Hi-endowe nowości
Ciekawy to będzie nowy gramofon SME / Gerrard (SME kupiło właśnie IP i prawa do nazwy tego ostatniego).
Ciekawe czy nadal będzie grało jak drętwe CD. Edytowane przez jello
...tak wygląda lampa KR Audio KT150....trochę koślawo wrzuciłem
Zaloguj się, aby zobaczyć treść (możliwe logowanie za pomocą ) Edytowane przez Miroslav1
  • 4 tygodnie później...
Piekło zamarzło - McIntosh wprowadza dwa wzmacniacze pracujące w klasie D.
Ale spokojnie, modele MI254 and MI128 to urządzenia do instalacji (napędzania głośników in-wall itd).
Distribution Amplifiers
The new distribution amplifiers consist of the MI254 and MI128 Power Amplifiers. The MI254 is a 4-channel amplifier outputting 250 Watts per channel, while the 8-channel MI128 outputs 120 Watts per channel. Each employ highly sophisticated closed loop digital switching amplifiers that are paired with extremely robust power supplies to produce performance levels that are rarely achieved in distributed audio.
Both have the same installer-friendly physical dimensions and are 2U rack mountable (mounting ears are removable for non-rack installations). As highly efficient Class D amplifiers, they do not require noisy cooling fans to maintain nominal operating temperature. In addition to distributed audio use, the MI254 is well suited for home theaters to drive surround sound speakers and could be integrated into virtually any existing home theater system.
On the front panel, both feature multi-color LED indicators to display the status of each channel. The MI254 also includes two blue McIntosh Watt Meters that display the summed power output of channels 1 + 2 and channels 3 + 4. On the back, the MI254 uses our standard 5-way speaker binding posts while the MI128 uses 2-pole Phoenix style push-in speaker terminals. The MI128 also includes back panel volume controls for volume balancing, along with 2 digital audio inputs (either coax or optical), and channel summing circuits for easy mono signal distribution.
The MI254 and MI128 share many common features, including: elements of classic McIntosh industrial design and engineering principles as evidenced by the inclusion of signal overload technology that prevents overdriving the speakers; BUS input & outputs to easily distribute a stereo signal to multiple outputs and/or multiple amplifiers; individual channel inputs; 12 Volt triggering capabilities; and eco-friendly on/off signal sensing that automatically turns the unit off if no input signal has been detected for a set amount of time.
Auralic wprowadza masterclocka -
"I am an audiophile"
Jestem ciekaw w jakim stopniu poprawi grę Auralica vegi g2 który według mnie jest już bardzo dobrym urządzeniem.Cena zobowiązuje 36k za sam zegar hoho.
  • 3 miesiące później...
Dynaudio zaprezentował ciekawe monitory Core 59 i Core 7. Model Core 59 ma 9,5" woofer, 3 drożna konstrukcję. Obydwa modele mają między innymi wejście cyfrowe AES3.
Edytowane przez Kyle
  • 2 miesiące później...
Nowa wersja SF Electy Amator: nr 3
A tu więcej fotek:ttps://www.on-mag.fr/index.php/topaudio/actualites-news/18496-sonus-faber-devoile-l-enceinte-electa-amator-iii-perle-d-acoustique-dans-la-pure-tradition-italienne-avec-piedestal-en-marbre
Super są te nowe EA III (z wyglądu - nie słuchałem). Nawet mam drukowany prospekt - w obecnych czasach to niemal rarytas ?
Horn miał je pokazać na ostatnim AVS, ale ostatecznie podjęto decyzję polityczną, aby pokazać coś co ma szansę na większą realną sprzedaż (serię Sonetto).
Może w tym roku się złamią.
W dniu ‎11‎.‎05‎.‎2019 o 01:33, GT napisał:
Ethos CD Player / DAC
148 090 zł
Absurd ?
Ciekawe z punktu marketingowego jest te 90 zł w końcówce, wskazujące potencjalnemu klientowi, że cena jest dokładnie skalkulowana (czytaj - taka jaka powinna być).
Ja rozumiem koszty badań, projektu itp. ale nie wierzę, że to cudo rzeczywiście tyle powinno kosztować.
Oczywiście w dzisiejszym świecie, w przeciwieństwie do lat wcześniejszych jest coraz więcej ludzi stać od ręki kupić taki sprzęt. I nie mam tu na myśli klasy średniej, bo jej zarobki praktycznie niewiele się ruszyły od lat 80-tych, ale wszelkiej maści menadżerków, sportowców, artystów, celebrytów czy polityków.
Pamietam, ja w sumie to nie dawno oburzano się, ze pierwszy piłkarz w lidze angielskiej dostał tygodniówkę w wysokości 50-tysięcy funtów. A dzisiaj taki Sanchezik w MU zgarnia za 7 dni dziesięć razy tyle.
Więc kupno dla niego takiego Ethosa, to jak dla 95% ludzi na świecie kupno bułek w sklepie.
A przy okazji - rozumiem, że za jakość trzeba płacić, ale referencyjny odtwarzacz to maks. 50 tysi (może nawet mniej). Wszystko powyżej to już naciąganie (bogatych) klientów.
To się tyczy 99% współczesnych sprzętów i to z każdej półki cenowej.
Politykę robi się za pomocą pieniędzy, a pieniądze za pomocą polityki. Ot, taki przypadek...
Oczywiste.
Przy okazji - wmawia się nam w testach czy recenzjach, że sprzęt naprawdę bardzo drogi  może mieć niedostatki i ułomności. Jednym słowem może być nieperfekcyjny, czyli w domyśle - chce jeszcze lepiej, musisz kupić jeszcze drożej.
