Najciekawsze konwertery USB / SPDIF (AES/ EBU)
globtroter1
Pojawił się taki nowy konwerter Singxer F-1 XMOS. Płytka 4-warstwowa. Ktoś ma?
Jestem bardzo ciekawy porównania (także pomiarów) Muteca 3+ vs Singxera SU-1, świetnie by było gdyby dało się to wypożyczyć, ktoś to sprzedaje w Polszy? Czy ktoś wie czy TacT Millenium mk2 robi reclocking?
czy mutec mc 3+ usb na dzien dzisiejszy to nadal najlepsza opcja do 5kzł?
Warto wypróbować też tańsze rozwiązania; np. PUC2 Lite. Już kiedyś Cię do tego zachęcałem. ;)
Wg mnie to najlepszy stosunek ceny do jakości w konwerterach z prawdziwym wyjściem AES/EBU.
Taka opinia porównawcza SU-1 vs Mutec 3+...
I would characterize the SU-1 as clear, crisp and dynamic. Strings, drum, etc sound very well defined and have just enough of an edge without sounding bright or too sharp. High and lows are presented with a lot of energy and detail I did not hear previously with the MUTEC. The overall sound is very very clear, open, airy. Notes just rise in the air and lingers in a pleasant way. In no way is the SU-1 bright though.The midrange is where I am bit more conflicted. I will admit I am a bit of a closet/wannabe tube guy, though due to laziness I dont own any tube gear. I listen to mainly female vocals and acoustic music so I like a warm, intimate, organic environment. The MUTEC presented the midrange with more weight and texture (aside...maybe the texture I am hearing is graininess which the SU-1 definitely does not at all). There is more of a 3d effect with the MUTEC. Vocals seem to have shape and size. With the SU-1, vocals are definitely more flat and not as "warm". I wont go so far as to say mids are bleached out but compared to the MUTEC, the SU-1 presents mids in a different way. In my system, which already leans towards the warm and lush side, the SU-1 provides a good balance.
Overall, I am very pleased with the SU-1. The dynamics and energy of the SU-1 is very addictive. I was worried that perhaps I was falling in love with the BOSE effect but after a week, I havent experienced any listener fatigue. I am still trying to get my head wrapped around the presentation of the midrange though. However, i would say this comment is purely based on preference and not some shortcoming of the SU-1.
The build quality of the SU-1 is fantastic. Installing the driver was a breeze. Note that the included driver does not have settings for latency and buffer size which I am used to having.
Pojawil sie? To sie stalo niemal rok temu o ile dobrze pamietam.
SU-1 to z grubsza to samo ale z wlasnym , lepszym zasilaniem. Odrobina zdolnosci manualnych, pare groszy i SU-1 skacze o kolejny poziom wyzej w jakosci dzwieku.
Gato Audio AMP-150 (klasa A/B), Aqua La Voce S2, Open Baffle DIY
Lub niżej o poziom. I przerobić można wszystko na każdym poziomie, łącznie z zasilaniem sześcioma niezależnymi zasilaczami i płytką wybebeszoną pod lupą w 50 miejscach.
U mnie SU-1 zastąpił HiFace EVO + Clock. I był to skok o klasę wyżej. Jestem bardzo zadowolony. W jednej obudowie mam najnowszej generacji konwerter USB-cyfra audio (korzystam i z SPDIF i z AES-EBU jednocześnie), femtoclocki z wyjściem do taktowania DACa plus izolacja galwaniczna.
rafa przydałby się link to informacji odnośnie modowania su-1.
Tu znajdziesz sporo
Zaloguj się, aby zobaczyć treść (możliwe logowanie za pomocą ) ale i na computeraudiophile są wątki na ten temat.
tutaj się reklamują już z gotowym rozwiązaniem+zasilacz
patrzyłem 2 tygodnie temu i na pewno było to 400$, dziś już jest 450$ a sam singxer kosztuje 400;)
W kilku źródłach czytałem, że kończą nową wersję singxera i będzie prawdopodobnie w sierpniu.
Przerobienie we własnym zakresie to czysta przyjemność ;)
  • 2 miesiące temu...
Witam, możecie polecić jakiś fajny konwerter? Żeby kosztował ok 500zł, może być używany. Myślałem o hiface two, miałem wersję jeden z zasilaniem bateryjnym i był fajny ale sprzedałem po zmianie daca bo miał wejście usb ale konwerter w nim siada, two podobno lepszy nawet od modowanej jedynki i widziałem jakoś za 300zł używkę...
