten co kupił to jednak jakoś zdarza się, że jest zadowolony, choć ta jedna recenzja jakaś do kitu była :D
Poza tym jak ktoś chce stricte 2ch to niestety być może musi się liczyć z większym wydatkiem np. na wersję NuForce'a.....
Osobiście mam 83SE NuForce i nie zamieniłbym się na żaden inny odtwarzacz, a też punkt odniesienia miałem....ale to oczywiście moje zdanie subiektywne i nic poza tym.
Zaloguj się, aby zobaczyć treść (możliwe logowanie za pomocą ) Edytowane przez zyzio
U mnie w marcu minęło już dwa lata jak użytkuje Pioneera BDP-LX-91, ale jakoś nie korci mnie na coś nowszego. Firma dba o niego i uaktualnione oprogramowanie pokazuje się dosyć często Póki co nie widzę dla niego konkurenta. Za 3D też dziękuję dopóki będzie w okularach...
Mac Mc601 (następca 501):
Razem z nim debiutuje Mc452 - w miejsce 402.
I nowy transport CD (!) od CECa - TL3:
Jak dla mnie dzieło sztuki.
Dan D'agostino Momentum Monoblock Amplifier
Cena to jedyne 42000 baxów ;)
Te obrabiarki CNC rozpuściły zupełnie producentów audio ;)
Ale obróbka maszynowa ani materiał na obudowę aż tyle nie kosztuje.
Nowa seria Focus 2 od Dynaudio:
-All models in the series have been improved in many ways.
-New and more refined form of kabninet and improved design.
-Designed generally become more contemporary and modern.
-Newly developed mid and bass drivers
-New crossovers.
-New housing design matched crossovers
-New on offer are a real wood veneer in dark walnut, and finishes in piano black and white.
