Najciekawsze konwertery USB / SPDIF (AES/ EBU)
globtroter1
Ostatnio to m.in. i dla mnie bardzo aktualny temat. Miałem okazję poznać już trochę urządzeń tego typu. Fajnie zgrupować najciekawsze z nich w jednym wątku. Zacznę od przykładu "topowej" nowości, która wkrótce będzie u nas dostępna. W kolejce: Audiophilleo1, Stello U3, HiFace EVO, Halide Design Bridge i inne... Zapraszam do dzielenia się własnymi doświadczeniami.
Soulution 590 USB Converter 24/192.
"DSP-Converter
A powerful DSP manages the communication with your computer. The received data is buffered in a large RAM memory.
The 590 USB Converter is able to process music files in PCM format with a maximum sampling rate of 192 kHz and a word lenght of 24bit.
Reference Clock
The high-precision clock of the USB-590 converter ensures optimal sound.
We apply here a technology that is based on the 540 SACD player. The wordclock signal available at its outpus allows to synchronize your D/A converter as well.
Powersupply
The USB converter 590 is power via the USB connection from your computer. Its power supplies are expensively filtered for the best possible separation from your computer. The quality of the clock signal is substantially influenced by the quality of the supply voltage. Noise components with high frequencies can significantly affect the sound quality.
Additionally, these noise signals could be distributed through the interconnecting cables to your DA converter and - depending on the design of your DA converter - reduce its perfomance as well.
Connections
Digital outputs:
- 1 x SPDIF (RCA)
- 1 x AES/EBU (XLR)
- 1 x Optical (Toslink)
Digital inputs:
- 1 x USB
Clock-Ausgang:
- 1 x Wordclock (BNC)"
Zanim zejdziemy na ziemię:). 2850 USD.
The Sonicweld Diverter HR USB to S/PDIF Translator
The Diverter HR is a best-in-class USB to S/PDIF converter which has been continually refined since its successful introduction in 2009. The Diverter HR allows your PC or Mac to function as a reference-class digital music source.
Asynchronous USB 2.0 Operation
Passes 16 bit and 24 bit audio data with sampling rates of 44.1, 48, 88.2, 96, 176.4, and 192 kHz
Unique ultra low-noise internal power supply regulation with aggressive common and differential mode filtration circuits for optimum performance using USB bus power
Computer-optimized power delivery networks for wideband, extremely low power supply impedance
Low-jitter master oscillator with ultra-short differential clock delivery path and dedicated, triple-regulated power supply
Active inrush current management protects USB controller
Custom ten-layer circuit board made from high-performance microwave substrates; employs high-speed digital design PCB layout techniques and uses multiple ground and power planes
Custom enclosure milled in-house from solid 6061-T6 aluminum alloy plate, with stainless steel constrained layer damping plates
Ruggedized Amphenol USB "B" input
True 75 ohm BNC digital output ( BNC to RCA adapter provided)
Robust high-speed differential cable driver with galvanic isolation
Firmware field upgradable via USB
Top plate incorporates a dimmable LED dot matrix display which indicates the incoming stream’s sample rate
Plug and play for Mac users running OSX 10.6.4 or newer; ASIO-compatible driver is supplied for Windows operation (XP through Win7)
100% USA designed and manufactured
Ciekawy i nieco tańszy :) jest konwerter jarkaC na DIY.
Posiadam,... działa bezbłędnie :)
Konwerter JarkaC postaram się zamówić w pełnej wersji z dwoma generatorami i rozbudowany o izolację galwaniczną, dodatkowo może z AES/EBU. Z tego, co przekazał mi Jarek widzę, że jeszcze chwilę to potrwa, ale pewnie z czasem i tu będzie można go opisać i porównać do czysto komercyjnych konstrukcji.
W uzupełnieniu odnośnika do opisu V-Link II dodam tylko, że wg mnie to rzeczywiście dość dobre urządzenie, zwłaszcza w swoim przedziale cenowym. Jego brzmienie wydało mi się bardzo solidne. Nie ucieka się do sztuczek, np. z wyraźną manipulacją w paśmie. V-Link II gra raczej większym i zamaszystym dźwiękiem, z dość dobrą lokalizacją i prawidłową przestrzenią, ale też w sposób bardzo wyrównany.
