Subiektywny ranking lamp EL34 / 6CA7 / KT77
jak to określił chińczyk w odpowiedzi "tubes have higher current data.."
cokolwiek to znaczy..
Sprawa się wyjaśniła, oferowane lampy mają wyższe prądy anodowe, powyżej nominalnych,
stąd ta ich niższa cena, nie wiem jak to się przekłada na efekt końcowy, trwałości itd..
Czyli wygląda, że są to lampy, które ze względu na zbyt mocno odbiegające parametry nie przeszły kontroli jakości.
Poszło z Commodore 64
Można je zaliczyć do kategorii "Standard Grade" różnica w specyfikacji może sięgać do 40%
All Treasure tubes from Grant Fidelity is of Premium Grade export quality from Shuguang and they are superior to those sold out of China or Hong Kong - which are intended for Chinese market and are commonly referred as Standard Grade. Standard Grade treasure tubes have much wider variance in specifications and could deviate from the tube's designed specs by up to 40%.
If you are looking for first class quality tubes and want protect your investment, we strongly recommend you to buy 'Premium Grade' only. The Treasure Premium Grade tubes imported by Grant Fidelity are further divided to Premium Grade A (perfect matching on every aspect and strong emission) and Premium Grade B (less than perfect matching in certain aspects such as plate current, transconductance or minor internal gas, slightly less emission. However we guarantee that none of these minor weakness will interfere with the tube's normal operation and pose no safety hazards to your amp. Grade A tubes are sold with a price premium over that for Grade B.
Even if you purchase 'Premium Grade B' tubes from Grant Fidelity, you are getting better tubes than the Chinese 'Standard Grade' sold over eBay type of places. Buyer beware.
Please note that Grade B tubes are guaranteed no DOA (dead on arrival) and carry the same warranty as Grade A. However, we do not warranty cosmetic appearance on Grade B tubes - they are categorized as B-stock with certain imperfections.
A tak z innej beczki: po co malują lampy mocy?
Black Tubes?...It is not paint- it is actually a carbon coating designed to trap any stray electrons inside the glass. I am fairly confident that the carbon coating also helps reduce micro phonics as well.
  • 4 tygodnie później...
Zauważyłem, że PSVANE dodał do opcji zakupu 150-godzinne wygrzanie lamp (+25$). Ciekawe czy to przy okazji nie wyeliminuje części wadliwych lamp bo z tego co czytam to często jest tak, że jak nie padną na początku to później już grają...
Na dole strony się wybiera, przykładowo dla EL34PH:
Nie mogę teraz znaleźć u nich na stronie tych Treasure, może już nie produkują?
"Few are those who can see with their own eyes and hear with their own hearts." A.Einstein
-edit-
pomieszałem strony, 6CA7-Z są, tylko na innej stronie :)
Porownalem u siebie w systemie
Shunguang 6ca7 gold treasure
Vs
Kt77 gold lion.
Mi lepiek podchodza gold lion. Dzwiek jest jest bardziej przestrzenny i aksamitniejszy, delikatniejszy , te aspekty sa przyjemne dla ucha i chce sie tego wiecej i odkrecac potencjometr. Wokale sa bardzo czyste i otoczone aura przestrzennosci. Dzwiek kt77 jest jakby ogolnie caly czystrzy. Ja czuje wiecej powietrza i slysze drobniejsze detale wydobywajace sie z przestrzeni.
6ca7 gold treasure sa barwniejsze. Slysze to szczegolnie na gitarach akustycznych. Dzwiek jest jakby gesciejszy/moze ciezszy, bardziej wypelniony, nie wiem jakiego okreslenia uzyc. Mimo barniejszej prezentacji wcale nie jest muzykalniej ani bardziej angazujaco. Te lampy maja tez wiecej basu. Ich dzwiek nie jest jednak tak czysty jak z kt77. Czasem w niektorych utworach cos mi jakby w niektorych dzwiekach przeszkadzalo. Jakby chropowatosc, zabrudzenie. No i brak gladkosci i subtelnosci na wokalach wzgledem kt77 sprawial ze nie chcialo mi sie az tak sluchac muzyki.
Moj system.
Diapason Adamantes III25th kolumny
Tri trv 35 se wznak
Glosnikowe i IC albedo monokrystal monolith.
Sieciowki oyaide gpx re v2
Transport lector digidrive t.l.3 z kablem cyfrowym albedo digital bnc
Dav Aqua Acoustic La Voce s2.
Do porownan mam jeszcze svetlany, 6ca7 EH, tung sole el34.
Jak porownam, to sie wypowiem :-)
Ciekawe porównanie, dzięki. Pokrywa się nawet w sporej mierze z tym autorskim, kolegi Severance :)
Z lenistwa, ale też z zadowolenia dźwiękiem nie chce mi się kupować i robić porównań z moimi RFT, ale gdyby użytkownik Psvane lub Gold Lion mieszkał w Trójmieście, można by zrobić pojedynek nowych lamp vs niemieckich NOS’ów.
