Wzmacniacze operacyjne, op-ampy, czas obalić mity
Recommended Posts
Trafiłem na bardzo ciekawą książkę pt. Small signal audio design, autor Douglas Self.
A jest co czytać, kniga ma 780 stron.
2 cytaty:
1. [Chapter 4]
The LT1028 is not suitable for audio use for reasons described in Chapter 11.
2. [Chapter 11]
You may be wondering what has happened to other well-known opamps, particularly the
OP-27 and the LT1028. Both are sometimes recommended for audio use, because of their
low e n s, but this ignores a serious problem. The OP-27 has a low e n and i n , and in fact gives
a calculated EIN of 123.0 dB, which beats the 5532A noise, but when you measure it in
real life it is actually several dB noisier; I have confirmed this several times. This is due to
extra noise generated by bias-current cancellation circuitry. Correlated noise currents are
fed into both inputs, and will only cancel if both inputs see the same impedance. In this
MM-RIAA application the impedances are wildly different, and the result is much increased
noise. This problem with the OP-27 was originally pointed out to me by Marcel van de
Gevel.
The LT1028 gives a poor performance in MM applications because while it has an
appealingly low e n of 0.85 nV√ Hz, its i n is high at 1 pA√ Hz as a result of running big input
BJTs at high collector currents. The EIN is by calculation 120.9 dBu, making it a shade
quieter than the 5532A. But the LT1028 also has bias-current cancellation circuitry, and the
data sheet explicitly states, ‘the cancellation circuitry injects two correlated current noise
components into the two inputs.’ According to Gevel [9] the effective voltage noise in an MM
application is about 39 nV√ Hz, so even the 741 would be a better choice.
Nocny Kochanek
Link to post
Share on other sites
51 minut temu, SomekPoland napisał:
Książka jest super, kupiłem we wrześniu. To jakie mity chcesz obalać?
Może takie, że wszystko pasuje do wszystkiego ;-).
Faktem jest, że ludzie często żonglują wzmacniaczami operacyjnego bez żadnego pojęcia.
Ale jest też faktem, że czasem ciężko znaleźć istotne szczegóły na temat rozwiązań zastosowanych w poszczególnych wzmacniaczach.
Edited by Jaro_747
  • Like 1
Jestem Europejczykiem.
We własnym kraju jestem rebeliantem.
Link to post
8 godzin temu, SomekPoland napisał:
Trochę ostatnio dłubię i bardzo polecam OPA1612, robi robotę aż miło, jak taniej to LM4562/NE5532. Jak JFET potrzebny to OPA1642 i OPA1656.
Mam gdzies jeszcze kilka kostek NE5532 sygnowanych przez Signetics - musze poszukac. O ile pamietam, dobre 12 lat temu wstawione do bardzo taniego CD, bez jakiejkolwiek ingerencji w zasilanie graly z lepszym konturem i wypelnieniem, anizeli znacznie nowsze i mocno promowane OPA2134, czy OPA2604.
Podobno to (Signetics) byly najlepsze NE5532 ever.
  • Like 2
Link to post
Były. Muzykalne bardzo, ale bez fajerwerków. Należy pamiętac, ze jeżeli producent sygnuje coś takim , a nie innym oznaczeniem nie oznacza , ze to ta sama struktura w środku. To oznacza tylko zgodność z dataszitem.
Link to post
Co to dokładnie znaczy "struktura"?
Struktura półprzewodnikowa w sensie chipa jest inna, bo producent jest inny. Natomiast co do schematu to szczerze wątpię żeby były jakieś różnice.
Link to post
Struktura musi też być taka sama inaczej oznaczenie będzie fałszywe. Za to mogą grozić poważne konsekwencje.
Link to post
Ja używam 2134 w końcówkach mocy (w buforze) ale nie powiedziałbym o nich, że grają z wypełnieniem czy też mają jakiś konturowy bas. Wręcz przeciwnie. Wydają się u mnie grać dość linowo bez fajerwerków i sztuczności. Odkrywają dużo szczegółów w muzyce ale myślę, że właśnie dlatego, że żadne pasmo nie stara się wychodzić przed szereg.
  • Confused 1
Link to post
A czy charakterystyka opampa w zakresie częstotliwości akustycznych nie jest przypadkiem płaska?
Link to post
Już miałem nadzieję, że będą obalane mity. Człowiek napisał w książce, że popularny scalaczek o bardzo dobrych parametrach szumowych podawanych na pierwszej stronie dokumetacji w samochwałce niezbyt fortunnie zaaplikowany szumi więcej niż bardzo. Jednak dyskusja nowych mitów nie podaje i nie obala. Powodów łatwo sie domysleć. Za to pewnie powstanie nowa saga o tym kto co wsadzał, co usłyszał i że elementy sprzed 30lat nie istniejących firm  są najlesze, Ale jest tez poztyw, może sobie tą książkę kupię 🙂
  • Like 1
Link to post
W dniu 29.12.2020 o 15:06, McGyver napisał:
Według szkoły otwockiej. A według falenickiej - Philipsy.
Sygnetics to też Philips.
Link to post
Zależy jakiego i przy jakim wzmocnieniu.
Akurat pasmo w określonej dla m.cz. grupie jest mało istotne wobec istnienie głębokiej pętli USZ.