Jedyne, co wychodzi w bezpośrednich porównaniach, ale dopiero ze sporo droższą konkurencją, to lekkie zubożenie barwy dźwięku i dość tonizujący charakter całości, ogólnie lekki brak wyrafinowania. Dla wielu urządzeń współpracujących będzie to jednak często tylko zaletą, a nie mając punktu odniesienie, dzięki wspomnianemu wyrównaniu, nawet pewnie tego nie zauważymy i szybko ten dźwięk zaakceptujemy.
To na zasilaniu z laptopa. Po podłączeniu zasilacza odcinającego zasilanie z kompa, dźwięk zyskuje. Wg mnie w tym przypadku nie są to zmiany drastyczne, choć co ciekawe, dotyczą w równym stopniu wszystkich aspektów dźwięku. Dla jasności: wg mnie V-Link II z dodatkowym zasilaniem za 100 Euro nadal jest gorszy niż niektóre, w tym kilka razy droższe konwertery bez niego. Warto jednak to zasilanie w granicach zdrowego rozsądku zastąpić zewnętrznym. Ciekawe czy i jakie ewentualnie zmiany wnosi wersja V-Link 192. Tej nie słuchałem.
W załączeniu zdjęcia obydwu konwerterów.
globtroter1 - miałeś też u siebie V-Linka II (w srebrnej obudowie) czy tylko mojego V-Linka (mk I) w czarnej ?
Masz rację. Trochę się pogubiłem z tym "linkami":). Miałem Twoją jedynkę , ale poza obudową flaki te same(?).
V-Link(I):
Tak wieść gminna niesie, ale prawdę powiedziawszy to nie widziałem bebechów V-Linka II aby porównać.
Twój opis V-Linka jest jednak 'spot on'. A jak ten Matrix ?
Używam od miesiąca u3 stello i jestem nim zachwycony. To ostatnio najlepszy upgrade jaki mi sie udało zrobić. Pochwały na 6moons były jak najbardziej zasłużone. Przede wszystkim zwiększyła się (tak to odbieram) szybkość dźwięku i scena (nie tyle nawet na boki, ale różnicowanie planów). Można bez problemu wypożyczyć do posłuchania.
Ja też używam Stello U3 jako głównego punktu odniesienia od ponad miesiąca. O nim z pewnością jeszcze napiszę.
Teraz chciałbym na chwilę jeszcze wrocić do wspomnianego Matrix'a USB. Można go kupić za około 200 zł z przesyłką. Cena jest chyba dobra zważywszy, że czasem nie potrzebujemy też dodatkowego kabla cyfrowego, a urządzenie wpinamy (możemy w zależności od wersji) bezpośrednio w gniazdo przetwornika. Nie miałem okazji porównać go bezpośrednio do V-Linka, ale w zasadzie początkowo mógłbym napisać podobne rzeczy o zubożeniu barwy i braku wyrafinowania sporo droższych urządzeń. Tu jednak, w przeciwieństwie do V-Linka przybiera to trochę inny charakter, chyba jeszcze mniej wyrafinowany.
O ile w przypadku V-Linka, a tym bardziej jeszcze lepszych konwerterów, możemy mówić o ekspolzji dość dużego, czy czasem wręcz zamaszystego dźwięku, tak tu, mamy bardziej wrażenie jego implozji. Przekaz traci już trochę na czytelności, zwłaszcza na skrajach pasma, pogarsza sie przestrzeń, przez co wzmacniony zostaje pierwszy plan i średnica - dość typowy obraz brzmienia wielu tańszych konwerterów i ogólnie wielu urządzeń audio. Objawia się to z całą mocą w ogólnym spadku emocjonalnego zaangażowania w odbiór muzyki. Opadamy więc na fotel odrobinę zawiedzeni, ale przy tej cenie i droższej konkurencji trudno oczekiwać fajerwerków. Reasumując wg mnie: sprawnie działąjący (Plug and Play), tani konwerter 24/96 (!) dla trochę mniej wymagającego słuchacza i systemu.
Bebechy V-Link II wyglądały mi identycznie jak widziane zdjęcie wnętrzności V-Link czarnego.
Tak, to jest to samo urządzenie. Różny jest tylko kolor obudowy.
