Klub otwarty  ·  599 członków
Hegel Klub
Klub HEGEL
Albo super okazja.
https://www.audiostereo.pl/topic/92363-klub-hegel/page/36/#findComment-2971620
Low noise, superb sound from Hegel
Bent Holter, founder of and designer for the Norwegian company Hegel, explained that his circuits are based on work he had done designing ultra–low-noise preamplifiers for the European CERN laboratory. Hegel's new H80 D/A integrated amplifier ($2000) replaces the H70, which was introduced in 2010, and uses the low-noise preamp circuit from the $5500 H300 amplifier and Hegel's patented feed-forward "Sound Engine" amplifier topology. It has two single-ended analog inputs, one balanced analog input, and five digital inputs, including USB. Though this doesn't operate in the usual asynchronous mode, it uses a proprietary reclocking topology said to eliminate jitter. The H80 offers 75Wpc into 8 ohms compared with the H70's 70W.
Hegel's HD25 DAC ($2500) uses a 32-bit AKM chip and offers even lower noise than the DAC used in the H80. In a series of level-matched comparisons between the H70 and H80 and the HD25, the H80 offers improved clarity and better low-frequency extension and control compared with the H70. While the best sound in the system, which featured Magico S1 speakers ($12,500/pair) and Nordost Red Dawn cables, with digital data sourced from a MacBook Air, was with the HD25's analog outputs feeding the H80, the H80 fed digital data sounded superb for $2000.
Perhaps the most exciting new product Hegel was showing at RMAF was the Super, a $399 portable USB D/A headphone amplifier. Machined from a single block of aluminum, this has a digital-domain volume control, but the circuit's noisefloor is so low that it is claimed to preserved resolution at lower volumes. The Super also has an extremely low output impedance so should be able to drive even the most demanding headphones with ease. Stephen Mejias hopes to be writing about the Super in a future "Entry Level" column.
http://www.stereophile.com/content/low-noise-superb-sound-hegel
Edytowane przez Violet
https://www.audiostereo.pl/topic/92363-klub-hegel/page/36/#findComment-2971718
Widze na zdjęciu kolumny Wilson Benesch :) Hegel z tymi kolumnami dobrze się zgrywa?
https://www.audiostereo.pl/topic/92363-klub-hegel/page/36/#findComment-2971728
A ja się już na spokojnie umówiłem u nas na odsłuch H80 w audiostylu w sprzedaży ma być 10 listopada, eee niech delphinusy z nim pokażą jak brzmi nirvana czy metallica:) zresztą tam pracują moi kumple:)
Violet
Jakie twoje wrażenia po H80:)
https://www.audiostereo.pl/topic/92363-klub-hegel/page/36/#findComment-2973696
kaaapa- sluchalem delphinusy jestem troche zmieszany bo wg. tego co mam to sa przynajmniej jedna klase nizej jak te dynaudio focus 160- niestety taka prawda, cena tez mowi swoje..
Edytowane przez FIRMA
https://www.audiostereo.pl/topic/92363-klub-hegel/page/36/#findComment-2973764
zmienialem na szybko 'grabki':) i chario maja bas na min 25m.kw ale nie taki niski jak F160 maja jego bardzo duzo nie schodzi nisko jak w focusach i niby gora milutka ale dla mnie stanowczo jej troche za duzo/wysoko..
https://www.audiostereo.pl/topic/92363-klub-hegel/page/36/#findComment-2973810
Bo delphinus ma aksamitną górę podaną w delkatny sposób do tego brzmienia trzeba przyzwyczaić są to piękne monitory z basem których może się uczyć wiele firm
https://www.audiostereo.pl/topic/92363-klub-hegel/page/36/#findComment-2973833
dla mnie sporo slabiej wypadly jak F160- ciekawostka, standy firmowe chario to jakas parodia- wykonanie w calosci mdf, jeden stand sfiinx jest ciezszy jak ponad 2 standy firmowe chario- standardowo chario maja zamiast kolcow przylepce z gumy a po wkreceniu kolcow stabailnosc szkoda pisac- na czyms musieli zaoszczedzic..
https://www.audiostereo.pl/topic/92363-klub-hegel/page/36/#findComment-2973848
Tu się zgodzę firma z tobą mogli postarać się o coś lepszego, przez to bas w chario jest bardziej plastyczny i troszkę mniej kontrolowany, co innego gdyby je postawić na granicie wtedy nabierze swojej twardości i tego zejśćia
https://www.audiostereo.pl/topic/92363-klub-hegel/page/36/#findComment-2973869
Panowie, przez niezwykły zbieg okoliczności, H80 zagościł na trochę u nas. Jest na co czekać. Tylko patrzeć, jak inni producenci obniżą ceny... :)
Kto słucha, nie błądzi...