A w ogóle to wzmacniacze operacyjne są szeroką grupą elementów. Takie dedykowane do m.cz. (elektroakustyki) stanowią zdecydowaną mniejszość.
Link to post
Otóż to. Więc jak mam rozumieć takie zdanie:
Sugeruje ono, że tak jest dla konkretnego typu opampa, w tym wypadku 2134. Czy dla innych jest inaczej?
Nie rozumiem też tego zdania:
Chodzi mi o ową konturowość i wypełnienie.
Albo:
Lub:
O co tu chodzi?
Link to post
Wymieniałem w kilku odtwarzaczach 5532 na 2134, wszelkie Musesy itp. i zawsze 5532 były najgorsze. Zwykłe 8820 dawały przestrzeń i mięsko, 2134 dawały wgląd w nagranie....
Są jeszcze droższe i lepsze układy, te dopiero grają.
Oczywiście są wyjątki takie jak badziewny 2604 grający płasko i chłodno.
Link to post
Najpewniej układy są projektowane pod konkretne opampy, bywa że i te najtańsze, a wtedy wkładanie "lepszych" często daje gorszy efekt.
Zastanawia też subiektywny odbiór równowagi totalnej dźwięku. Uklad składa się z wielu części elektronicznych towarzyszących opampow. Zastanawia mnie z czego wynikają tak duże różnice w odbiorze równowagi tonalnej: charakterystyki pasma przenoszenia, THD...?
Link to post
Z subiektywnych odczuć osób.
Link to post
Wiele osób pewnie zauważyło bawiąc się układami prototypowymi wzmacniaczy dyskretnych jak silniejsze sprzężenie zwrotne wpływa na parametry i jak na dźwięk - to się nie zawsze pokrywa. A wzmacniacze operacyjne są robione pod kątem pomiarów, mają pełno tranzystorów z malutkimi prądami i ogromne wzmocnienie po 130dB aby uzyskać świetną liniowość. Tylko to nie jest droga do uzyskania najlepszego dźwięku, bo najlepsze układy dyskretne w klasie A grają naturalniej, nawet jak nie mają tak wyśrubowanych parametrów jak np. 0.00001% THD jak np LME49990.
  • Like 2
Link to post
No właśnie.
Ale producenci wkładają w tor wiele WO a w nich dziesiątki tranzystorów i nie widziałem rankingu aby więcej "tranzystorów przeliczeniowych" dyskwalifikowało wzmacniacz. Podobnie jest w każdym innym klocku audio...
Szczerze mówiąc to w takim poważnym WO zazwyczaj są dwa stopnie wzmocnienia a reszta to stabilizacja, dopasowania poziomów,...
Link to post
Są subiektywne, ale i powtarzalne w testach odsluchowych. Ten subiektywny odbiór z czegoś wynika.To nie jest chwilowe wrazenie czegos. Potwierdzają to też firmowe konstrukcje gdzie producent celowo kształtuje wrażenia z odbioru dźwięku.  Tam nie ma przypadku, tylko całe zaplecze laboratoryjne.
Edited by jamess8
Link to post
Mowa była o ne 5532 SIGNETICS , ja nie zauważyłem by te układy były gorsze w stosunku dowyżej wymienionych...
Link to post
A jaki jest wynik testu różnicowego u tych producentów? Taki test musi potwierdzić istnienie różnic w domenie techniki skoro są stwierdzone na ucho. Jeżeli nie potwierdza to wnioski nie powinny już sprawiać żadnego problemu, ale kto by się przejmował rzetelnością w testach porównawczych, ważna jest dobra zabawa 😉.
Jak zwykły WO może dodać "przestrzeń"? Może ktoś to wyjaśnić technicznie?
  • Haha 1
Link to post
Z tymi firmowymi konstrukcjami i opisami producentów, to bym uważał. Sytuacja jest podobna jak u producentów kabli. Więcej legendy, mniej rzetelnej techniki w opisie. Czasami zupełnie jej nie ma.
To mit. Jest taki stary artykuł. Trzeba go koniecznie przeczytać przed wyrażaniem opinii o negatywnym wpływie sprzężenia zwrotnego na brzmienie.
Część pierwsza:
Hidden Content
Część druga:
Hidden Content
Technicznie się nie da.
Odbiór muzyki jest czymś bardzo skomplikowanym, i sądzę, że kwestie czysto techniczne, aczkolwiek ważne nie są najważniejsze. Dlatego też katgoryzowanie i wartościowanie różnych technik na podstawie własnych subiektywnych wrażeń nie jest dobrą metodą i najczęściej prowadzi do błędnych wniosków, będących potem podstawą różnych legend i stereotypów nie mających nic wspólnego z rzeczywistymi faktami. Stąd też to "dodawanie przestrzeni" - efekt powstający w głowie zupełnie nie mający odzwierciedlenia w zmianach wprowadzanych w sygnale przez urządzenie.
  • Like 1
  • Haha 1
Link to post
Czytaj sobie, czytaj, ja znam temat z praktyki, z czasów kiedy nie byłem jeszcze audiofilem, ale zauważyłem pewne zależności.
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Prosimy wyłącz rozszerzenie AdBlock podczas używania strony.
Zarejestrowani użytkownicy mogą wyłączyć ten komunikat.