Jeśli DAC - to NOS-DAC z buforem lampowym, jeśli wzmacniacz - to Pure Class A.
Osobiście użytkuję USB 24/192kHz M2tech Hiface.
Recenzje zachęcające, niestety nie miałem możliwości porównania do innych konwerterów.
Gorąco zachęcam do upgrade tego fragmentu toru.
Czytałem na ten temat, ale niestety nie mam aż takich umiejętności, aby w tym grzebać. Wiem, że za granicą robi to jkeny, ale nie przerabia powierzonych, tylko sprzedaje już gotowe upgradowane. No chyba, że robi to ktoś w Polsce, to chętnie bym "wszedł" takie coś.
Jeśli poziom pracy jkeny jest taki jak każdego innego irlandzkiego "fachowca" to radzę omijać szerokim łukiem.
To papraki. :)
Zresztą wystarczy wejść na "stronę internetową" (tak to nazwijmy...) jkeny, żeby nabrać podejrzeń co do fachowości autora.
Za to ceny - takie ceny w Irlandii nazywają "rip-off". Tutaj to powszechne.
Facet potrafi lutować w kraju, gdzie 99,9999% populacji nie wie, którą stroną trzyma się lutownicę. "W krainie ślepych jednooki królem"... więc w tym oceanie ignorancji nie miał wyjścia - musiał zostać guru. :)
Myślałem, też aby zaopatrzyć się w coś takiego jak:
AQVOX USB Low-Noise Linear Power Supply
Zapewnia izolację galwaniczną i zasilanie bez śmieci z komputera.
Też mam coś takiego :) Jeszcze nie miałem okazji posłuchać, ale pozyczałem globtroterowi do posłuchania i podobno dobre.
Najnowszy JK SPDIF mk 3 to już nie jest prosta przeróbka HiFace, tylko całkowicie od podstaw zbudowane urządzenie. JK wstawił tam m.in. nowy układ budujący sygnał spdif - i teraz cała elektronika chodzi z wbudowanej baterii 3,3V. W swojej cenie jest to moim zdaniem wybitne urządzenie.
JK SPDIF mk 3 gra u mnie od 3 tygodni.
(chwilowo mam więc JK, V-Linka, Halide i Matrixa, a więc już niezłe stadko ... a kolejne konwertery już w drodze ;])
Muchas gracias :)
Mój kumpel w Krakowie też ma. Wybieram się do niego jak sójka za morze od nie wiem kiedy. Co do poprzedniej wypowiedzi - tu się trzeba przesiąść na inne urządzenie, i to miałem na myśli. Ja nie widzę miejsca na upgrade w tak małej i ciasnej obudowie, żeby dał krok w przód, a nie w bok.
Myślałem o takim upgrade, ale to jest jakiś autorski projekt gościa z Tajwanu.
Poproszę forumowicza W_Waw o napisanie coś o konwerterach HiFace Evo i jego modyfikacjach, bo testował ostatnio koncepcyjną wersję.
Ma dobry system i jeszcze pół roku temu był szczęśliwym posiadaczem top loadera Musical Fidelity A1080, a dziś już słucha tylko z komputera i DACa.
Michale, czy cytowany powyżej Musical Fidelity V-Link II "zagra" lepiej z miom NOS-DAC'em niż obecny USB 24/192kHz M2tech Hiface?
Jestem tego pewny, ale też nie mówię, że V-Link to jest to, co ma być docelowo. Z HiFace Evo nie miałem do czynienia, być może jest jeszcze lepszy? Ja akurat przyznałem w swojej opinii o V-Link II, że na podstawie doświadczeń z nim mam wrażenie, iż po USB już można zajść dalej w sensie samego odtwarzaniu bitów niż używając odtwarzacza CD, natomiast do transportów kompatybilnych z gęściejszymi formatami nieco mu zabrakło, żeby się zrównać, przy czym nie zwaliłem tego faktu w całości na V-Linka.
Proponuję i proszę żebyś przyhamował trochę ze swoimi komercyjnymi i promocyjnymi zapędami w tym wątku. Wg mnie, czasem masz bardzo nachalny i autopromocyjny sposó bycia na tym forum, a to nie jest Twój wątek sponsorowany.