STACJONARNY: PC->NFB 1.32->HA2013 MOBILNY: HTC 10->CCA C16/FiiO FH5
ja bym na Twoim miejscu rozważył malinę z hatem za 500zł ale jesli nie to te dwa powinny zagrać dobrze
gustarda miałem i w porownaniu do maliny to jest przepaść na korzyść tej drugiej
od kiedy pojawiły się haty do malin konwertery usb/spdif moim zdaniem straciły rację bytu - przynajmniej w pieniądzach do ok 4 tyś zł bo malina gra porównywalnie do pc+mutec mc3+ a kosztuje 1/10
Też tak uważam. Malina z hatem DigiOne i akrylową obudową kosztuje poniżej 800 zł. Za tę kwotę otrzymujemy komputer SBC, pełną izolację galwaniczną częśći cyfrowej od komputerowej dla sygnałów I2S oraz doskonałej jakości sygnał SPDiF z jiterem poniżej 0.6 ps.
Serio raspberry pi tak świetnie daje radę? W jaki sposób łączy się ją z dacem? Rozumiem że pi z pc przez usb ale do daca także przez usb?
Chyba nie rozumiesz.
Ano nie. Czyli to na zasadzie jak z daphile że pi jako komputer i do niego dac przez usb? Tak nie chcę, ma działać normalnie przez pc, przeglądarka, foobar, gry itp pod windowsem.
W ten sposób, to nigdy Ci dobrze nie zagra.
Osobna Malina, to sprzęt który robi muzykę i nic więcej po drodze, nie ma wentylatorów, dysków i innych śmieci, do tego liniowy zasilacz i masz muzykę przez duże M.
Koniec z niestabilnymi sterownikami, trzaskami, szumami i walki z VIA.
Nie da się mieć najlepszy dźwięk z kompa, który służy do wszystkiego, bo doinstalowujesz pełno śmiecia, który siedzi w pamięci, sprawdza aktualizacje i szatkuje procesy, bo jakiś programik co jakiś czas łączy się z lanem i wysyła raporty co Ty tam robisz na tym kompie.
Czysty mini komputerek jak Malina nie ma tego balastu i robi tylko to co najważniejsze.
Dlatego gra tak dobrze.
Pygar
OK, jakiś opis poskładania tego rozwiązania z pi gdzieś znajdę? Z ciekawości poczytam.
Na dobry początek Wujek Google zawsze pomoże :
Pygar
Czekam obecnie na hiface two, kupiłem za 260zł używany na próbę bo mi nawala konwerter via w nfb 1.32 i chcę potwierdzić winę konwertera i głównie stąd zakup :P Ale dodam jeszcze że fatyguje mnie myśl jaki kupić przewód na kabel coax, wiem że 75ohm ale macie jakiś namiar? Coś porządnego bym chciał, do 100zł/metr. Rozumiem że może nie potrzeba tyle wydać i można kupić kabel za 15zł ale stawiam na dobrą jakość, poza tym mam sporo kabli w okolicy więc solidne ekranowanie mi potrzebne.
Weź coś z oferty Oyaide oni robią bardzo solidne kable z prawdziwym ekranowaniem i dokładnie na 75 Ohm.
Budżet nie jest jakiś wielki ale w używkach czasami coś się trafi w podanej okolicy +- 150zł, w fabrycznej konfekcji.
Pygar
Dzięki za info, popatrzę :) Mi jednak starczy sam kabel do diy, wtyki mam neutrik profi także sam sobie go polutuję :) Czytałem że ten singxer su-1 faktycznie jest fajnym konwerterem i można go jeszcze zmodować ale jakbym miał 1500zł wyłożyć i pieniądze za daca wziąć to nie wiem czy za ok 3000zł nie opłacało by się kupić już lepszy dac z dobrym usb :P Ano i usb w moim dacu też jest do odratowania poprzez wprowadzenie kilku drobnych zmian :) Ale trzeba zainwestować grosza i nie bać się testować :)
Poszukaj Belden 1695A lub Belden 1694A. Jeżeli nie znajdziesz, to zgłoś się do mnie, może znajdę gdzieś w pudłach. ;)
+1
Mądrze gada.
Wymiana konwertera VIA na Amanero to jest drobna zmiana ? Tylko taki zabieg ma sens i przełoży się na słyszalny efekt.
Te Dace były produkowane w kilku wersjach. Były takie w których konwerter był wymienialny i takie w których konwerter był wbudowany w płytę główną i wymienić go nie można.
Niestety, u mnie jest na płycie głównej stąd wspomniałem o wprowadzeniu zmian w samym konwerterze via które mi polecono w temacie o audio gd, dlatego zmiana raczej nie będzie wielka bo nie wsadzę tam amanero a spróbuję naprawić vię...