https://www.audiostereo.pl/topic/92363-klub-hegel/page/36/#findComment-2973930
Ja to wiem chyba jestem pierwsza osoba w naszym pięknym kraju który go słuchał dokładnie soundgarden norge, jest to świetny wzmak do 10000pl nie ma konkurencji!!! Nawet h100 musi mu sie podporządkować poza wyższa moca
https://www.audiostereo.pl/topic/92363-klub-hegel/page/36/#findComment-2973940
Chętnie,tylko że moje godziny pracy pokrywają sie z Audiostylem! W piatek byłem tam 15 minut przed zamknięciem. To mało czasu na odsłuch! Bede musiał cos wykombinować, bo w ciemno nie kupie!
https://www.audiostereo.pl/topic/92363-klub-hegel/page/36/#findComment-2974000
Napisz coś więcej o H80, z czym porównywałeś?
Tak jak napisałem, przerzuciłem już sporo kg w tej cenie. Nie warto szukać. W kwestii poprawy nuiansów, możesz dopłacić sporo, tylko czy warto? Do 8tyś, nic nie znajdziesz, co można porównać. Może jakąś sprytną dzielonkę, ale nie będzie daca. Koledzy z Norwegii postanowili zagrać wszystkim na nosie...
Panowie, przyjedźcie do nas. Mamy świeże rybki, posłuchamy muzyki, wypijemy GoldWasser i pójdziemy poszukać bursztynu... :) Godziny do ustalenia.
https://www.audiostereo.pl/topic/92363-klub-hegel/page/36/#findComment-2974003
Tak, jak Atoll IN100, uważam, za wzmacniacz wybitny, sporo powyżej budżetu 4000zł, i według mnie, nie ma konkurencji w przedziale do 6000zł, tak samo H80 sporo powyżej 6790zł.
Atoll IN200, jest dobrym produktem i wielu osobom ma prawo się podobać bardziej niż Hegel H80. Natomiast z czystej statystyki wynika, że H80 nie ma konkurencji... Choćby przez swoją multimedialność... Samo brzmienie, też według mnie bardziej wyrównane, z większą dynamiką, więcej energii, tzw. muzykalności, fanu....:) Na moje uszy oczywiście...
https://www.audiostereo.pl/topic/92363-klub-hegel/page/36/#findComment-2974028
Mocowo to wyczytalem, a jak pradowo? Miales okazje podpiac do jakichs wymagajacych kolumn (w stylu ATC)?
Szukam (ciagle) czegos co da duzo pradu, a przy tym bedzie umialo zagrac nawet przy mocno skreconym potencjometrze.
BTW Rozmawialismy, mialem wpadac ale spedzilem uroczo czas na Klinicznej :(
P.S. Skad w Trojmiescie wezmiesz swieza rybe? ;)-
https://www.audiostereo.pl/topic/92363-klub-hegel/page/36/#findComment-2974043
Z Pucka..., albo Jastarni. Nie napisałem, że będzie na miejscu, Zapraszam na świeżą, a od tego są specjaliści. Tawerna jeszcze mnie nie zawiodła... A tatar z łososia bałtyckiego - wzór!!!
https://www.audiostereo.pl/topic/92363-klub-hegel/page/36/#findComment-2974050
Jakby co to ja też jestem chętny na odsłuch H80 w Audiostylu ...
W kupie raźniej ;-)
Trzeba tylko poprosić żeby jakieś sensowne kolumny przygotowali ;-)
Pozdrawiam z Katowic !
https://www.audiostereo.pl/topic/92363-klub-hegel/page/36/#findComment-2974053
Co do brzmienia, to kłopot jest taki, że wszyscy oczekują jedoznacznych deklaracji, a takich nie składam, bo chcę być uczciwy. Im bardziej wymagający, osłuchany klient, tym więcej konfiguracji trzeba przerobić. Jak chcesz napędzić i wycisnąć wszystko z ATC SCM 40, to Hegel H200 się przyda... Wszystko poniżej, obniża przekaz kolumn.
https://www.audiostereo.pl/topic/92363-klub-hegel/page/36/#findComment-2974056