Edytowane przez WuMike
Teraz porownuje kt77 gold lion z tung solami. Jesli chodzi o gore to ze skrajnosci w skrajnosc. Na Kt77 wszystko cyka,lekko wyostrzony jest tez wokal. Mniej barwy. Na tung solach gora znika. Jest cieplej i wokal lagodniejszy.
Jak wsadzilem spowrotem gold lion to troszke sterylnosc czuje i wyostrzenie wokalu troszeczke odrobinke przeszkadza. Trzeba by jakis zloty srodek znalezc. Chyba jeszcze shunguangi wsadze jeszcze.
No i porownalem jeszcze svetlany i mialy byc do tego EH. Jednak jak je wlozylem to na jednej bias byl zerowy. Czyli chyba zepsuta.
Wybieram gold treasure 6ca7 shuguang.
Maja przestrzen , barwe, detal, gore slodka i zaznaczona ale niemeczaca. Nie sa ani troche sterylne. Bas ladnie zaznaczony ale bez buly, ma barwe.
Wczesniej na jednej plycie mi nie podchodzily jak kt77 ale na jazzowych krazkach 6ca7 gold treasure wygraly.
Oby nie padaly szybko.
Jak u siebie porównuje Psvane 6ca7 Mark II , Tung Sol EL34 , 6ca7 EH to psvane wygrywają łącząc zalety jednej i drugiej a najmniej psując
A jak oceniacie EL34 Tesla Brown Base z dawnej produkcji,
Zdobyłem 20 szt. nowiutkich fabrycznie zapakowanych, ale narazie leżą sobie na półce i czekają jak się dorobię wzmacniacza pod te lampy. Jestem ciekawy jak oceniacie te lampy, czy ktoś miał z nimi styczność.
Nie znam tych lampek ale wyczytałem, że są brzmieniowo zbliżone do Mullardów. Jak jesteś bardzo ciekawy brzmienia to możesz wypożyczyć mi kwadrę to porównam z Mullardami xf4 i RFT.
Też tak słyszałem kilka opinij że są najbardziej do Mullarda zbliżone, konstrukcyjnie rzeczywiście są podobne, też podwójny geter.
Lampy są w stanie dziewiczym fabrycznie zapakowane narazie nie chciałbym ich ruszać.
Pewnie za jakiś czas część z nich będę chciał sprzedać, bo nie wykorzystam tylu lamp.
W ogóle to zastanawiałem się czy je kupić, bo tanie nie były, ale za kilka lat będą już pewnie nie dostępne.
Obecnie składam pp na EL84 ale jak znam życie to jeszcze mi z nim długo zejdzie, następny będzie SE na EL34/6P3S DOLAM
Mam też 4 szt. NOS w pudełkach RFT EL34 z 60 roku i 2szt. 72 r.
Jaka jest twoja opinia o RFT w porównaniu z Mullardami, czy rok produkcji ma znaczenie?
Z RFT EL34 mamy tak, że przede wszystkim różnica jest słyszalna pomiędzy wersją z krótkim oraz długim cokołem.
Nie miałem, przynajmniej świadomie, kontaktu z tymi lampami a być może rozglądam się za jakimiś RFT. Wiem tylko, że mają różne cokoliki ;) Mógłbyś pokrótce opisać te różnice w dźwięku.
Edytowane przez Mickey6
Koledzy a testowaliście PSVANE el34 HiFI ?
miałem u siebie , największa wada - awaryjne - miałem 3 komplety wytrzymały od kilku miesięcy do coś ponoć roku. Padały lampy po sztuce , była gwarancja i kilka miesięcy i dalej to samo . Z wyglądu i grania to 100% chiński "szogun" , tylko gorszy.
Czyli kicha. Idę zatem w EH 6CA7. Myślę, że się nie zawiodę.
Oczekuje szybszego grania bez zamulenia, i ładnej detalicznej góry ;-)
Musica curat cor meum et animam meam delenit
jj e34l (pisownia poprawna) grają z większym basem od 6ca7eh , ale nie są tak długowieczne . Z dobrze dobranymi lampkami w pre potrafią zagrać dynamicznie i rozdzielczo.
góry szukaj raczej w małych lampkach typu telefunken siemens
Jesli ma byc jasno i telefunken to tylko ribbed plate, a z tanszych polecam tesle, (mowa oczywiscie o malych lampkach)
Czasem lepiej nic nie mowic i wyjsc na idiote niz sie odezwac i rozwiac wszelkie watpliwosci.
Planuję utemperować nieco górne pasmo oraz dodać trochę masy i jednocześnie wprowadzić trochę klimatu, czy te mullardy będą odpowiednie?
Zaloguj się, aby zobaczyć treść (możliwe logowanie za pomocą ) Jak z ich awaryjnością?
12ax7 Psvane Treasure i 12au7 Psvane Treasure
Wysłane z mojego SM-G950F przy użyciu Tapatalka
No właśnie EL34 żadnych i chciałbym w końcu ich posłuchać i na własne uszy się przekonać. W związku z czym dobrze było by, aby posłużyły trochę.
Mi Tung-sole EL34B wycofały trochę górę w połączeniu z psvane 12au7. To dobre lampy ale dla mnie problemem było, że niektóre utwory przymulone były i z radością wróciłem do KT77 Gold Lion.