Po drugie - dla wielu, również na tym forum pewnie jest bardziej nobilitujące rozmawianie o odtwarzaczu za 150k zł, a nie jakiś tam marnych 50k zł, zważywszy, że przeciętny Kowalki w domu ma taki z 2k zł.
Mnie to specjalnie nie rajcuje.
I jeszcze na koniec - ceny sprzętu high-end zwyczajnie przypominają ceny dzieł sztuki. Całkowicie subiektywnych.
Pisałem już gdzieś wcześniej  tym, że moja twarz nabiera koloru flagi radzieckiej, kiedy czytam, słucham, jak to samochód za 100 tys. też może mieć ułomności, bo to przecież tylko 100 tys., to czego mam czelność oczekiwać. Dokładnie tak samo jest w branży audio. I się dziwić potem, że ludzie ( w tym po części ja sam ) odwracają się do vintage szrotów :-))).
Nie ma sensu podniecać się cenami. Sprzęt audio to nie dobra pierwszej potrzeby. Poza tym, producent ma prawo ustalić cenę na dowolnym poziomie. Najwyżej nie sprzeda i zbankrutuje. Jednego stać na lanosa, innego na bentleya.
Po pierwsze nikt się tu nie podnieca. Przeca pisałem, że mnie to w ogóle nie nobilituje.
A po drugie - uważasz, że takie działania producentów nie ma żadnego wpływu na Twój portfel?
Problem polega na tym, że tak ze 2 dekady temu wielu narzekało, że sprzęt audio wyższej klasy nie jest poważnie traktowany w kategorii produktów luksusowych(np. jako oznaka prestiżu, dobrze pojętego snobizmu itd.) - a jedynie jako dziwaczne hobby przypisane nie do "ludzi sukcesu" ale do wyalienowanych, aspołecznych jednostek, które budzą bardziej politowanie niż podziw. To były czasy zachłyśnięcia się kinem domowym, kiedy niektórzy producenci w ogóle rezygnowali z produkcji urządzeń audio, dlatego niektórzy wiązali pewne nadzieje w promocji branży wśród nowych grup majętnych odbiorców. Dziś można powiedzieć, że to się udało - ludzie kupują drogie gramofony jako designerskie gadżety, czasem nawet ich nie podłączają. Towar luksusowy ma to do siebie, że nie istnieje pojęcie cena/jakość a określenie tani to najgorsza obelga. Z drugiej strony np. sam design kolumn YG Acoustic jest wart pewnie ze 20-30 tys. (podejrzewam, że meble w takiej industrialnej stylistyce mogą być nawet droższe).
Nie rozumiem osób, które narzekają na ten stan rzeczy - skoro te hi-endy są poza zasięgiem portfela i grają za ułamek swojej ceny to czego tu żałować?
Wysłane z mojego LG-H870 przy użyciu Tapatalka
To jeszcze włoska robota z innych ujęć..
10 minut temu, Silver_85 napisał:
No piękne te Essence. Eleganckie bez festyniarstwa.
Tylko to trzeba chyba być kawalerem beż żony, dzieci, psów, chomików, teściowych, rodziny z rozkołysaną gównażerią itp. :-))))))
Jak ktoś z powyższych by mi nawet chuchnął na te cuda ...poszedłbym siedzieć za morderstwo ze szczególnym okrucieństwem :-)).
Nowa odsłona AR CD 6 i CD 9 z dopiskiem SE.
Piękny design nowych CD ARC. Taki retro-modern.
  • 5 tygodni później...
Lexicon SL-1 Steerable Wireless Loudspeaker (each):
• 33 speaker drivers
- Twelve 3⁄4” (19mm) Tweeters
- Sixteen 2” (50mm) Mid-range
- Four 5.25” (135mm) Woofers
- One 10” (250mm) Integrated Subwoofer
• 23 channels of amplification
• 650 Watts RMS
• 24-bit Audio Connectivity
• Two LED Rings to indicate beam width & direction
• Grille on/off auto-EQ optimization settings
Cytat
Mark Hockey (Marketing Manager at Harman Consumer UK): Biorąc pod uwagę, że ceny niektórych kolumn pasywnych z oferty JBL dochodzą do 90.000 Funtów (
Zaloguj się, aby zobaczyć treść (możliwe logowanie za pomocą ) ) i to, że mamy jednak do czynienia z bardzo zaawansowanym urządzeniem aktywnym, o znakomitym brzemieniu, z regulowaną wielkością i położeniem sweet spotu, to jest to cena wypadkowa pomiędzy kolumnami hi-endowymi, a takimi „zwykłymi”.
Wczoraj, miała miejsce oficjalna premiera, na którą zjechało się wielu dziennikarzy oraz dealerów i słychać było w komentarzach, że prezentacja bardzo mocno przekonała ich co do tej technologii.
Kolumny do sprzedaży powinny trafić na przełomie roku – istnieje spora szansa, że w pełni gotową wersję produkcyjną przywiozę do Warszawy – spodziewaj się więc mnie i SL-1 na Audio Video Show 2019.
... - przewidywana cena 43.000 Euro za parę.
Ciekawe. Wydumka trochę na kształt topowych B&O.
Focal Spectral 40
Cena - 8k EU
On 8/16/2008 at 9:20 PM, Elberoth said:
Aby zachować przejrzystość takiego wątku, ważne jest jednak przestrzeganie jednej podstawowej zasady:
NIE KOMENTUJEMY ZDJĘĆ. WKLEJAMY TYLKO ZDJĘCIA PRODUKTÓW I ICH OPISY.
